Old December 4th, 2008, 05:14 PM   #1
g21-30
g21-30's Avatar
Intuitive Frame Sliders - Available - Free Shipping
http://www.1tail.com/sa/p/INTUITIVE_...INJA_BLACK.htm
Old December 4th, 2008, 05:23 PM   #2
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
Pic of the sliders on an actual Ninja 250 would be ****!
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old December 4th, 2008, 05:31 PM   #3
M-Oorb
M-Oorb's Avatar
Motorcycle(s): 2008 250r (Fastest Color)
Only had my 250 for a couple months. I dont feel bad admitting im a new and only way to learn new things is to ask question. So....what are frame sliders and what do they do?
M-Oorb is offline   Reply With Quote
Old December 4th, 2008, 05:38 PM   #4
They are hard plastic (or sometimes metal) pieces that you attach securely to the sides of a bike (directly to the frame). The intention is that if the bike goes over on its side, damage is lessened because the sliders take the hit. There's a bunch of strong feelings about them on all sides; some folks think they are completely useless and do more harm than good; others think they are completely necessary and save huge $ if there is an incident.
I think it depends on the type of tip-over or crash to figure out if they'd help or hurt. It also depends on how secure is the mount. Some bikes have great places to mount sliders, other bikes don't. In fact, some sliders can total a bike by bending the frame on the most moderate incident, where the bike may have been repairable without sliders. Some people talk about "cut" or "no-cut" sliders. For some bikes (mainly supersports like R6's and similar machines), the best place to mount a slider is right behind a fairing, so you need to cut a hole in the fairing to put the slider through. The no-cut ones for those bikes mount the slider on a bracket so they can peek out from behind the fairing a few inches away. It's generally believed that the no-cut sliders for those types of bikes are utterly useless, as the bracket will bend in the best case, and if it doesn't it will torque the frame in the worst case.
I have them on my trackbikes, and I feel it did save me quite a bit of cash when I had a 90+ mph on-track crash on a R6 and ended up with only a few hundred $ in damage. I don't put them on my streetbikes, and haven't considered them yet for the ninjette. Though I'd be very interested to see what these look like so I can think about how solid a mount they are using on our bikes.
Old December 4th, 2008, 07:27 PM   #5
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Give me an hour or two and I'll get some pics of them on my bike up for you... Gray's is on right now, so it will have to wait
Old December 4th, 2008, 07:44 PM   #6
you need to get your priorities straight... plus you need a DVR.
Being a slave to network programming is a drag.
Old December 4th, 2008, 07:51 PM   #7
noche_caliente
I have a DVR - it's being recorded as well so I can watch it later - but I was dying to see this episode!
Old December 4th, 2008, 08:47 PM   #8
noche_caliente
Ok, here are some pics
Here are a couple on my black bike
Old December 4th, 2008, 09:08 PM   #9
sleepymike
Motorcycle(s): 08 250R
do you have any pics with the fairings off, showing how these mount?
sleepymike is offline   Reply With Quote
Old December 4th, 2008, 09:36 PM   #10
noche_caliente
no, but there is a DIY that caligirl did over on KF that has them
Old December 4th, 2008, 09:56 PM   #11
Thx for the link, I took a look at that DIY. Personally, I think that these sliders on the 250 are useless for anything other than a parking-lot zero-mph drop, and maybe not even for that. Any lateral torque whatsoever on the slider and it will bend immediately, and will likely rip the engine mount bolt & its mount as well. A bike sliding on its side at even moderate speeds, even one as light as ours, is still 400 lbs of inertia moving at speed, and there's no way that long thin bar stands up to that force without failing one way or another, and hopefully not damaging anything other than itself.
That said, I do like them cosmetically, it is nice to not have to chop up the fairings, and they give the bike a more aggressive look. But I think that we ninjette owners are kind of stuck, as the aggressive fairing design is much wider off of the frame and engine of the bike compared to other supersport bikes, making the distance that a frame slider mount needs to travel longer than on other bikes.
Look at how sliders mount on an R6, for example:
No long bolt, the mount of the slider itself snugs up against the frame, holding it in place against lateral torque.
Old December 5th, 2008, 09:06 PM   #12
TomB1956
TomB1956's Avatar
Motorcycle(s): 2008 Ninja 250R (Green)
Thanks Alex....that's kind of what I was thinking.
TomB1956 is offline   Reply With Quote
Intuitive Frame Sliders Yaozer Motorcycle-related 16 September 16th, 2013 01:37 PM
FS: Un-used intuitive frame sliders BEST OFFER tjb0012 Motorcycle-related 8 May 30th, 2010 08:52 PM
New enough Intuitive Frame Sliders mike_sema 2008 - 2012 Ninja 250R Farkles 46 April 17th, 2010 03:12 PM
Intuitive Frame Sliders Question tjb0012 2008 - 2012 Ninja 250R Farkles 5 April 14th, 2010 04:23 PM
Installed Intuitive Frame Sliders! NickH Pictures 20 April 11th, 2009 04:19 PM
