Old March 8th, 2019, 04:34 PM   #1
BikeRider
Motorcycle(s): NA
2010 Ninja 250r Project Won't run without Choke
Hi I know this has been talked about a lot, but I recently bought a 2010 Ninja 250r with 700 aprox miles on it for 850. It has an issue where the gear where the starter connects to the fly wheel gear case hole broke, but I just removed that gear and put new oil and coolant in it. Anyway I knew the bike had been sitting so I stripped down the carbs ultrasonic cleaned them make sure all the jets were clear and put then back in. Went to start the bike and it started on choke and idled around 7k rpm but when I tried to turn the choke off it died on me even after letting it warm up for a good while. Just took the carbs off again and looked in there and everything was still clean and no clogged gets or stuck floats or anything! Looks NEW! Biggest thing is some vacuum hoses were missing when I got it so I'm not sure on some of the hosing and that might be what is causing it not to run. Any suggestions?
BikeRider is offline   Reply With Quote
Old March 9th, 2019, 07:37 PM   #2
How far did you disassemble carbs?
Enough to floss out fuel-circuits and bleed-holes in emulsion tube and pilot jet?
https://www.ninjette.org/forums/show...39#post1242539
Old March 9th, 2019, 08:37 PM   #3
BikeRider
Motorcycle(s): NA
Yes and there were no clogged holes in the pilot jet or main jet and it all looked as if new.
Old March 10th, 2019, 07:15 AM   #4
where do you have your pilot screws set?
Won't run without choke and dies when given throttle Kryptykcloudz 2008 - 2012 Ninja 250R Tech Talk 32 July 20th, 2021 10:33 AM
2009 250r won't run without choke Bonereviver 2008 - 2012 Ninja 250R Tech Talk 8 February 3rd, 2014 08:00 PM
Won't "run right", won't idle, choke only, etc?? - SOLUTION HERE Jiggyfly 2008 - 2012 Ninja 250R Tech Talk 5 May 16th, 2012 09:50 AM
Oil rapidly filling airbox, won't run without choke. 44chart 1986 - 2007 Ninja 250R Tech Talk 21 March 28th, 2011 09:13 PM
Ninja 250r Wont Rev or run without choke esde 1986 - 2007 Ninja 250R Tech Talk 21 November 9th, 2009 02:32 PM
