Old March 21st, 2019, 05:29 PM   #1
Vorifey
Motorcycle(s): 2006 ninja 250
Clutch issues
To;dr: clutch suddenly has no tension
Hello,
While riding home from work I went to downshift and pulled the clutch in with no resistance. I was unable to shift down and managed to pull off to the side and stalled. I crudely managed to get it into first but it would stall without any revs.
I can pull the clutch in and it doesn’t “spring” back out. It just kinda sits there. I can easily push it out.
Luckily I was close to a bike shop— managed to get there in first gear, told them what happened, they looked at it and came back out telling me it was a simple cable adjustment. They said “something like that should’ve been adjusted last time you were here” (I brought the bike in a few months prior) and proceeded in charging me $20. I was just happy it was fixed.
I left and as soon as I got a few blocks away, same thing happened. I managed to drift and force downshift to first and stalled out on the side of the road. I was close to home and walked it the rest of the way.
I’m not sure what to do an am not mechanically inclined. The cable from what I can tell is fine? I don’t know what to do. Any help is appreciated.
Thank you.
File Type: jpg A61D1878-9DEE-4869-8F79-E9630E28946C.jpg (75.1 KB, 8 views)
File Type: jpg 1B4447C2-5637-4373-8861-561C8D487152.jpg (66.4 KB, 7 views)
File Type: jpg 3FF30A3A-D132-40B1-B1A6-C23F61FEE9AC.jpg (96.7 KB, 14 views)
File Type: mov 9087857B-C7EF-49FB-A228-D1A42B446E98.MOV (7.34 MB, 1 views)
Vorifey is offline   Reply With Quote
Old March 22nd, 2019, 04:35 AM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Most likely the cable is broken, while working the lever watch the other end, (on the engine's clutch cover). If the cable is indeed broken, I'd be looking for a different shop.
PS; Welcome to the board
Old March 22nd, 2019, 06:23 AM   #3
Maybe the cable broke most of its strands and the few remaining ones stretched, so it wasn't obvious it had a problem. The mechanic then adjusted it and it worked fine. It might be better to go back to the same shop and get them to replace the cable. A polite suggestion of putting the $20 already spent toward the new one might be agreeable to the shop.
Old March 24th, 2019, 05:14 PM   #4
Something may be wrong with clutch:
1. Cable-adjuster at lever is fully extended
2. Cable-adjuster at engine is fully extended
3. Clutch-arm is pulled in disengaged position
This might be in response to broken cable stretched out with only couple strands remaining? If the clutch-arm is in that position without any cable pulling on it, there's something wrong inside, perhaps clutch springs broken or cam on arm is broken. Normal position for clutch arm is 90-degrees towards inside.
Clutch Issues dragono 1986 - 2007 Ninja 250R Tech Talk 8 January 17th, 2015 05:42 PM
Help help! :( (clutch cable issues) Stillblunted 2008 - 2012 Ninja 250R Tech Talk 9 January 24th, 2012 09:20 PM
Clutch Issues n4mwd 1986 - 2007 Ninja 250R Tech Talk 25 October 20th, 2010 08:25 AM
Clutch Engagement Issues HELP! peter330 2008 - 2012 Ninja 250R Tech Talk 30 June 2nd, 2010 09:19 AM
250 clutch issues 01jackedZ 1986 - 2007 Ninja 250R Tech Talk 27 September 13th, 2009 08:51 PM
