Old March 4th, 2019, 01:42 AM   #1
beakeyozz
Motorcycle(s): kawasaki 2006 GPX and 1990 ninja 250
2006 Gpx 1990 ninja project
HI all just a quick Question Frames and forks are they the same on both bikes l mean the part that goes into the fork leg are they the same diameter the 1990 is a import from japan they only made a twin disc set for that country the 2006 has only one disc lm aiming on putting the twin disc set up on the 2006 the problem is the top part of the fork leg has spot rust on it and the seals are stuffed now lm thinking of rebuilding the bottom leg with the 2006 top part as theres not a blemish on them actually l have 3 bikes its a scoot
Last futzed with by beakeyozz; March 4th, 2019 at 01:43 AM. Reason: why not scoots kool
beakeyozz is offline   Reply With Quote
Old March 5th, 2019, 01:11 PM   #2
Artruck
Motorcycle(s): 2007 ex250 (black), silver 2005 ex250 scrambler, 2003 ex250 donor bike, 2006 kymco people 250
I would invest in a set of digital calipers to measure each part to double check the fitment. They will pay for themselves real fast. Looking at the bikes, I would say, that they should fit if they are same diameter fork legs (I think they are) but you will need to replace the whole braking system for the front to be safe. The master cylinder for the barakes might have different flow characteristics to feed the twin calipers. And the fittings will all match up for sure.
Artruck is offline   Reply With Quote
Old March 7th, 2019, 02:52 AM   #3
beakeyozz
l will be useing the dual calipers marster cylinder afther reconditioning it and the connection that has the 2 lines comeing out from it to the calipers
[motorcyclistonline] - 2006 Suzuki DR-Z400 Project Bike Review Part 2 Ninjette Newsbot Motorcycling News 0 February 8th, 2019 04:30 AM
[motorcyclistonline] - 2006 Suzuki DR-Z400 Project Bike Ninjette Newsbot Motorcycling News 0 August 7th, 2018 03:32 AM
[motorcycle.com] - Church Of MO: 2006 Suzuki SV650S vs 2006 Kawasaki Ninja 650R Ninjette Newsbot Motorcycling News 0 January 24th, 2016 07:30 AM
2007 ninja fairing/ plastics on 1992 GPX Thannny 1986 - 2007 Ninja 250R Tech Talk 1 July 17th, 2013 12:46 AM
