Old January 22nd, 2018, 12:47 PM   #81
spent_too_much
spent_too_much's Avatar
Originally Posted by Ram Jet View Post
Silver wheels.
Bill
Thanks, but I already have a set of black wheels with good tires on it.
Old January 22nd, 2018, 12:49 PM   #82
spent_too_much
I am poised to resume progress.
Old January 23rd, 2018, 01:01 PM   #83
spent_too_much
I spent some time last night organizing the parts for this build...
I hope to rebuild the front caliper tonight.
Old January 24th, 2018, 08:45 PM   #84
spent_too_much
I have made some progress over the last few days.
The front caliper is reassembled, and installed. ( The DOT 3 brake fluid was all I had on hand, and only used to wet the seals for reassembly. I'll use a fresh bottle of DOT 4 to fill the brakes upon final assembly. )
The engine is properly installed now.
The wiring harness is routed, and all front connections are complete.
The radiator, associated hoses, exhaust header, and headlight are installed.
I need to paint both of the handle bars, and then I can complete the front brake, and install the controls.
Old January 24th, 2018, 09:24 PM   #85
teafour
Corner Chaser
teafour's Avatar
Motorcycle(s): 2006 GSXR1000, 1986 VFR750, 2004 Ninja 250
Just looking amazing sir. Good work!
teafour is offline   Reply With Quote
Old January 25th, 2018, 06:35 AM   #86
rde09
Motorcycle(s): 250 ninja's (o6 yellow sold,04 project,03 green, 01 red/black & 97 yellow w/blue flames)
Your ninjette is really going to stand out when your finished and riding, or is it just to show off and admire (would be nice for a rally or bike show). That red and white really pops! Kudos
rde09 is offline   Reply With Quote
Old January 25th, 2018, 07:30 AM   #87
Making good progress.
Can't wait to see the finished bike!
Old January 25th, 2018, 02:43 PM   #88
spent_too_much
Me too! It has been a long road... So many of life's delays...
Old January 25th, 2018, 02:45 PM   #89
spent_too_much
Thanks! I am definitely going to ride it. The bike show might be a good idea.
Old February 5th, 2018, 06:52 AM   #90
spent_too_much
I spent a lot of time on reassembly last week, and made good progress...
Almost all of the electrical connections are done.
The front and rear brakes are installed, and filled with fresh fluid.
The carbs, and air filter box are installed. The carbs were done by Ducatiman, and I tore the air box apart to clean it out, prior to installation.
The tail, with lights, is installed.
I ran into a few snags, and must paint a handful of misc. parts to continue.
The shorter handlebar risers that I used are causing the brake and clutch levers to hit the guage pod, and prevent full turn. ( https://faq.ninja250.org/wiki/Loweri...rs_on_a_budget )
I didn't yet paint the grab handle, so I cannot button up the back end until I do.
I need to paint the bar end weights red, for accent.
Oh, and I had to remove the rear wheel, for access.
Old February 5th, 2018, 08:55 AM   #91
Ghostt
Ghostt's Avatar
LoL that's my write-up.
violente et ignorantia
ZX-2R BLOG
Old February 5th, 2018, 09:41 AM   #92
spent_too_much
LOL... I didn't think about the control contacting the cluster. I just focussed on them not impacting the tank.
It is a good write up, btw. And, now you know that someone benefitted from it.
Old February 5th, 2018, 09:47 AM   #93
Ghostt
Ghostt's Avatar
You can try adjusting them up a little bit so they don't hit the cluster.
BTW how do you like the new risers?
ZX-2R BLOG
Old February 16th, 2018, 04:32 AM   #94
spent_too_much
I can't comment as I have never ridden with them. Sorry.
Old February 16th, 2018, 04:41 AM   #95
spent_too_much
I have made some minor progress forward. The grab handle has been painted, and installed. The rear turn signals are installed. The bar end weights were painted and installed. The 15 tooth front sprocket, and 45 tooth rear sprocket were installed, along with the rear wheel. I swapped in the original, painted risers. The ignition switch was installed. I might be forgetting a few little odds and ends.
I think that I am in the home stretch now...
Old February 16th, 2018, 04:43 AM   #96
spent_too_much
A picture to illustrate the difference in height.
Old February 16th, 2018, 12:24 PM   #97
rde09
Looking better all the time!
Old February 17th, 2018, 02:45 PM   #98
spent_too_much
Thank You!
Old February 17th, 2018, 02:49 PM   #99
spent_too_much
For once, I am thinking ahead. I'll be ready for the fuel tank in no time, so I began to work on that this afternoon.
I cleaned the exterior, and then sanded it, trying to eliminiate as many of the scratches as I could. There is one nasty dent, which I will bondo, and hope to have it primed by the end of the 3 day weekend.
Old February 17th, 2018, 04:51 PM   #100
Ram Jet
Ram Jet's Avatar
Be CAREFUL with those forward fairing to tank screws. But I'm sure you know that. Don't you hate all that filling and sanding? I do. Nice work.
Bill
Old February 19th, 2018, 06:17 PM   #101
spent_too_much
I must have spent at least 5 hours, preparing the tank. I sanded it all, applied ( too much ) Bondo. Sanded that. Then realized that a few sections required more Bondo. Sanded that. Then an all over sanding in preparation for the high build primer.
It looks horrible now, but feels nice and smooth.
Last futzed with by spent_too_much; February 21st, 2018 at 08:47 PM.
Old February 19th, 2018, 06:24 PM   #102
spent_too_much
I attempted to install the chain tonight - but is was too short. I purchased it as an Amazon warehouse deal ( 6 months ago ). It looks like someone cut it too short and returned it. My 110 link chain, only ended up as 98 links ! I knew that I would need to shorten it to 106, to match my 15 / 45 set up, but this won't work.
I did manage to install the coolant overflow, side stand, disassembled and cleaned the fuel tank cap, and installed the turn signal / choke control though. So, it wasn't a complete bust.
I am so close to being ready to fire it up.
Last futzed with by spent_too_much; February 24th, 2018 at 02:57 PM.
Old February 20th, 2018, 12:33 PM   #103
rde09
Thumbs up
It is like a big elephant, taking it out one bite at a time. Looks great!
Old February 21st, 2018, 08:49 PM   #104
spent_too_much
I painted the tank tonight. I hope that it looks this good when the paint has cured, in a few days.
Old February 21st, 2018, 08:53 PM   #105
Ram Jet
Ram Jet's Avatar
Nice work. I hope my outboard motor tank comers out as well.
Bill
Old February 21st, 2018, 08:53 PM   #106
spent_too_much
Bill
Thanks Bill. Yes I am careful not to use too long of bolt in that location.
Old February 24th, 2018, 03:21 PM   #107
rde09
Thumbs up
What are you going to accent the tank and fairing with?
Red "NINJA" and "Kawasaki" in red on the belly cowl? Maybe some red pin striping?
Old February 25th, 2018, 07:48 PM   #108
spent_too_much
I hadn't thought about that. Perhaps my "trademark" "Ninja" on the tail, in red.
Old February 25th, 2018, 07:51 PM   #109
spent_too_much
I spent waaaayyy too much time installing the tank and sorting out the chain, but I am two steps closer.
Just a few more parts, and I can fire it up!
Old February 25th, 2018, 09:21 PM   #110
Ram Jet
Ram Jet's Avatar
Verrrrrrry interesting. I can wait to see it finished. Although you probably won't be able to stop modifying it for as long as you own it.
Bill
Old February 26th, 2018, 10:21 AM   #111
rde09
You could always place some red flames (which there wasn't any produced like that with white paint, only black w/red flames) and black Ninja and Kawasaki like the 06 models
Last futzed with by rde09; February 26th, 2018 at 11:32 AM.
Two motorcycles to build one Donovan1 1986 - 2007 Ninja 250R Tech Talk 11 March 7th, 2016 09:01 AM
a.kozak's 06 ex250 build (custom front end) a.kozak 1986 - 2007 Ninja 250R Farkles 16 October 22nd, 2014 07:31 AM
90 build up justin_ninja 1986 - 2007 Ninja 250R Tech Talk 4 January 12th, 2013 03:53 PM
Build Off or Rip Off? eddiekay General Motorcycling Discussion 13 December 9th, 2011 08:08 AM
2009 SE Build Betlog Pictures 8 July 21st, 2010 09:59 PM
