Old January 11th, 2009, 09:32 AM   #41
g21-30
g21-30's Avatar
Excellent! Glad it worked out for you. The silicon sealant is a great idea. Since I'm not planning on riding in the rain, I won't do that right away. Maybe when I take the nose off to extend the mirrors some.
Did you burn the lights in for the required 10 minutes, once you fixed the fuse? I found out that by holding the starter button down a little bit longer, the low beam comes on and stays on. Once that surge is past, I can then turn the high beam on and off, as needed, no problems.
F-Sane (http://www.f-sane.com) recommends changing the fuse for the headlights from 10A to 25A. This will prevent the fuse from blowing in the future. Most people have both lights on at the same time and this will support the initial surge of power that the ballasts use to ignite. DISCLAIMER (On my part): The wiring may not be designed to carry this much current, so I can't recommend leaving high beams on for startup purposes!
Originally Posted by Viper-Byte View Post
Right, I have just about finished installing my HIDs (I just want to put a little silicon sealant round the rubber seals just to fully water proof them.) All went smoothly, except the testing part... I put the front back on, turned on the bike, WOW, what a difference!! then hmm, what is highbeam like? flick the switch, high beam comes on for a micro second and then both lights go out. checked the fuse box and I had blown the 10A fuse. I am going to get some fuses that will allow me to start the bike under full beam and leave that fuse, that way I will not be going too high a fuse that it is not going to do what it is designed for, but a fuse that will allow me to use the lights how I want.
Old January 11th, 2009, 12:03 PM   #42
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
Yeah, I ride to work and it is ofter wet, so I figured why not water proof it completely
I have run the low beam in for about 15 mins, but the high beam no as it blew the fuse and I couldn't replace it with a larger one, I figured another 10A would just blow again, I will be getting that soon, just woken up down here
Yeah, I was thinking about the current while starting it up on high beam and it does sound like something to be avoided due to the wiring. Well that is easy, start on low beam, if need be switch to high beam though these are so much brighter that I may not even use high during the day.
Viper-Byte is offline   Reply With Quote
Old January 11th, 2009, 02:56 PM   #43
Viper-Byte
Viper-Byte's Avatar
Right, all finished. I replaced the 10A fuse with a 15A fuse and all is good
All nice and water tight as well
Old January 11th, 2009, 03:16 PM   #44
g21-30
g21-30's Avatar
Congrats Viper-Byte. I know it was an experience.
Old January 12th, 2009, 04:02 PM   #45
grandmaster
grandmaster's Avatar
Motorcycle(s): 2008 Ninja 250R, CR125R
Well, the lights showed up today, hopefully I get get them in over the weekend or something if i have time. I think I should probably go get a manual too, might be a smart idea, anyone know how much they are?
grandmaster is offline   Reply With Quote
Old January 12th, 2009, 04:21 PM   #46
g21-30
g21-30's Avatar
Did you jump into the middle of this thread? I ask, because post #3 provides the info you seek!
Old January 12th, 2009, 04:35 PM   #47
grandmaster
My bad haha, I read it all about 3 weeks ago and never went back through all of it again. But i definatly will be when i do the install, btw thanks for the writeup.
Old January 12th, 2009, 04:38 PM   #48
hey, he's in college... you expect him to read, too???
Old January 12th, 2009, 06:10 PM   #49
g21-30
g21-30's Avatar
Good news for you. Hold off on the DIY. Viper-Byte has a great mod for it, assuming you received the same kit that he and I did! It should make it slightly less tedious.
Old January 12th, 2009, 08:05 PM   #50
grandmaster
Oh really? I ordered it form the same place you did, and came in the same packaging and everything...so I would assume its the same. You know when its supposed to get posted up?
Old January 12th, 2009, 08:27 PM   #51
Viper-Byte
Viper-Byte's Avatar
I will aim to have my write up on the install of mine tonight, in a few hours.
The only things I done differently was I used the extender things on the existing bulbs (they just pull off) and cut then down and took the inside out, works the same as the washers. I also put on some silicon sealant to full waterproof the bulbs.
Also, my fuse kept blowing at 10A, I installed a 15A fuse and it will stay on no matter if the bike is started on high, or low beam.
I will post the pics of my install tonight.
Old January 12th, 2009, 10:24 PM   #52
grandmaster
Sweet, sounds good, thanks.
Old January 13th, 2009, 03:52 PM   #53
Viper-Byte
Viper-Byte's Avatar
Right, sorry about the delay, had to make an unscheduled trip to the Hospital.
I have uploaded the main pics I took for this in my photo album here: http://www.ninjette.org/forums/album.php?albumid=29
As I have said, I used the riser that the stock bulbs come with as seen here:
I pulled it off the bulb, you will need to be careful as the metal lip on the bulb is sharp
The metal prongs just come out if met with a hammer
I had to use a file to cut the riser down as I didn't have anything better suited, this allows the part of the HID bulb that is heatshrunk to get through, the cut in the wall it to allow the wires to get through.
This is what it looks like on the HID bulbs:
Then just clamp it in using the spring as normal:
I often ride in the rain, and thought with cutting the rubber seals to allow the rubber seals that came with the HIDs to fit in, this will possibly allow water in, so I got some silicon sealant, with the thoughts that it will bond the two rubbers together, provide a water tight seal and be easier than glue to come off if need be.
It is as simple as that. (these are only the parts that I have done differently to Sam, otherwise I used his DIY to install them )
Old January 13th, 2009, 04:05 PM   #54
You guys have got to post your impressions of the lights when riding. It may be a PITA to install, but the difference in lighting over stock is night and day.
This mod is a must do if you ride a lot at night in areas with little or no street lights.
be sure to check your headlight aiming after you're done with the install.
Old January 13th, 2009, 04:12 PM   #55
Viper-Byte
Viper-Byte's Avatar
I didn't find it too bad to install, I just took my time and all was fine.
The difference is really amazing, I have only taken it out for a test ride at night so far and the difference is AMAZING! Not only is there more light to see with, being the colour that it is (I got 8000k), it is clearer to see. I went for a ride yesterday and while it was cloudy, I could see the lights relecting back on the signs a little
I think the mod is a must do if you do any decent amount of riding at night, even during the day, they will allow the cagers to see you better than the stock lights (my impressions anyway)
Yep, I have checked my aim and adjusted it accordingly.
Old January 13th, 2009, 04:22 PM   #56
g21-30
g21-30's Avatar
Viper-Byte...congrats on the mod. I hope the DIY helped you.
I went out Sunday afternoon while it was overcast. Twice people were thinking about pulling out from side streets and I just flashed the high beam. Both times they slammed on the brakes, so I know the lights "helped" them to see me.
I haven't had a chance to ride at night or adjust them. Probably won't get to do this in the next few days. Looks like a possibility of snow on Wednesday, Thursday, and Sunday!!
Old January 13th, 2009, 06:05 PM   #57
grandmaster
Thanks for the remainder of your side of the writup. looks good.
Old January 14th, 2009, 07:43 PM   #58
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
David - do you have any more pics that show the temperature a little better? I think I'm leaning towards the 8000K for the tone, but I know that the 4300K is going to be a stronger intensity.... pics of the color would help me a little bit!
Old January 14th, 2009, 08:26 PM   #59
Viper-Byte
Viper-Byte's Avatar
I guess I should have included a before and after shots in my post.
I have not really got too many after shots, but here are some, I have put all the ones so far in the album link above, I will get more tonight for you from riders perspective.
I actually think the 8000k is a very nice combination of light and colour, with the little night riding I have done so far.
Daytime:
Old January 14th, 2009, 10:40 PM   #60
dunno... how much reason do you want to give the police a reason to pull you over for illegal headlights? the 8K color is noticeably blue and very easy to distinguish as an aftermarket kit.
The 4300K is the closest color temp as what manufactures who produce cars with HIDs use.
Old January 15th, 2009, 02:33 AM   #61
Viper-Byte
Viper-Byte's Avatar
As promised, here are some better pics , I feel that the 8000k is really blue while warming up, but after a few mins, IMO it is actually not all that blue.
Low beam stock:
High beam stock:
Low beam HIDs:
High beam HIDs:
(probably not the best example as I had only had the high beam on for 10 seconds before the pic, which is why it is so blue.
Low beam HIDs:
High beam HIDs (fully warmed up):
Old January 15th, 2009, 10:10 AM   #62
grandmaster
Where is the bike in the last two pictures? Are you next to it or standing over it? Kind of a dumb question but just curious as to where the pattern is on the ground in relation to where you stand.
Old January 15th, 2009, 10:38 AM   #63
the light pattern will be where ever you aim the headlight once you adjust them.
Old January 15th, 2009, 12:47 PM   #64
Viper-Byte
Viper-Byte's Avatar
That is me sitting on the bike as the rider would see the lights, note: my drive way goes up hill.
Old January 15th, 2009, 12:51 PM   #65
grandmaster
^^Thats what I was asking, thanks. Looks good.
Old January 15th, 2009, 12:53 PM   #66
Viper-Byte
Viper-Byte's Avatar
Yeah, I guess I should have stated that all of the pics
in my post above are from the seat.
Old January 15th, 2009, 02:27 PM   #67
xTKx
Finally!
xTKx's Avatar
Motorcycle(s): 09 Red 250R
Thanks for the walk-throughs gentlemen. It's pretty cool when people take the time to document every step of the way for those (like me) who're getting started. Hopefully within the next couple of months I'll be able to actually put these threads into action!
xTKx is offline   Reply With Quote
Old January 15th, 2009, 02:36 PM   #68
Tony,
check out this thread if you need projects to keep you busy in the future.
http://www.ninjette.org/forums/showthread.php?t=5586
Old January 17th, 2009, 12:59 AM   #69
grandmaster
Hey, just curious as to where the fuse is for the lights...just in case I end up blowing one I can actually find it.
Old January 17th, 2009, 01:36 AM   #70
Viper-Byte
Viper-Byte's Avatar
It is just under the seat behind the battery in little box, which has the fuse ratings on it.
Old January 17th, 2009, 01:38 AM   #71
grandmaster
Sweet, thank you!
Old January 25th, 2009, 12:57 AM   #72
darkknight49
darkknight49's Avatar
Motorcycle(s): Black 08 Ninja 250
HIDs are awesome. I wholly intend on getting some once I get some cash and take the Bike to my parents house (since I don't have any tools).
Would you recommend a service manual purchase to help with the install?
2008 Ninja 250 - Yoshi Exhaust, Brake Light Modulator, HID Kit
To Come: Sliders, Fender Elim, Flush Mounts, Hugger (much later...no $ )
darkknight49 is offline   Reply With Quote
Old January 25th, 2009, 01:07 AM   #73
Viper-Byte
Viper-Byte's Avatar
Yes, they are awesome, IMO they are worlds over the stock lights.
It is not all that hard to install them, I do not have a manual, though I have just ordered one. The only part I was not sure about was the wiring (there are only 2 connections for each light to be made and they only plug into the existing light sockets. So it is not a lot of wiring), Sam has since edited the DIY to include this, so it is fine now.
I can see that you are looking at doing a few mods, if that is the case, I would suggest getting a service manual, post #3 has a link to a cheap place.
Old January 25th, 2009, 08:26 AM   #74
g21-30
g21-30's Avatar
Cheap, unless you live in New Zealand!!! Right Viper?
Old January 25th, 2009, 10:57 AM   #75
Viper-Byte
Viper-Byte's Avatar
Yeah, the shipping is double what the manual is But I have ordered a few things and the shipping has stayed the same, so...
Old January 25th, 2009, 02:01 PM   #76
grandmaster
Going to get started on my HID's right now!
Old January 25th, 2009, 02:22 PM   #77
maxedpenny
Don't Be Evil!
maxedpenny's Avatar
Motorcycle(s): 08 250R
Kelly, Could you post a pic of your bike with the 4300s? Is there any blueish tint?
maxedpenny is offline   Reply With Quote
Old January 25th, 2009, 03:19 PM   #78
Sorry, no night time pics, but the lights do have a bluish tint when compared to the stock halogen lighting. It is much like the HID headlight color on factory automotive headlights, which are 4300K.
Old January 25th, 2009, 03:34 PM   #79
maxedpenny
Don't Be Evil!
maxedpenny's Avatar
Thank you. I wish I could rep you. I am sold on the 4300s. But I am going to wait until it is closer to riding seaon to install them I allmost want to move somewhere warm. But I would miss snowmobiling and snowboard too much.
Old January 26th, 2009, 06:53 PM   #80
shporsche
shporsche's Avatar
Motorcycle(s): Ninja 250 09
Here is a pic of my HID install with 6000k bulb.
Sorry got no install pics, but I do have a pic of the bulb and the spacers I used.
shporsche is offline   Reply With Quote
HID headlight conversion. agentbad General Motorcycling Discussion 6 May 21st, 2014 07:13 PM
[webbikeworld.com] - Bikemaster HID Headlight Conversion Kit Review Ninjette Newsbot Motorcycling News 0 September 16th, 2012 09:10 AM
HID conversion b_eastep 1986 - 2007 Ninja 250R Farkles 84 August 4th, 2010 10:10 AM
Proper HID conversion? jonthechron 2008 - 2012 Ninja 250R Tech Talk 23 February 9th, 2010 02:09 PM
