Old February 10th, 2019, 02:30 PM   #1
Webchar
Motorcycle(s): Ex250 ninja pre-gen
Unknown wiring
Hey does anybody know what these wires go to? I bought an older model 250 not 100 percent sure on the year yet and had no key. So I wired the ignition wires and can get everything to work except the starter button. Then I found these wires have been snipped. I think some of them touched and blew a fuse so I replaced the fuse and now I have no power to anything. Any help is appreciated. Thanks
File Type: jpg 53065FE3-4944-41A6-B452-49B69913ABED.jpg (69.5 KB, 33 views)
File Type: jpg 80DE58C6-F0DC-4185-B335-56C1B21CFF57.jpg (135.6 KB, 13 views)
Webchar is offline   Reply With Quote
Old February 10th, 2019, 11:03 PM   #2
Hi and welcome!
Your best bet is to track down wiring diagram for your model year. Look at VIN plate and look at stickies at top of this sub-forum for diagram. Then restore all wiring back to factory condition.
Ignition-switch wiring must be exactly stock. If it's blowing fuse, something is not connected like stock. Factory condition is required because of anti-theft features; will not work otherwise.
Also starter circuit has some safety-interloc conditions that must be met to start (neutral gear, clutch-squeezed, etc.).
So download wiring diagram, trace each and every wire from beginning to end on diagram and make sure wiring on bike matches. You'll find some non-factory conditions. And when you repair and convert back to factory state, fuses will stop blowing and bike will start! Good luck!
Old February 11th, 2019, 07:15 AM   #3
dodgerdad
dodgerdad's Avatar
Careful that the positive jumper cable clamp on the battery isn't grounding out on the frame. From the photo it looks pretty darn close.
Old February 11th, 2019, 07:18 AM   #4
Webchar
I’ve looked at wiring diagrams and can’t trace anything back to a harness with those exact colours. My ignition wiring is the old style without the resistor in it. It wasn’t the ignition wiring that blew the fuse it was the wiring harness in the pic. Thanks for the help
And lol I will move that jumper cable over a bit didn’t even realize
Old February 11th, 2019, 12:54 PM   #5
Those bare wires go to ignition-module:
Look at PDF diagram at end of this post:
https://www.ninjette.org/forums/showthread.php?t=35999
Look at lower-right of diagram for "ignition module" and every single one of those wires match up to your picture. Wire-colours typically change after they go through a connector. So note colour-change after it goes through connectors and fuse-box. Best bet if you find replacement connectors to repair your harness.
You'll also want to make the repair as good or better than factory, no crimp-connectors, no electrical tape. Solder and heat-shrink tubing only.
https://www.youtube.com/watch?v=Q9G9gaokqvM
Unknown road to unknown road Milsparro Ride Reports 7 August 31st, 2014 08:55 PM
Unknown hose jman511115 2008 - 2012 Ninja 250R Tech Talk 12 July 8th, 2012 05:08 PM
Unknown carb part dosfiddy 1986 - 2007 Ninja 250R Tech Talk 15 June 12th, 2012 10:10 PM
Unknown Bolt 08ninja250 2008 - 2012 Ninja 250R Tech Talk 4 August 19th, 2010 12:54 PM
[superbikeplanet.com] - Author Unknown Ninjette Newsbot Motorcycling News 0 September 16th, 2008 08:49 AM
