Old February 16th, 2010, 09:48 PM   #1
jonthechron
Motorcycle(s): magHitVE
K&N Filter or Pod
K&N KA-2508 or R-0990?
Advantages and disadvantages? I know I could grab the pod for about 25-50% less, but does this price come with disadvantages? My bike is already disassembled, so removing the air box would not be a problem. I have a stock exhaust and stock needles. Eventually will get an aftermarket exhaust, but not for a while.
Old February 16th, 2010, 10:29 PM   #2
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
The pod will let the most air in. (like having nothing on there basically)
Rejet and needle shim will be required no matter what going to pod. Expect to need a jet kit designed for a pod filter. Otherwise you won't get above 5-8k. lol
"Ask me how I know"
I used the factory pro 3.0 jet kit as per kkim's link.
IMO, the stock airbox is a PITA and the K&N r-0990 looks sweet with no runners while being easier to work on.
I dunno which has a better performance though.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old February 16th, 2010, 10:34 PM   #3
jonthechron
Thanks for your response, but after jetting and adding the pod will I notice a difference using the stock exhaust?
Old February 16th, 2010, 10:36 PM   #4
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
You will notice a major difference. Like night and day. Best $130 you'll put into it, but plan on a full exh system to get good flow and no melted honeycombs.
You'll probably need $10-$20 in vacuum fittings and caps etc to plug off some lines too.
LMFAO!
Weaksauce
Old February 16th, 2010, 10:48 PM   #5
jonthechron
Alright thanks! I'll bump this mod up in priority, I was going to change to SS brake lines first but this will be on top of the list. Keeping an eye on Yoshimura Full exhaust, but I have only heard it on youtube... I have yet to hear any of the aftermarket exhausts up close.
Old February 16th, 2010, 10:54 PM   #6
you'll lose some low end power if you remove the airbox, but it will breathe better at higher revs. you will notice a difference even if you keep the stock exhaust.
I would recommend keeping the airbox for now and get the panel replacement filter, unless you're planning on getting a full exhaust in the near future.
FYI, removing the airbox is a royal PITA.
Old February 17th, 2010, 12:07 PM   #7
2WheelGuy
2WheelGuy's Avatar
If you have to ask keep the airbox. Re-jetting for pod filters is a PITA. Pod filters are noisy. Getting the airbox out is a PITA.
On the plus side pod filters can make a little more power (if jetted correctly). Removing the carbs to change jets is much easier without the airbox.
AFM #278
K&N Pod filter mwirrick Ninjettes At Speed 13 January 10th, 2014 05:57 PM
BNIB K&N pod filter cuong-nutz Motorcycle-related 5 September 17th, 2013 12:27 PM
K&N Pod Filter Peanut_EOD 2013 - 2017 Ninja 300 Tech Talk 23 November 15th, 2012 08:35 PM
K&N Pod Filter with Stock Exhaust? krolinked 2008 - 2012 Ninja 250R Tech Talk 3 August 6th, 2012 07:47 PM
guys w/pod filter &or slip on cuz 2008 - 2012 Ninja 250R Tech Talk 9 September 6th, 2011 05:24 AM
