Notices
Old August 8th, 2017, 07:15 PM   #1
verve
Motorcycle(s): 07 ninja 250
brake lever causing brake light to be on constantly
so i bought a pair of levers from ebay and the clutch fit perfectly. the brake lever seems pretty loose but i noticed today that the brake light is on all the time. does anyone here know what it could be? any help would be appreciated and thanks in advance
verve is offline   Reply With Quote
Old August 8th, 2017, 07:32 PM   #2
DirtyPelican
DirtyPelican's Avatar
Motorcycle(s): Ninja 250, Triumph Speed Triple
I assume that its the front brake causing it, its the only change that occured right. Make sure that the electrical switch underneath the lever area is clicking properly. You might have to take it off and clean it all up to ensure smooth operation. You can hear it click when its engaged if you listen to the lever area
Check out my Ninja Bobber Build
https://www.ninjette.org/forums/showthread.php?t=298422
DirtyPelican is offline   Reply With Quote
Old August 9th, 2017, 06:13 AM   #3
Find where the brake like switch plunger is contacting the lever. That area is too close to the switch, or there is too much material there so it's pushing on the plunger and lighting the light.
You will need to remove some material in that area or modify the switch in some way to reduce the pressure on the plunger.
Without looking at it closely that's just a guess, but what i would expect to be the problem when changing to an aftermarket lever.
Old December 9th, 2017, 08:42 PM   #4
spent_too_much
spent_too_much's Avatar
The same thing happened to me with an after market set. I was originally sent the wrong part. The seller sent another, different lever, and that solved the issue.
Brake Light Lever Switch Adjustment Cra1g 1986 - 2007 Ninja 250R Tech Talk 10 September 6th, 2016 01:31 PM
Front Brake Lever Wont Activate Brake Light DmbShn41 2008 - 2012 Ninja 250R Tech Talk 6 May 10th, 2014 11:56 AM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
