Old April 5th, 2012, 09:36 PM   #1
Armo55
Armo55's Avatar
Motorcycle(s): Kawasaki Ninja EX250 2010
Today's The Day...
Alright, ima Shim my needles on my ninja first thing in the morning.
I have a DanMoto Slip on and the power loss from it is just devastating.. I got #4 washers from Radio Shack and an Offset Screw Driver.
I think ima start with 2 washers for each needle.
Any Advice?
Armo55 is offline   Reply With Quote
Old April 5th, 2012, 09:40 PM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Get a better avatar
AFM #676
Supersports are for n00bs
Old April 5th, 2012, 09:42 PM   #3
Armo55
Armo55's Avatar
Unnecessary Advice ^
Old April 5th, 2012, 09:44 PM   #4
cuong-nutz
cuong-nutz's Avatar
The offset screwdriver will not help much and you may end up boogering the head of the screw. I highly recommend you replace the screws with allen bolts.
HalfFast Racing Team
Old April 5th, 2012, 09:46 PM   #5
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Jiggles is in the hospital and high on pain killers and disappointment. We must forgive him.
As for tips... be very careful not to damage your diaphragms, otherwise it is pretty straight forward.
Old April 5th, 2012, 09:49 PM   #6
Jiggles
Jiggles's Avatar
MOTM - Apr '13
you know what happened before I crashed my 250? I shimmed the needles.
Prepare to get an r6 my man!
AFM #676
Old April 5th, 2012, 11:36 PM   #7
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
Buy cap socket screws (ie: allen head's), buy a philips dry-wall bit.
Work slowly and carefully. Attempt to not strip the heads. If you do, use a vice grip and wrestle those suckers our. After successfully shimming, replace all the screws and live happily ever after
Last futzed with by MikeBudd; April 6th, 2012 at 09:51 AM.
MikeBudd is offline   Reply With Quote
Old April 6th, 2012, 08:07 AM   #8
Armo55
Armo55's Avatar
I stripped ONE screw, how do i get it out??
Old April 6th, 2012, 08:09 AM   #9
zzrguy
zzrguy's Avatar
Motorcycle(s): 2002 ZZR 250
Exclamation
vice grips are your best friend
zzrguy is offline   Reply With Quote
Old April 6th, 2012, 08:42 AM   #10
cuong-nutz
cuong-nutz's Avatar
Vice grips or you can do like I did and dremel a slot for a flat head screwdriver.
Old April 6th, 2012, 09:07 AM   #11
zzrguy
zzrguy's Avatar
also for got to add go pick some of these up
http://www.fastenal.com/web/products...S2530014A20000
Old April 6th, 2012, 09:24 AM   #12
Armo55
Armo55's Avatar
Guys, i cant do this... this screw will NOT budge.... i did vice grips and everything..
Old April 6th, 2012, 09:51 AM   #13
MikeBudd
MikeBudd's Avatar
Really? Even my tightest screws came out with a heavy-duty pair of vice-grips.
Old April 6th, 2012, 10:38 AM   #14
cuong-nutz
cuong-nutz's Avatar
post a picture of how it looks. An impact screwdriver may work if you have room for it
Place it on the screw and wack the end with a hammer to budge it loose.
Old April 6th, 2012, 12:04 PM   #15
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
I had to dremel a slot in one of mine and use a flat head.
Old April 6th, 2012, 12:29 PM   #16
greg737
Motorcycle(s): -
come on guys... is nobody going to tell him that the screws on the carbs are Japanese Industrial Standard (JIS) screws, not regular old Amer'can style Phillips?
Okay, I will... The screws on your carbs are JIS. They might look like regular old Phillips head screws but if you try to work on them with Phillips head screwdrivers you will strip them out. The profile of the "X" in the head is subtly different.
What @MikeBudd was trying to tell you is that the profile of the small size of the standard (Home Depot) dry-wall driver bit is the same as a JIS screwdriver. He was saying that you can use that to work on the carbs. Or, after you've struggled with a Phillips head screwdriver to get all the screws out, destroying them in the process, you can then go out and buy some good stainless-steel allen head screws. Your choice.
Old April 6th, 2012, 12:32 PM   #17
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I told you you need to change your avatar
AFM #676
Old April 6th, 2012, 12:48 PM   #18
zzrguy
zzrguy's Avatar
Haha lol yeah they are jis but you can get them out with normal american style if you put it in the hole and wack it with a hammer. :P honestly i dont know how you can not get it out with vice grips. try harder.
Old April 6th, 2012, 12:50 PM   #19
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
All excellent and all true.
And all too late, sadly. He's already stripped the screw.
armo55, you have my sympathies and I wish you luck in fixing the problem. Having said that, search and homework is your friend.... the JIS and drywall bit info has been covered extensively in the past. Now you know how important finding out EVERYTHING about what you're about to do can be. Learn from this experience.
Prepare, prepare, prepare, measure, prepare some more, measure again, triple-check and THEN work.
This beats kind-of sort-of understanding what you're doing, going to work, making a costly mistake, trying desperately to (maybe) fix the damage and finally finding out what you should have done in the first place.
FWIW for anyone wanting to work on the carbs without suffering a "DAMMIT" moment:
It is MUCH MUCH easier in the long run to remove them from the bike. You are less likely to bugger them. The pain and hassle are worth it IMHO. It's what I did and the actual carb work was 100 percent trivial as a result.
Old April 6th, 2012, 02:20 PM   #20
cuong-nutz
cuong-nutz's Avatar
I figured it was safe to say that he already knew he needed the JIS bits if he read that far to where he got an offset screwdriver and the necessary washers since in all the DIY threads mention it.
Old April 6th, 2012, 05:11 PM   #21
Armo55
Armo55's Avatar
Alirght guys, I just wana say i have done research and read every single carb shim post out there... I am aware for JIS screwdrivers, didnt feel like ordering them.
So i stripped the **** out of the screw and i went and bought a diamond tipped small circular blade for the dremel, made a like and screwed it out.
I put 2 washers on each carb needle, and then I checked everything and closed the cabs securly, but on some allen screws.
It didnt seem to improve my bikes performance much, then i removed the snorkel. It helped a bit more.
Overall, i am a tiny bit more satisfied but it was NOT worth the 4 hours. Maybe my expectations were too big? and im starting to grow out of this bike? (Been 10 Months)
Any advice on what to watch out for?
Old April 7th, 2012, 07:20 AM   #22
greg737
Motorcycle(s): -
My guess is you haven't undergone a sudden spurt of personal growth. You're probably no more Zen now than you were before you bought the EX-250.
Beyond the existential questions of life and being, I'm guessing your riding skilz haven't progressed to a point (of total mad sickness) where they're rendering the EX-250 useless/pointless in your hands.
It is possible, however, that you've got the onset symptoms of a mild case of "600 SuperSport proximity phallus enlargement disorder", which is when you begin to image that your penis would look much bigger if you were ridin' a Gixxah'.
Old April 7th, 2012, 07:56 AM   #23
Armo55
Armo55's Avatar
Lol, I wouldnt mind ridin' a ZX6R
Old April 7th, 2012, 10:01 AM   #24
TnNinjaGirl
Ms. Personality
Mayhaps learn to work on the screamin 30hp of the 250 before moving up to a 100hp 600. But, like you said you were aware of what you needed and didn't feel like ordering it. So, I guess it doesn't matter what advice you ask for, you won't follow it.
Old April 7th, 2012, 04:18 PM   #25
Armo55
Armo55's Avatar
Asking for advice and ordering a Japanese tool dont go hand in hand, but nice try?
Old April 7th, 2012, 04:52 PM   #26
TnNinjaGirl
Ms. Personality
They do if you want to get the job done ;-)
Posted via Mobile Device
Old April 7th, 2012, 04:57 PM   #27
Armo55
Armo55's Avatar
Job was done a long time ago
Somebody had a bad day today Desmoluci Off-Topic 1 April 25th, 2014 09:37 PM
Beautiful day today Renner General Motorcycling Discussion 4 September 7th, 2012 04:06 PM
What did you do with your day today? Apex Off-Topic 12 August 28th, 2012 08:24 PM
What did you do with your day today? Apex Off-Topic 11 May 8th, 2011 01:43 PM
Today is the day!!!! Apex Off-Topic 10 October 17th, 2009 01:15 PM
