Old January 6th, 2014, 07:22 PM   #1
mwirrick
mwirrick's Avatar
Motorcycle(s): 2008 Ninja 250, Concours, 2009 FZ1, 2007 BMW G650X Challenge, 1997 Ducati 900SS, SP
K&N Pod filter
I've recently removed the air box from my race bike (wow, so much room to move around in now!), but installing the K&N pod filter (oval shaped with two intake ports that match the stock carb pretty well) has me a wondering if the lack of support the carb now has--since the air box is gone--could be a problem. Its pretty much just hanging on the rubber intake runners as it sits now. That doesn't seem ideal. Any thoughts out there? I can pretty easily put some zip ties here and there to help support it, but that will look a little tacky, to say the least. And I am not sure that will be sufficient. Hate for the thing to fall off mid race! Thanks.
Mike
-Less is More Racing, Inc.
mwirrick is offline   Reply With Quote
Old January 6th, 2014, 09:03 PM   #2
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
I zip tied my to the frame and it pulled them off of the motor. I couldn't figure out why it wouldn't start and everyone laughed at me. I didn't zip tie the filter to anything and it stayed on for over 14,000 miles.
Old January 7th, 2014, 07:44 AM   #3
DCMoney
DCMoney's Avatar
I safety wired mine to a hard part on the carb...
I was not comfortable with the pods just hanging there at all.
Will post a picture later.
MCRA.com
Old January 7th, 2014, 08:04 AM   #4
Quite a few members have used zipties (or something similar) to secure their carbs and/or pod filter to the frame. Same reasoning as you.
If it makes you feel better, go for it. If you don't want to worry about it, it's not necessary. 6000+ miles on mine with the carbs/filter just dangling and no problems yet.
Old January 7th, 2014, 09:51 PM   #5
mwirrick
mwirrick's Avatar
Thanks for the quick responses. Not sure how I will proceed, but good to know others have had the same thoughts. I can see how zip ties could pull the filter off, but leaving it hanging on the rubber intake tubes concerns me, too. Will probably try both approaches and see how things go. Thanks again.
MW
Mike
Old January 10th, 2014, 12:15 PM   #6
I thought some race orgs required the stock airbox in place?
Old January 10th, 2014, 12:17 PM   #7
DCMoney
DCMoney's Avatar
Some do, ours doesn't.
MCRA.com
Old January 10th, 2014, 12:19 PM   #8
Some race orgs in our (Mike and I) area have a "gentleman's" ruleset. It's basically, supersport rules or "as long as your not cheating to bad". lol
Old January 10th, 2014, 12:23 PM   #9
DCMoney
DCMoney's Avatar
Last season sure, this season not so much.
Link
ninja 250
unmodified engine
unmodified oem carburetor body
unmodified oem ecu
oem fork externals must be used
oem swing arm must be used, can add spools shark fin etc
17'' stock wheels must be used. gen 1 ninja 250 may upgrade from 16'' front wheel to 17'' wheel as long as it is as close to stock weight as possible
pump gas
anything not listed above may be changed or modified
MCRA.com
Old January 10th, 2014, 12:28 PM   #10
The airbox is not on that list, so I would assume it can be changed as pods can be attached to a stock carb body. Am I missing something?
Old January 10th, 2014, 12:29 PM   #11
Nevermind, I follow you now. See ya in April!
Old January 10th, 2014, 01:12 PM   #12
DCMoney
DCMoney's Avatar
Yeah, no more gentleman's agreement if you have a few hours to waste should read through the 250 threads on that forum....
MCRA.com
Old January 10th, 2014, 01:23 PM   #13
Will do, thanks for the heads up. Since I plan on doing the races, I should keep up with things.
Old January 10th, 2014, 05:57 PM   #14
mwirrick
mwirrick's Avatar
Midwest Cafe Racing Association (MCRA) allows removal of the air box this year. So does the CMRA (Texas based organization). Not sure about WERA. As was said, some outfits allow it, some don't. Sure does free up a lot of space and make things easier to get to!
Mike
BNIB K&N pod filter cuong-nutz Motorcycle-related 5 September 17th, 2013 12:27 PM
K&N Pod Filter Peanut_EOD 2013 - 2017 Ninja 300 Tech Talk 23 November 15th, 2012 08:35 PM
K&N Pod Filter with Stock Exhaust? krolinked 2008 - 2012 Ninja 250R Tech Talk 3 August 6th, 2012 07:47 PM
guys w/pod filter &or slip on cuz 2008 - 2012 Ninja 250R Tech Talk 9 September 6th, 2011 05:24 AM
K&N Filter or Pod jonthechron 2008 - 2012 Ninja 250R Tech Talk 6 February 17th, 2010 12:07 PM
