Notices
Old April 13th, 2012, 06:41 PM   #1
Dimsum_The
Intermittent Horn Problems
I recently installed a new switchgear on my 93 Ninja with the push to cancel turn signal switch. My old switch gear had a broken horn button that the previous owner said was broken when he bought it. After repinning the connectors from the switchgear it worked fine for a while, recently though the horn has only been working when im going 12-20mph or faster (as indicated on the speedo) I've checked all the connections and for the life of me cant figure out why this would happen.
Dimsum_The is offline   Reply With Quote
Old April 15th, 2012, 05:49 PM   #2
Dimsum_The
So does anyone have any ideas of what could cause this? I'm pretty sure its not the carb...
Old April 15th, 2012, 06:07 PM   #3
cuong-nutz
cuong-nutz's Avatar
So you've checked the wires and connection at the horn? Perhaps it corroded and has a bad contact. Disconnect the horn and take a look.
HalfFast Racing Team
Intermittent Headlight Problem n4mwd 1986 - 2007 Ninja 250R Tech Talk 3 December 25th, 2012 05:18 PM
having an intermittent starting problem! davidfriend 1986 - 2007 Ninja 250R Tech Talk 8 April 18th, 2012 05:16 AM
Installed Stebel Nautilus air horn, a.k.a. Wolo "Bad Boy" horn FrugalNinja250 1986 - 2007 Ninja 250R Farkles 8 June 23rd, 2011 05:37 AM
Intermittent Clunk 2005 gogiburn 1986 - 2007 Ninja 250R Tech Talk 1 August 18th, 2010 07:31 PM
Intermittent headlight dowmace 1986 - 2007 Ninja 250R Tech Talk 3 May 19th, 2010 09:55 AM
