Notices
Old March 7th, 2019, 07:25 AM   #1
dodgerdad
dodgerdad's Avatar
Keeping centerstand w/aftermarket exhaust
I'm in the process of fitting some aftermarket exhaust cans and would appreciate any tips on how to deal with preventing the centerstand from contacting the chain now that it won't get stopped by the original muffler.
I've searched around here and haven't found any way to deal with this. I plan to get under the bike today to try to deal with this specific item but could use some ideas. Just need a simple and safe way to limit the travel and avoid chain contact.
Losing the centerstand is not an option for me so let's avoid that discussion.
Thanks!
Old March 7th, 2019, 03:50 PM   #2
Ceeloo Yello
Motorcycle(s): 250
dodgerdad try checking out this post:
https://faq.ninja250.org/wiki/Muzzy_Exhaust
Old March 7th, 2019, 04:35 PM   #3
dodgerdad
dodgerdad's Avatar
Thanks for the link. I went through the bike this morning and found that the only position where I can tuck the stand away without it looking awful will clear the bottom of the chain horizontally but is too close laterally.
The chain tends to move up and down with tension and slack but it can easily move laterally (a tiny bit) under a jerky acceleration/deceleration. In order to clear the chain laterally the stand needs to be pretty low resulting in a bizarre appearance.
I'm a little bummed but intend to remove it and install it temporarily when working on the bike (as suggested in the link). I've used rear/front stands in the past and they're just not as convenient as a centerstand, they ain't free and they add to my garage clutter.
In the photo you can see what little tolerance there would be if I kept the stand at a level that wouldn't make it an eyesore.
Old March 7th, 2019, 05:54 PM   #4
Snake
Snake's Avatar
Question: Will the center stand be used for everyday parking situations or are you wanting it for maintenance?
Old March 7th, 2019, 06:00 PM   #5
dodgerdad
dodgerdad's Avatar
Strictly maintenance.
Old March 7th, 2019, 06:10 PM   #6
Ceeloo Yello
Motorcycle(s): 250
Would think that if you keeping it duals the cans would hide the center stand.
Old March 7th, 2019, 06:17 PM   #7
dodgerdad
dodgerdad's Avatar
Yeah, the stock set-up hid the stand quite well, but the new cans are smaller and mount much higher.
I'll just install the stand for maintenance/repairs. I guess it's not a huge deal, it was just so convenient having it there all the time especially now that I've begun my mods. Oh well.
Old March 7th, 2019, 06:31 PM   #8
Snake
Snake's Avatar
I installed an Area P 2 into 1 exhaust and install the center stand just for maintenance purposes. Easy on / Easy off.
Old March 7th, 2019, 06:33 PM   #9
dodgerdad
dodgerdad's Avatar
Yeah, seems like a reasonable solution.
Old March 7th, 2019, 07:13 PM   #10
Ceeloo Yello
Motorcycle(s): 250
I got a single yoshimura exhaust and sadly I just let the center stand hang
Old March 7th, 2019, 07:49 PM   #11
I attempted the dual center stand on/off thing, then got some threaded bungs welded onto my swingarm for spool lifts instead.
Old March 7th, 2019, 08:19 PM   #12
dodgerdad
dodgerdad's Avatar
Mine won't hang down, it's firmly up against the bottom of the chain.
Old March 7th, 2019, 08:21 PM   #13
dodgerdad
dodgerdad's Avatar
I can see it becoming a bit of a hassle but I think I'm cheap enough to deal with it
Old March 8th, 2019, 09:47 AM   #14
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
What I do is just slip 3/8" bolts in the centerstand holes instead of threading the stock bolts in when I need to work on the bike.
Old March 8th, 2019, 09:48 AM   #15
dodgerdad
dodgerdad's Avatar
It won't wobble around?
Old March 8th, 2019, 09:52 AM   #16
Z1R rider
Z1R rider's Avatar
Not that I've ever noticed, you do lose a fraction of an inch rise height because the holes are bigger than the bolts
Old March 8th, 2019, 09:54 AM   #17
dodgerdad
dodgerdad's Avatar
Thumbs up
Old March 8th, 2019, 10:08 AM   #18
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Could you attach a spacer to the center-stand so it will hang where it belongs and not smack the chain?
Old March 8th, 2019, 10:41 AM   #19
Yup, extend bumper so it contacts smaller muffler placing centrestand at original location
Old March 8th, 2019, 11:59 AM   #20
dodgerdad
dodgerdad's Avatar
With how high the new can is mounted, the bumper doesn't touch anything anymore.
It's cool, I'll just reinstall it for maintenance.
Thanks for the suggestions!
Old March 9th, 2019, 05:20 AM   #21
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
glad you found a work around. you came full circle and members gave ya excellent ideas. nice
"trying not to get old"
Old March 9th, 2019, 02:53 PM   #22
Another idea is to weld little post under muffler to contact bumper of centrestand.
Old March 9th, 2019, 03:39 PM   #23
Z1R rider
Z1R rider's Avatar
less weight, more clearance!
Old March 9th, 2019, 04:13 PM   #24
dodgerdad
dodgerdad's Avatar
Yeah, the less weight thing is getting interesting as my build progresses.
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 SON1C 2013 - 2017 Ninja 300 Tech Talk 4 August 14th, 2014 05:45 PM
It IS possible to shorten the stock exhaust, while keeping the same sound. gilmorec61 2008 - 2012 Ninja 250R Tech Talk 22 April 24th, 2012 07:12 AM
removing snorkel keeping stock exhaust on james250ninja 2008 - 2012 Ninja 250R Tech Talk 19 September 2nd, 2011 06:48 AM
aftermarket exhaust? kenji_808 2008 - 2012 Ninja 250R Tech Talk 1 May 15th, 2010 04:25 PM
Centerstand all of a sudden contacting the exhaust? Grn99Kawi 1986 - 2007 Ninja 250R Tech Talk 6 September 7th, 2009 02:32 PM
