Old September 30th, 2012, 07:06 PM   #1
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Air leak from Tire Valve
My tire randomly goes flat while sitting overnight every once in a while. This is because the valve leaks air if it is moved. If/when I remove the valve cap it will leak air sometimes from the center hole. It also leaks air from around the base where it meets the tire. What is wrong w/ it and how can I fix this?
Old September 30th, 2012, 07:14 PM   #2
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
valve replacement
You can buy a replacement valve from an auto supply place for a couple of bucks.
If you break the bead on one side of the tire, you can probably remove the old valve and insert the new one.
You put on a steel valve cap and pull it through, soapy water helps.
Then pump the tire up until the bead seats again, soapy water helps.
No need to re-balance.
GeorgeRYoung is offline   Reply With Quote
Old September 30th, 2012, 07:35 PM   #3
FvnnyL3tt3r1ng
Srry I don't know what a bead is?
Old September 30th, 2012, 07:59 PM   #4
Dragone
Dragone's Avatar
Motorcycle(s): '86 VFR 750, '90 ZX7, '92 KZ1000, '05 ninja 500, '05 6RR, '06 10R, '07 ninja 250
Replace the schreader core and air up to your air preferences. Not sure on how each one costs, but it is penny's.
Dragone is offline   Reply With Quote
Old October 1st, 2012, 06:30 AM   #5
Bead is the edge of the tire that seats on the interior of the wheel's rim.
See how-to:
http://faq.ninja250.org/wiki/Tires
Old October 2nd, 2012, 12:49 PM   #6
FvnnyL3tt3r1ng
Took it to the shop, found out the valve was dryrotted around the rim area. Needed a new tire so had a new tire+ valve put on. I guess I'll have to learn how to replace the valve next tire change...
Old October 5th, 2012, 03:40 AM   #7
Jim Moore
Jim Moore's Avatar
Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150
The auto parts place sells a tool for that job. Called a stem puller or something like that. Costs a couple bucks.
Jim Moore
Jax, FL
Jim Moore is offline   Reply With Quote
Air cut off valve Thrak 2008 - 2012 Ninja 250R Tech Talk 25 July 1st, 2021 07:05 PM
300 air switching valve and purge valve (CAL) removal joyspring 2013 - 2017 Ninja 300 Tech Talk 21 February 13th, 2017 01:36 PM
Front Air Valve Stem kstrib 2008 - 2012 Ninja 250R Tech Talk 2 May 2nd, 2012 11:15 PM
[kropotkin thinks...] - Air At Last: Hayden Gets Air Valve Engine For Donington Ninjette Newsbot Motorcycling News 0 June 19th, 2008 08:32 AM
