Old March 23rd, 2018, 10:01 PM   #1
Josh4uto
Motorcycle(s): 99 ninja ex250
Easy easy easy tail light/ turn signal led mod
So ive seen lot videos people doing tail light mod but never found and info on parts used other then using stock signal bulbs sorry imo that lame lol but each its on i guess.
Im here to help out next guy need help or info on this mod.
I will lay out how remove housing , parts and tools
1) remove 2 10mm bolts under seat to remove housing
2) unplug 2pin plug attach to tail light bulb
That easy to remove
3) now there is one screw on each lens that need be removed and pop out lens carefully there amall tab at top that hold it in ao dont pull straight out will break , pull down and out
4) take 1/4 inch drill bit are dremel and cleanly knock down the raised portion of plastic to make it smooth
5) now want make small notch bout 1/4 inch for the bulb socket to pop into housing flushly
6) NO GLUE NEEDED ONLY 10MM WRENCH , PHILLIPS HEAD , DREMEL
GUESS WHAT YOUR DONE THAT IT
PARTS USED FOR PROJECT
1) OREILLYS GM 3157 SOCKET PART #85881
2) HALOGEN / LED BULB YOUR CHOICE I WENT WITH SUPER BRIGHT WHITE LED BULB SUPER BRIGHT
NOW YOUR TAILIGHT WILL BE SUPER BRIGHT AT NIGHT AND SIGNAL BE BRIGHT AS WELL AND NOTICED
WIRING STEPS
1) USE WIRES GOING TO OLD TURN SIGNAL AND USE ON NEW SOCKET REALLY SIMPLE 3 WIRE WERE AS OLD 2 WIRE ONLY THING DIFFERENT YOU GROUND 3 WIRE TO BIKE
HOPE THIS HELPS YOU OUT NOW YOU CAN DELETE THE BULKY PLASTIC HOLDING SIGNALS AND TAG SUPER CLEAN LOOK
Josh4uto is offline   Reply With Quote
Old January 28th, 2019, 04:17 PM   #2
Snake
Snake's Avatar
Thanks for the DIY write up!
Cheap and easy tail box. RogerPapaMike Cargo Space 5 January 10th, 2024 06:29 PM
gsxr damper easy mod mike_sema 2008 - 2012 Ninja 250R Tech Talk 11 March 18th, 2020 05:33 PM
turn signal tail light mod help plz BukkShot 1986 - 2007 Ninja 250R Tech Talk 3 March 18th, 2015 08:44 PM
go easy on me - i'm new. vsnizzle General Motorcycling Discussion 11 May 12th, 2014 05:47 AM
I Know This Should be Really Easy but... Scattcatt 2008 - 2012 Ninja 250R Tech Talk 20 August 25th, 2011 11:04 AM
