Old May 21st, 2014, 08:34 PM   #1
NinjaNoob23
Motorcycle(s): 2011 Ninja 250
Front Fork Noise and Wobble
Ok, here's the deal.. My 2011 runs great, love it, couldn't be happier. However there is a small leak in the front left fork. The mechanic said it wasn't a big deal and not to worry about it. Having said that, when I hit a bump the front end makes a pop noise and the bars shake a little. Under semi heavy breaking the front end shakes a little. I'm wondering what may be the issue here? There are no problems when riding, only the loud pop and wobble with bump and wobble with breaking.
Any Ideas?
Side note: the wobble/shake isn't from left to right, it's front to back.
If that makes a difference.
Last futzed with by NinjaNoob23; May 21st, 2014 at 10:06 PM.
NinjaNoob23 is offline   Reply With Quote
Old May 21st, 2014, 09:21 PM   #2
cuong-nutz
cuong-nutz's Avatar
Could be that your steering stem bearings are loose. You'll need to remove your top triple clamp and get a spanner wrench or a flat head screwdriver and hammer to tighten it up if that's the case.
HalfFast Racing Team
Old May 22nd, 2014, 04:18 PM   #3
NinjaNoob23
I'll have to check that out. If that is the problem, is it urgent to fix? I'm thinking about going on a trip this weekend. It's 2.5 hours one way….
Could the noise be from low oil in the shock itself?
Old May 22nd, 2014, 05:02 PM   #4
cuong-nutz
cuong-nutz's Avatar
Yes it is an urgent fix. If you hit a bad bump at speed you might get a tank slapper. You don't wan to chance it.
Old May 22nd, 2014, 07:19 PM   #5
NinjaNoob23
Ok thanks, I'll take the Jeep for the trip and check it out when I get back. Thanks for the advice.
Old May 23rd, 2014, 04:05 PM   #6
NinjaNoob23
I took it all apart last night and found the problem. The bearing nut was a little loose but not enough to cause a problem. The leak in the fork seal has gotten a lot worse since the last time I checked it (less than a week?). Sooo now I get the pleasure of tearing the front forks apart to change the seals
Here is a good DIY write up on seal replacement.
https://www.ninjette.org/forums/showthread.php?t=23200
Last futzed with by NinjaNoob23; May 23rd, 2014 at 06:02 PM.
Old May 24th, 2014, 04:48 PM   #7
Lemonfresh
Motorcycle(s): '10 Kawasaki Ninja 250ARRRR (Sold), '13 Kawasaki Ninja 300 (Crashed), '07 Triumph Daytona 675
You could try this out first. If its just dirt trapped between the seal and the tube, this would work. Or you get clever and make your own.
https://www.motionpro.com/motorcycle/partno/08-0395/
Lemonfresh is offline   Reply With Quote
Old May 24th, 2014, 05:34 PM   #8
........The leak in the fork seal has gotten a lot worse since the last time I checked it (less than a week?).........
Consider this:
http://faq.ninja250.org/wiki/Caring_for_your_forks
Clean and lubricate those stem bearings.
The top nut acts like a counter-nut to fix the position of the top track.
http://faq.ninja250.org/wiki/Steerin...ng_replacement
Old May 24th, 2014, 06:58 PM   #9
NinjaNoob23
Originally Posted by Motofool View Post
Consider this:
Thank you, that's the best/most relevant information you could have given me.
Old May 24th, 2014, 07:37 PM   #10
You are welcome
Front end wobble or bounce... ? MrSavvy 2008 - 2012 Ninja 250R Tech Talk 11 September 21st, 2014 12:53 PM
front end wobble no hands on bars EMSRacer07 1986 - 2007 Ninja 250R Tech Talk 5 March 22nd, 2014 08:40 PM
Front sprocket noise ChaoSS 2008 - 2012 Ninja 250R Tech Talk 9 November 30th, 2012 04:42 AM
Noise from front wheel sherbear 2008 - 2012 Ninja 250R Tech Talk 3 May 19th, 2009 09:48 PM
Help - squeaking noise coming from front wheel / fork? muffinman 2008 - 2012 Ninja 250R Tech Talk 5 March 17th, 2009 05:11 PM
