Old February 5th, 2019, 04:45 PM   #1
Raddad70
Motorcycle(s): Honda cx650, 2005 ninja 250
Funky ninja winter project
This fall I picked up a CL special for $350 - a running 2005 with no faring and a dented tank also missing instrument cluster and other stuff PO had started to convert into a naked street fighter. He said it had 13k on the clock- I choose to believe him He drilled into the top triple tree to mount a fat bar - which I like and plan to keep. Holes are a little off plus the fork tubes were a little twisted but not bent. Forgive me for not taking a before picture I stripped everything off the bike the first day I got it home. My plan is to modify this little bike into something fun and original - not to worried about performance- not gonna race it. I just want it to run decent. I will be doing everything myself and have been using this site for tech advice and inspiration. Here it is as it sits in my messy garage in zero deg weather - notice the frost on the engine case. Sorry can’t seem to load pictures- restricted?
Last futzed with by Raddad70; February 5th, 2019 at 05:58 PM. Reason: Can’t load pictures
Raddad70 is offline   Reply With Quote
Old February 5th, 2019, 05:06 PM   #2
in for the pics...
Good luck Dave!
csmith12 is online now   Reply With Quote
Old February 5th, 2019, 06:08 PM   #3
Raddad70
Sorry for the poor quality it's a picture of a picture - only way I could get it to load. Anyway I am using a tank off a old honda quad. Here is my initial concept for the build.
Old February 5th, 2019, 06:20 PM   #4
Raddad70
Using retro decals on the tank old river mark logo.
Old February 5th, 2019, 06:41 PM   #5
Raddad70
So far I did a valve adjustment, new plugs, and changed fork oil to 15w (added a bit more than stock to stiffen it up). Since the fork tube will be exposed on top I used these small discs found inside of hard drives to dress them up. Some sort of shiny metal - I don't think they will rust.
Old February 5th, 2019, 06:46 PM   #6
Ceeloo Yello
Motorcycle(s): 250
Looks interesting
Old February 5th, 2019, 07:57 PM   #7
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Enjoy your build!
Old February 6th, 2019, 06:42 PM   #8
Snake
Snake's Avatar
Awesome project bike!
Old February 9th, 2019, 08:02 PM   #9
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Good luck . I love seeing people revive the beaten abused forgotten bikes of the past. Most my toys have been the rejects lol. Preps on the creativity
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
Old February 9th, 2019, 08:49 PM   #10
I was able to get out some big dents from mine by making a pry bar that fit in the filler hole. I had to cut it and re-weld it a few times to get it to reach all the dents, but I got the sheet metal close enough that the Bondo never had to be more then 1/8" thick.
Old February 10th, 2019, 02:37 PM   #11
Raddad70
Unhappy
I was seriously thinking of using the original tank which would have simplified things greatly but I pulled the trigger and got a 1980s fourtrax 300 tank off eBay thinking it would matchup pretty good. It’s a little larger than I anticipated and the mounts will be tricky. Again want to do something unique. Not a lot of dents but there is rust and pinholes. Also the fuel petcock is gravity fed so I need to plug the vac port on the carbs. Still frozen so not much progress. I am setting a goal to have it complete by late summer. Next on the list is paint triple trees and get the forks mounted then I will know where to mount the tank so it has enough clearance then will come the seat.
Old February 14th, 2019, 06:16 PM   #12
Raddad70
Chopped the rear frame and the seat, unfortunately I can’t weld but I will be using steel bar stock to make brackets to brace the frame under the seat. Also the side panels and rear fender will be aluminum and bolted to the frame which may add some strength - minimal I know. Got these mini led turn indicators and mounted to existing tabs.
File Type: jpg 4A9FA461-D048-4F3E-98BA-5BE4F6268FC7.jpg (75.4 KB, 13 views)
File Type: jpg 884D2ED2-8711-4AB3-AD1A-D7245A538E5F.jpg (66.7 KB, 12 views)
Old March 5th, 2019, 07:41 PM   #13
Raddad70
Well this is going to be a slow process and on an extreme budget - family comes first yano. Almost every part I’ve ordered so far is from China on EBay. Not proud of this just the way it is. Front end coming together.
File Type: jpg 6A8027E2-E235-4E80-AB16-D14AD6D666C6.jpg (118.4 KB, 15 views)
Old March 6th, 2019, 07:30 AM   #14
dodgerdad
dodgerdad's Avatar
I can't imagine needing more strength in that rear section, especially if you leave those vertical bracket/tabs. Unless you're really, really heavy, I'd say it should be plenty strong.
Old March 6th, 2019, 07:49 PM   #15
Yeah, rear end should be fine with that lateral bracket at rear.
Old March 7th, 2019, 07:24 PM   #16
Raddad70
Cool, no 2 up, only me at 180 lbs.
Old March 7th, 2019, 08:24 PM   #17
dodgerdad
dodgerdad's Avatar
You'll be cool-in-da-gang
Old March 9th, 2019, 04:49 PM   #18
Raddad70
LED’s anyone? High beam mounted up, the low beam will go below it with an orange tint on the lens. Aluminum is great to work with - it is strong, light, easy to drill, cut, and shape - good stuff!
File Type: jpg 5DFCAC6E-A700-4C79-BC58-B7F21261EE3E.jpg (110.2 KB, 11 views)
File Type: jpg B9D72DFD-9C93-4379-AA6E-8F41191E3B87.jpg (103.9 KB, 5 views)
Old March 9th, 2019, 07:30 PM   #19
wow!!! Looks like some futuristic robot!!
Old March 10th, 2019, 06:48 AM   #20
Raddad70
Yes, I think it will look like something out of a bad 80’s sci-fi movie. Sorta neoretro, the course has been set.
Old March 25th, 2019, 06:04 PM   #21
Raddad70
Still so freakin cold here. Working on the seat today. I took a chance and bought a dirt bike seat but nothing was lining up that’s what sucks about custom work. It would be nice to have 30 bikes out back to try different parts to see what fits. So I went back to the original seat and cut the rear section off and scabbed it to the front. After a dozen rivets and aluminum plate this sucker is strong. Now just have to mesh the foam pieces, cover and done.
Old March 25th, 2019, 06:28 PM   #22
Raddad70
Seat pics
Old March 26th, 2019, 06:15 AM   #23
dodgerdad
dodgerdad's Avatar
You managed to merge those two pieces quite well!
Old April 2nd, 2019, 06:53 PM   #24
Raddad70
Headlight nearly complete, horn mounted under tank, turn indicators mounted to brackets on either side of the radiator. Front tire in the shop - should have by the weekend.
File Type: jpg A6E49D77-301F-4D1A-BDF1-F1CFF26783D4.jpg (109.7 KB, 5 views)
File Type: jpg 4F29FF1D-5245-4024-BE01-594C30FFA30D.jpg (110.6 KB, 4 views)
File Type: jpg F10DCC58-E485-44B2-BDE0-7CC331948054.jpg (118.9 KB, 3 views)
Old April 3rd, 2019, 08:06 AM   #25
t-cab12
Needs a riding buddy.
Motorcycle(s): 2008 Ninja 250, 1986 Honda Elite 80
loving it
Don't hide 'em. Ride 'em.
t-cab12 is offline   Reply With Quote
Old April 8th, 2019, 05:19 PM   #26
Raddad70
Got my gas cap today. To make this work I need to make a gasket and cut the opening larger. It will be close to flush when done - big improvement over the boat anchor that was on there - over a pound of steel.
File Type: jpg E0438651-2324-4A17-BBD8-3D3F5C4F51C3.jpg (102.6 KB, 4 views)
Old April 8th, 2019, 06:11 PM   #27
Raddad70
Okay the front tire is way too small looking imo. I went with this (Shinko 740 100/80-16) because it is a match for the rear 741 130/80-16- which is still in good shape and only 2 yrs old. Stock sizes right - I’m going to run it like this for now. Future plans go up a size on the tire or maybe go big 17” rim.
File Type: jpg 1465F741-FE2B-4151-B717-2649CD4CB217.jpg (119.8 KB, 12 views)
File Type: jpg 25068A38-04E8-446C-9653-E1028C210C1A.jpg (117.8 KB, 9 views)
Old April 9th, 2019, 06:08 AM   #28
dodgerdad
dodgerdad's Avatar
Noticeably smaller front but I kinda like the stance it gives the bike.
Old April 9th, 2019, 08:16 AM   #29
Raddad70
Yeah, the rear end is an inch off the ground because of the center stand. I Could lower the forks in the triple trees but only a little - nothing crazy. That is if I go up one the tire/ rim size - to keep a more aggressive stance.
Old May 11th, 2019, 07:22 PM   #30
Raddad70
It basically went from winter to spring in 3 days here. The grass is now 2 ft tall and allergies are thru the roof. Here are a few things I’ve been working on. I got front and rear fenders cut out and bent into shape. Added a white led underneath the tail light for the license plate and a blue one in the center - a wink to the old choppers. I’m making a luggage rack out of plate aluminum it will have cutouts for bungees - Ha, it kinda looks like the transformers symbol. I was thinking of naming this bike “Gromslayer” but now I think I will call it Warthog cause it’s ugly, small but chunky and it has skinny little wheels also the front fender looks like a snout.
Old May 13th, 2019, 06:36 PM   #31
Raddad70
Went from winter to spring in like 3 days the grass is 2 ft high and allergies are crazy bad but got a few things worked out. Cut and bent from and rear fenders. Was going to name this bike “Gromslayer” but now I think I will call it Warthog because it’s small, ugly, chunky with little wheels and the front fender looks like a snout, HA!
File Type: jpg 89FDEE42-EF12-4A29-AC61-6B2BF61CE8F5.jpg (120.1 KB, 7 views)
Old May 13th, 2019, 06:43 PM   #32
Raddad70
Making a small luggage rack out of plate aluminum - kinda looks like the transformers symbol
File Type: jpg 9E8D5C95-F8BD-42B1-9A2D-F217C3A1AE8D.jpg (125.0 KB, 9 views)
Old May 13th, 2019, 06:49 PM   #33
Raddad70
Rack
File Type: jpg 8EA90591-B9FE-4743-96EB-59DF7F35FD15.jpg (66.2 KB, 4 views)
Old May 14th, 2019, 06:26 PM   #34
Raddad70
I modded the tail light with 2 leds. 1 white underneath for the number plate and a blue 1 in the center. A nod to the custom bikes of old.
File Type: jpg 6AC90561-4CE3-47E0-85C2-EFD78C8838C9.jpg (101.8 KB, 4 views)
Old May 14th, 2019, 08:21 PM   #35
go Robot!!!
Old May 15th, 2019, 05:47 PM   #36
Raddad70
Original mufflers were in bad shape - this is where my reasoning is always skewed - aesthetics over function. So this is my attempt to make the cheapo mufflers that look cool (imho) kinda work. Step 1 cut old mufflers off pipe, step 2 pay this kid I know from church to weld new muffler adapters to pipe, step 3 stuff ss pot scrubbers and baffles in the cans, step 4 mount up - still working on it. Hmmm, I wonder how they will sound?
File Type: jpg 04F9E8B4-36AB-47F5-89A7-176C1D36FD8E.jpg (181.9 KB, 4 views)
File Type: jpg 5293DFD0-EA58-492E-B4D0-B42F1047297A.jpg (130.0 KB, 3 views)
Old May 15th, 2019, 05:51 PM   #37
Raddad70
Wink
Let kill som DB’s
File Type: jpg 5DF13253-139C-4B90-83D5-D1C9E6CFD996.jpg (88.4 KB, 2 views)
File Type: jpg 98104B0B-6CE3-45BA-8E93-E495C02D504D.jpg (160.4 KB, 1 views)
Old May 15th, 2019, 05:58 PM   #38
Raddad70
Tip - used a zip tie to attach springs then cut and reuse for all 4.
File Type: jpg AE803663-0982-43B8-81F1-A899D12E857F.jpg (95.0 KB, 1 views)
File Type: jpg B9072D86-40C5-4B0D-BB8F-DFF4E16BCA07.jpg (124.6 KB, 1 views)
Old May 15th, 2019, 06:01 PM   #39
Raddad70
Robot says “1001000011011” translation: Thanks!
Old May 15th, 2019, 06:17 PM   #40
Raddad70
Still need to make hangers. I like how the wheels are more open especially the rear. I like going smaller/ lighter when possible. I really don’t want to rejet and I don’t have a feel for how the stock bike performed or handled. I am keeping the air box and am using a UNI foam filter, shimmed the needles .06
File Type: jpg 097B6C8A-C588-489C-A565-8A344AFD36E9.jpg (105.6 KB, 3 views)
File Type: jpg 800ABC0A-1D79-4CC2-A006-92204ABB76D7.jpg (101.9 KB, 3 views)
Winter boredom project rubber side down 1986 - 2007 Ninja 250R Farkles 8 March 28th, 2018 04:22 PM
winter project almost complete justopelt 1986 - 2007 Ninja 250R Farkles 10 May 5th, 2014 02:00 AM
2012 Ninja 250r SE - Winter Project...Streetfighter Version. SuperAmp13 2008 - 2012 Ninja 250R Farkles 6 April 3rd, 2014 04:34 PM
2009 r6 winter project TnNinjaGirl The Ex-Ninjetters Lair 85 February 24th, 2014 12:45 PM
My Winter Project maxedpenny 2008 - 2012 Ninja 250R Farkles 51 March 11th, 2009 05:09 PM
