Old May 16th, 2012, 05:48 PM   #1
rph12
Motorcycle(s): 2005 Ninja 250
Aftermarket turn signal replacement fast blinking problem
Hey guys,
So on a slow u-turn on a pretty steep hill (stupid, as I learned) I almost fully dropped my bike but caught it just before any fairings hit leaving just the right turn signal housing slight scratched and cracked (inches from a nasty one). So I went and bought a whole new housing and instead of the OEM one I bought the after market version. I noticed that it had one more wire than the original one that was in there (this is just a note for later, the wire is red). So it works all fine and dandy, except for this: When flicking the turn signal switch to activate the right side, the turn signals blink normally...for a couple of seconds. Then they begin to blink rapidly. I'm not sure what causes it and there seems to be no specific thing to recreate it.
Could it be the wires are in wrong? Could it be that the third red wire is just kind of sitting there chillin`?
Any help is great, thanks all.
rph12 is offline   Reply With Quote
Old May 16th, 2012, 06:22 PM   #2
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
Try changing the stock relay to an automatic (electrical) one. These can be found at any auto shop and they should help, assuming the blinkers you put on are Leds.
EthioKnight is offline   Reply With Quote
Old May 16th, 2012, 09:17 PM   #3
cuong-nutz
cuong-nutz's Avatar
Upgrade your flasher or install a resistor. Sounds like you have LED turn signals. The stock flasher relay works off a load on your wiring.
HalfFast Racing Team
Turn signal problem ChickenRun 2008 - 2012 Ninja 250R Tech Talk 11 June 9th, 2013 05:44 PM
Turn Signal lights but no blinking Murtasma 2008 - 2012 Ninja 250R Tech Talk 3 August 1st, 2011 06:06 PM
1) Turn signal not blinking, 2) Brake modulator down MysterioX 2008 - 2012 Ninja 250R Tech Talk 3 May 28th, 2011 03:00 PM
Turn signal problem!!! danjaho 2008 - 2012 Ninja 250R Tech Talk 1 March 23rd, 2011 07:25 AM
Fast blinking turn signal austexjg 1986 - 2007 Ninja 250R Tech Talk 9 December 31st, 2009 10:46 AM
