Old December 20th, 2011, 09:56 PM   #1
cuong-nutz
cuong-nutz's Avatar
Fix for front wheel squeak noise/Front wheel removal
If you are getting an odd noise at low speed that's repetitive as the front wheel turns most likely it's your wheel hub seals. It also could be because the seal was not installed flush and or was damaged during wheel removal/installation. Over time dirt and grime will accumulate around the seal and eventually get into it. KKim's DIY tire change and balance touches on this topic.
Tools needed:
Pliers
Torque wrench
12mm wrench/socket
17mm wrench/socket
20mm wrench/socket
front triple stand (or at least a rear stand and jack)
rear stand
Materials:
rags/paper towels
wheel bearing grease
Support your bike up with both front and rear stands.
Remove the front brake caliper held on by 2 12mm bolts and move it to the side.
Disconnect the speedometer cable from wheel hub. With some pliers, just unscrew.
Remove cotter pin and castle nut.
Carefully remove the axle bolt while supporting the wheel. Lower wheel and remove. The wheel spacer on the right side will fall out in most cases.
Clean the wheel spacer, speedometer hub seal, and wheel seals of old grease and debris.
Inspect wheel spacer for nicks and scratches where the seal surface contacts. If there are any, lightly polish it smooth. If any of the seals are noticeably damaged, replace them or else water and debris will enter the wheel hub and damage the wheel bearings. I found out that one of my seals wasn't installed flush and had some slight tears on the lip but didn't need to be replaced. Install new grease onto seals, axle bolt and wheel spacer.
Here you can kind of see that the seal wasn't installed flush.
Reinstall wheel spacer and speedometer hub back on to wheel. Carefully lift wheel inbetween forks making sure that the speedometer gear housing stop is aligned with the fork. If it's not aligned, the housing will spin and damage your speedometer cable and housing.
You can see the slot here will it will line up with the fork:
Slide axle bolt through wheel.
Torque castle nut to 65 ft/lb.
Install cotter pin.
Put some grease on the speedometer cable end and put it back into the housing. Spin the wheel so the cable end will fit into the gear slot so you can screw it back in.
Reinstall brake caliper. Torque bolts to 18 ft/lb.
Stay squeak free
HalfFast Racing Team
Last futzed with by cuong-nutz; December 20th, 2011 at 11:03 PM.
Old December 20th, 2011, 10:00 PM   #2
Nice! I linked it from the wiki article on fixing the squeak:
http://www.ninjette.org/wiki/My_Bike...ont_Tire/wheel
Old December 20th, 2011, 10:41 PM   #3
cuong-nutz
cuong-nutz's Avatar
More how-to's to come...Too much free time until I find another job.
Old December 21st, 2011, 01:01 AM   #4
Flying Pig
Resident Lurker
Flying Pig's Avatar
Motorcycle(s): R6, Strom, 250R, CH80 Elite
Funny. I noticed that on my diagnostic run. It would come at slower speeds, but not at faster. I figured I'd just remove the front wheel and regrease everything I could, glad to know it's a common problem and not just specific to the ninjette that I picked up
When was the last time you checked your tire pressure?
Flying Pig is offline   Reply With Quote
Old February 14th, 2012, 06:37 PM   #5
Megamike
Motorcycle(s): 2011 250R
Sorry to revive an old thread/issue, i just wanted to post my experience with this in case its useful for others.
i had a brand new 2011 ninja, squeak starting coming in at about 700mi
1st attempt to fix
- Had a mechanic remove front wheel, grease everything, he said yeah it seemed the wheel was overly tight from factory as mentioned in other threads etc. Squeak came back in about 100mi with a vengeance
2nd attempt to fix
- squeak got so bad you could hear it a block away, (louder than the engine), bike was embarrassing/no fun to ride anymore. took it back to dealer to check out.
they fixed it and only charged 1/2 hour for labor, the below are their notes on it -
"Test ride did hear some noise sounded like brake pad having contact with rotor. Removed wheel Lubed/Greased dust seals, checked bearings all seem ok, removed caliper and no noise present, installed calipers and noise was present, the noise is break pad making contact with rotor, brake pads will break in with time."
so it seems like it was a brake issue. My squeak has completely gone (fingers crossed it stays that way)
After reading a lot of threads on this, it seems like this happens on new bikes and is not something that will just "go away" with break in of the brake pads. My squeak gradually got worse and worse until i couldn't take it
anymore....
So if there are any of you out there still greasing and regreasing with wd-40 etc, maybe checking out and/or adjusting the brake calipers might help.
Megamike is offline   Reply With Quote
Old February 16th, 2012, 03:23 PM   #6
GlassAnkles
GlassAnkles's Avatar
Motorcycle(s): 02 zx-12r, 13 zx-10r abs
glad you bumped this thread, i was wondering the hell that noise was coming from my 2012
GlassAnkles is offline   Reply With Quote
Old February 16th, 2012, 03:32 PM   #7
NDspd
1/4 English, 3/4 Kick Ass
NDspd's Avatar
Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold)
I'm getting my tires replaced, do you think I could ask them to grease up everything?
Would printing this DIY thing out and showing them would help me fix my issue?
I've talked to them before about it, and they just say it's the brakes. I'm fluent enough with motor vehicles to know it is not the brakes. Like I originally thought, it was something dealing with the bearings...but no, they didn't want to listen.
Thanks for bumping up this thread!!!
NDspd is offline   Reply With Quote
Old February 16th, 2012, 04:17 PM   #8
Megamike
I think in your case, you might just want to try another mechanic or a larger motorcycle dealer that might have more mechanics to look at your bike. I think the greasing helps but it really just covers up the brake/caliper issue a little bit.
I'm not sure but i'm assuming when my bike was in the shop they were able to mount my bike on a stand and spin the wheels to test for the squeak with the caliper's on and off. It doesn't sound safe/realistic for them to take it for a ride without the calipers on =D
i'm no mechanic but i already tried the greasing thing with my regular guy and it didn't work. You shouldn't have to grease that stuff as normal maintenance imo, there had to be some cause of it. Maybe you can just have your brakes and calipers checked anyways? seems like in my case the calipers needed adjustment or something.
Old January 12th, 2013, 08:47 AM   #9
Rob250
Motorcycle(s): 2012 Black & yellow Ninja 250
Awesom,
Had my 2012 Ninja for 5 months started hearing this sqeek. Going to check this as its most likely the issue. Very cool Great how to!
Rob250 is offline   Reply With Quote
Old April 1st, 2013, 05:48 PM   #10
hamm
hamm's Avatar
Motorcycle(s): Ninja 250R 09
Just a heads up to anybody reading this, I followed this guide and used wheel bearing grease to lubricate the wheel spacer which fixed the squeak on my Ninja.
Thanks to the OP
ham
www.youtube.com/user/tastyhamsandwhich | motovlogger
hamm is offline   Reply With Quote
Old April 1st, 2013, 08:09 PM   #11
Old April 23rd, 2014, 12:19 PM   #12
kennetht
kennetht's Avatar
all speedo hubs for 2008-2014 ninjas are identical correct? my bike is 2009, and i need to replace it as it is broken.
looking to replace my 2009 hub with this hub from a brand new 2012 ninja 250
http://www.ebay.com/itm/2012-Kawasak...p=mtr#viTabs_0
this will work fine correct?
kennetht is offline   Reply With Quote
Old April 23rd, 2014, 12:24 PM   #13
2008-2012 are identical. 2013 will be different.
Old April 23rd, 2014, 12:25 PM   #14
kennetht
kennetht's Avatar
ok so its only 2008-2012 that are identical.
perfect, thank you. going to purchase now.
Whistling Noise from front wheel? BlackNinja8 2008 - 2012 Ninja 250R Tech Talk 3 March 18th, 2012 08:35 PM
Front Wheel Squeak - Solved klewi 2008 - 2012 Ninja 250R Tech Talk 8 May 29th, 2011 01:50 PM
Whine/squeak from front wheel GeneJunkie 2008 - 2012 Ninja 250R Tech Talk 14 January 10th, 2011 03:16 PM
Ticking noise on front wheel? Betlog 2008 - 2012 Ninja 250R Tech Talk 10 July 11th, 2010 11:14 PM
Noise from front wheel sherbear 2008 - 2012 Ninja 250R Tech Talk 3 May 19th, 2009 09:48 PM
