Old June 12th, 2012, 09:09 PM   #1
Tiane
Motorcycle(s): NINJA300
Question Adding a rivet master link to the stock chain ???
The stock 43 rear sprocket on the Jap model doesn't give me the extra push I need when coming out of the turns in the local track, specially going up the hill. The track is small and max speed is about 70 miles.
I tried to install a 47 rear sprocket but the chain is too short, just a couple mm
I had never considered adding a link to a stock chain before because the chain becomes weak, and it won't last... however, I don't think I'll have an issue with the stock 250's DID VP2 chain if I add a DID VX2 rivet link
What do you guys think?
Tiane is offline   Reply With Quote
Old June 13th, 2012, 12:58 AM   #2
Stock EX250 has a EK SRO chain. I thought that only Australia had less teeth on the rear sprocket (according to the service manual). The service manual says that the EK SRO master link is fine if you break a link and need to reconnect, but it can't ADD a link because there is no way to get another inner link. Master links are always outer links used to connect two inner links. What I mean by "outer" and "inner" link is that the plates alternately overlap in this chain design. Some links have plates over the next links and the next link has plates under it and under the next. I have seen chains that have all identical links where they are wider on one end and smaller on the other to fit inside the next links larger end.
RK 520XSO Chain Clip vs Rivet Master Link agentbad 1986 - 2007 Ninja 250R Tech Talk 5 May 15th, 2014 07:35 PM
How many links do I reduce my chain if adding 15t front sprocket, stock rear? novak2k9 2008 - 2012 Ninja 250R Tech Talk 2 February 11th, 2013 02:25 AM
More chain trouble: 2-month old chain, O-Ring failure at master link. :( What now? CZroe 2008 - 2012 Ninja 250R Tech Talk 56 July 7th, 2012 05:42 PM
Request: Silver chain, gold master link. Mountain Dew Pictures 3 January 25th, 2012 08:24 AM
FS: RK XSO 520 gold rivet master link choneofakind Motorcycle-related 3 January 18th, 2012 05:48 PM
