Old May 15th, 2014, 09:01 AM   #1
agentbad
agentbad's Avatar
RK 520XSO Chain Clip vs Rivet Master Link
So I just ordered some parts from Murph's and saw they have a RK 520XSO Chain with the correct amount of links (106) and a clip style master link. I know clip style master links aren't as popular but many seem to use them without any problems. My main reason for going with the clip is it's easier to install and I don't have a chain breaker so I will just be cutting the old chain off. I would definitly add some safety wire to the clip for peace of mind. Does it really matter with the proper precautions?
Old May 15th, 2014, 09:14 AM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
They have worked for many years.
Old May 15th, 2014, 09:30 AM   #3
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
if i were you i would still get a chain press.
TEAM ALFALFA
www.apexassassins.com
Old May 15th, 2014, 12:22 PM   #4
Red250R
Red250R's Avatar
I installed that chain with the clip link. No issues at all. I used a small tywrap tho. I had the same problem as you. No chain breaker. I've been meaning to buy one to install a rivet type master but since I haven't had any problems, I've been holding off. I know thats not a smart way to rationalize it, but that's what's happening lol
Red250R is offline   Reply With Quote
Old May 15th, 2014, 01:08 PM   #5
agentbad
agentbad's Avatar
After watching this I think the chain press is a good idea. I am sure I could Macgyver it like this dude but seems like a bit more work. Also which way should the clip be pointing?
Old May 15th, 2014, 07:35 PM   #6
Closed end of the clip faces the direction of rotation. Open end faces the direction the chain is coming from.
How to install a rivet style chain Alex General Motorcycling Discussion 4 June 25th, 2014 02:34 PM
More chain trouble: 2-month old chain, O-Ring failure at master link. :( What now? CZroe 2008 - 2012 Ninja 250R Tech Talk 56 July 7th, 2012 05:42 PM
Adding a rivet master link to the stock chain ??? Tiane 2008 - 2012 Ninja 250R Tech Talk 1 June 13th, 2012 12:58 AM
Request: Silver chain, gold master link. Mountain Dew Pictures 3 January 25th, 2012 08:24 AM
FS: RK XSO 520 gold rivet master link choneofakind Motorcycle-related 3 January 18th, 2012 05:48 PM
