View Poll Results: Which pod filter do you use?
BMC 1 3.85%
EMGO 1 3.85%
K&N 20 76.92%
Uni 3 11.54%
Other 1 3.85%
Voters: 26. You may not vote on this poll
Old November 12th, 2009, 10:48 PM   #1
null0
Motorcycle(s): Ninja 250 F17
I'm going to be installing pod filters and re-jetting but I really haven't seen any decent feedback on any of the 4 brands . Ninja250.org has a little bit of information about fitment but there's really nothing else. Do design (conical or straight) or length (4",5",6") have any effect?
null0 is offline   Reply With Quote
Old November 13th, 2009, 05:10 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I use the K&N 0990 filter pod .It is a single filter with two openings. It is made for the Triumph Bonneville. It fits perfect.
Old November 13th, 2009, 09:21 AM   #3
greg737
Motorcycle(s): -
Same here.
I'm using the R-0990 also. Be prepared for a pretty substantial increase in intake noise in the upper half of the rev range.
Old November 13th, 2009, 10:18 AM   #4
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Here is a link on the pod issue that might give you some more food for thought.
http://www.ninjette.org/forums/showt...highlight=pods
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old November 13th, 2009, 10:37 AM   #5
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
I'm using uni-pods, because that's what came with my Area-P exhaust. I may change when I need new filters, but right now, they're working fine. I have no idea which model number they are though, but you could email or PM Kerry Bryant, the owner of Area-P. They're awesome people and I'm sure they would love to tell you which part they use for this.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old November 13th, 2009, 01:57 PM   #6
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
Talking
K&N RU-1822 for pre gen's Amazon...60 bucks
lasting forever..priceless
QTRltrPWR
nate-bama is offline   Reply With Quote
Old November 13th, 2009, 02:12 PM   #7
islanderman7
The Sexy Filipino
islanderman7's Avatar
Motorcycle(s): Ninja 250R 2008 (da black one)
Man if I had known about these, it would have made my life easier. I have the K&N 0990 filter pod and it was hard to put on because once I put one side on, the other side would come off. It was a headache.
Area P CF Standard,Airbox Removed,K&N R-0990,Factory Pro Jet Kit 3.0, Zero Gravity DB
I'm not riding too fast... I'm flying too low.
islanderman7 is offline   Reply With Quote
Old November 18th, 2009, 11:38 AM   #8
coffeecandy
Motorcycle(s): 2002 Ninja 250
WD-40 or some kind of lube works pretty well to slip these on.
http://www.amazon.com/R-0990-Univers...8569417&sr=8-2
R-0990 at amazon is 33 plus some change and free shipping to add.
you will need to Jet you bike if you do this per wikifaq. which can be found here
http://faq.ninja250.org/wiki/Rejetti...ng_pod_filters
Ronayers.com sells these jets for 7.11 each plus shipping and handling.
Bay Area Event Coming Up:
June 2, 2012 Mike's Newb Group Ride
coffeecandy is offline   Reply With Quote
Old November 18th, 2009, 02:16 PM   #9
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
I'm running 108 mains now ..110 worked well also but bogged in sixth gear at high rpm's
QTRltrPWR
Old November 22nd, 2009, 11:30 PM   #10
null0
Here's a small factoid now that I'm about halfway through the install. The Uni Pods (6" Dual Stage) weigh 60g each. The part of the airbox that I removed weighs 880g. Weight savings of 1.45 pounds so far.
Old November 23rd, 2009, 01:57 PM   #11
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
QTRltrPWR
Old November 23rd, 2009, 07:29 PM   #12
null0
The hardest part of the whole operation was getting that damn airbox out. I spent 2 hours trying to get it out intact then just gave up and took it out in 3 pieces. On the plus side you can cut the battery box off with a Dremel and bolt it back in.
What's the deal with the hose running from the airbox to the CA emissions, should I plug it or leave it exposed?
Old November 23rd, 2009, 09:05 PM   #13
Snake
Snake's Avatar
If it goes to the carbs then it needs a filter on the open end.
Old December 1st, 2009, 12:36 PM   #14
dbotos
dbotos's Avatar
Motorcycle(s): 2001 EX250
Same here. I saw no point in getting the ones with the chrome end caps since they probably weigh more and no one would see them...
dbotos is offline   Reply With Quote
Pod or replacement filter vmax 2008 - 2012 Ninja 250R Tech Talk 4 August 4th, 2014 09:30 PM
My pod filter got wet subxero 2008 - 2012 Ninja 250R Tech Talk 53 June 16th, 2013 07:55 AM
K&N Pod Filter Peanut_EOD 2013 - 2017 Ninja 300 Tech Talk 23 November 15th, 2012 08:35 PM
POD filter question lstat 2008 - 2012 Ninja 250R Tech Talk 13 August 28th, 2012 07:42 AM
K&N Filter or Pod jonthechron 2008 - 2012 Ninja 250R Tech Talk 6 February 17th, 2010 12:07 PM
