Old September 27th, 2014, 11:25 AM   #41
garth285
KAWASAKI GURU
garth285's Avatar
Originally Posted by Flying View Post
I'm holding my breath as I read your progress. I would love to try my hand at fitting and testing a turbo 300 system.
Thanks for the support! Its pretty fun, keeps me sane lol.
I should be coming together a little quicker hopefully but I will be dropping the bike off to the fabricator next weekend for all the turbo stuff to be mounted.
Old October 14th, 2014, 06:53 PM   #42
garth285
KAWASAKI GURU
garth285's Avatar
CLICK TO READ MORE:
Old October 17th, 2014, 12:45 PM   #43
garth285
KAWASAKI GURU
garth285's Avatar
Old October 17th, 2014, 01:35 PM   #44
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
nice metal
alright, sweet metal
Qomomoko is offline   Reply With Quote
Old October 27th, 2014, 05:48 PM   #45
garth285
KAWASAKI GURU
garth285's Avatar
Turbo Mounted!!! Click photo below for update.
Old October 31st, 2014, 09:05 PM   #46
garth285
KAWASAKI GURU
garth285's Avatar
Awaiting more parts and time to bring the bike to the fabricator to finish the cold side.
Turbo oil feed line:
Head studs:
Old November 1st, 2014, 02:10 AM   #47
micoulisninja
modaholic junkie
Shawn please provide some info on those studs... I guess they are the alternative you mentioned to ARP's expensive ones... where did you find them, cost and type/size etc please....
looking good so far !! I just can't wait to hear it whistling...
Old November 4th, 2014, 10:58 AM   #48
garth285
KAWASAKI GURU
garth285's Avatar
Well I decided not to run those studs, they are not the correct length and after measuring things I dont think it will be worth it. If I were going to do studs I'd just go with ARP 10mm and drill and tap the block for those.
For now I'll see how much the stock head bolts will hold :-(
Old November 4th, 2014, 11:10 AM   #49
Flying
Motorcycle(s): 2010 Ninja 250
Loving the simple turbo manifold. How did you handle the mating surface? Is it just a trip to the machinist or is there more to it?
Old November 4th, 2014, 11:11 AM   #50
garth285
KAWASAKI GURU
garth285's Avatar
Which mating surface are you talking about?
My welder took the stock pipes and I brought him a spare engine to mock everything up with.
Old November 4th, 2014, 11:49 AM   #51
garth285
KAWASAKI GURU
garth285's Avatar
If I decide to go with pistons I just heard back from Wossner Pistons. $200 a pop and 4 required with a 8-10 week lead time.
Maybe if someone wanted to go in on a set I'd do it but yeah $800 for pistons is outta the budget :-(
Old November 19th, 2014, 02:57 PM   #52
garth285
KAWASAKI GURU
garth285's Avatar
Plumbing should be done Friday :-)
Old November 22nd, 2014, 10:47 AM   #53
garth285
KAWASAKI GURU
garth285's Avatar
Old November 22nd, 2014, 11:45 AM   #54
micoulisninja
modaholic junkie
so nice to hear it idling !! I must put mine together soon, I just can't wait anymore !!
it will be nice to see it rolling and revving !!
Old November 22nd, 2014, 01:02 PM   #55
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Nice! I am looking forward to see this run.
Worlds fastest 250 ninja
Old November 22nd, 2014, 01:32 PM   #56
garth285
KAWASAKI GURU
garth285's Avatar
Thanks guys! I was a little worried about the return line so I ran that clear hose, I can see the oil flowing very nicely threw it so I'm very happy!
I have to put the chain and sprockets on the bike but other than that I have to hard mount the fuel system to the bike, finish up some electrical items and then start the tuning!
I am tuning threw the ECU which is a lot more time consuming so I might just take the bike to the dyne sometime soon.
I need to get some gauges to, but I am going to use the KDS tool at first.
I'll keep ya guys posted!
Old November 24th, 2014, 12:26 AM   #57
Major_Paine
Motorcycle(s): 2004 ninja 250 (in progress), 2009 cbr600rr
posting on here to follow this. been wanting to put a turbo on my 250 for a while now. its a pregen tho, so id have to figure a few things to do differently i think
Major_Paine is offline   Reply With Quote
Old November 24th, 2014, 05:53 AM   #58
garth285
KAWASAKI GURU
garth285's Avatar
The biggest thing you have to think of is how you want to tune it, either carb or fuel injection. If you go fuel injection you can either find a Ecotrons kit or find all the ninja 300 FI stuff. Either way it works out to being almost the same price I believe but yeah between fuel injection and the turbo stuff you will be slightly over a grand.
Let me know if you need any help but check out Racer X's turbo build as well!
Old November 24th, 2014, 06:49 AM   #59
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Nice sound
Old November 24th, 2014, 08:47 AM   #60
garth285
KAWASAKI GURU
garth285's Avatar
Chain and sprocket went on last night no problem.
Running something a little aggressive or no so aggressive but its a 15/40 setup with a DID ERV3 chain.
Using a gearing calculator it should put me at 131mph at 13,000 rpm.
As far as if that is correct or not I am not sure but it will be a start, I have a few other sprockets to try out but when I get it up on the dyno I will run it up to the rev limiter in 6th and see what MPH it says.
I also can up the RPM's a little if I really have to lol.
Old November 24th, 2014, 10:39 AM   #61
Racer x
Racer x's Avatar
Sounds a little steep. If you make 65 hp then you can get that speed. But watch the peak on the dyno. It should be around 12500 and putting out max HP max. The torque should be close to 40 and above 11500. Gearing is very impotant. You need to be VERY close on the calculations
Old November 24th, 2014, 11:02 AM   #62
garth285
KAWASAKI GURU
garth285's Avatar
Yeah for sure, luckily in S FL I have plenty of empty places to do real runs and see what it will pull. I'll be doing plenty of runs on the street before the mile :-p.... in mexico that is....
Old November 24th, 2014, 12:26 PM   #63
Racer x
Racer x's Avatar
Don't be surprised how easy it is to over gear. And remember the mile is from a dead stop. Can't wait to see numbers. This is a giant leap forward for 250 ninja performance. Good job gettng it this far.
Old November 24th, 2014, 12:59 PM   #64
garth285
KAWASAKI GURU
garth285's Avatar
Yeah I know all about the gearing man, a tooth will make or break a race. and running 201 or 198mph is a big leap when trying to outrun a 206mph busa lol
Old November 24th, 2014, 01:17 PM   #65
Racer x
Racer x's Avatar
I discover a gear calculation chart. I have over 150 documented runs in the mile. I know the speed and I know what gear I used.
I went through each run and found the exact RPM. Not only did I find five or six runs that I only shifted into fifth gear. Some on purpose some not. But I found only 100 to 200 rpm between a record run and a waste of gas.
Old November 24th, 2014, 01:25 PM   #66
garth285
KAWASAKI GURU
garth285's Avatar
Not fun! I am using the calculator I have on my turbo250.com website which has been decently accurate for the busa and zx10r but I have yet to run this bike and log any RPM's or MPH.
Old November 24th, 2014, 04:50 PM   #67
Racer x
Racer x's Avatar
The math is amazing. You find the peak hp and torque. Gear between the two and run. Document everything you can. Data is what we need at this point. That and valve springs. What are you doing for coils.
Old November 24th, 2014, 04:54 PM   #68
garth285
KAWASAKI GURU
garth285's Avatar
Sounds good, I have a nice data logger and always use GPS's for my top speed runs. Its going to be such a change from trying to break the 200mph barrier I have been chasing for many years.
Coils as far as ignition coils? If so I picked up ninja 300 coils, which actually I believe they are used in a few kawi models, I have access to k-dealer so I can see what parts are used where pretty easy. I picked up a few of the key components a lot cheaper on ebay searching for 600 or 650 parts instead of 300.
Old November 24th, 2014, 06:50 PM   #69
Racer x
Racer x's Avatar
The stock 250 ignitikn coils are a little weak. Watch to see if power flat lines no mater what the fuel mixture. First thing I needed with nitrous. That and a clutch.
Old November 24th, 2014, 07:05 PM   #70
garth285
KAWASAKI GURU
garth285's Avatar
The 300's use coil sticks, I think they use the same stick in much larger bikes to may not be an issue.
I have some beef cake clutch springs I'll be trying. I'll let you know how they work.
Have you tried different temp plugs?
Old November 24th, 2014, 11:10 PM   #71
Racer x
Racer x's Avatar
I use NGK cr10e plugs. The stick coils should be good. They use them in larger bikes. But they have lower cylinder pressure.
Old November 25th, 2014, 06:54 AM   #72
garth285
KAWASAKI GURU
garth285's Avatar
Im going to try out CR9EK's They worked great on my turbo busa, has two electrodes for better spark and a little cooler than the stock CR8E's
Old November 25th, 2014, 07:17 AM   #73
Somchai
Freedom for Germany
@garth285 and @Racer x, do you know this?
Link: http://www.briskracing.com/brisk-rac...er-spark-plugs
Old November 25th, 2014, 07:21 AM   #74
garth285
KAWASAKI GURU
garth285's Avatar
Yeah I have seen brisk plugs before, also NGK makes plugs that I think were about $50 a pop but they are gapless and have actual tests to back them up, they are weird though your supposed to warm the bike up with normal plugs and then switch to these and then go race lol.... I had them in my 04 10r because I got a free batch but yeah plugs are another can of worms lol....
Brisk supposedly does make good stuff but I am gunna stick with the NGK double electrodes for now!
Old November 25th, 2014, 04:29 PM   #75
Major_Paine
oh im definitely going efi. thinking about following your lead and getting everything off of a 300.
is racer x's build on the new gen or pregen
Old November 25th, 2014, 04:34 PM   #76
garth285
KAWASAKI GURU
garth285's Avatar
Pregen but I think it has a newgen engine in it.
If you need any help with the EFI stuff let me know!
Old November 25th, 2014, 04:48 PM   #77
Major_Paine
thanks! ill be doing that! im looking to put out 40-45 hp after its all set up. nothing too fancy, more doing it because itd be so rare.
already have a gsxr front end on the bike and then some. things gonna be fun at track
Old November 25th, 2014, 07:16 PM   #78
garth285
KAWASAKI GURU
garth285's Avatar
@Racer x you needa step up your game!
Tonight I was able to spend a good amount of time in the garage... got all my controls mounted and holes drilled in the clipons, installed the battery tray, installed the clamps going to the plenum to the TB, routed quite a few electrical components. Mocked up where I will be mounting the fuel system and that all will fit VERY nicely so I'll hopefully have that running within a day or two.
Mounted the tail section, tank and seat, everything is fitting very nice, I just mocked up the front fairings and two things, 1 the exhaust outlet is right at the line between the upper and lower, and the charge pipe is hitting the RH side of the upper pretty good so I'll have to do some trimming there. If I eliminate the coolant resivior and relocate it I can move the charge pipe in a little more so I'll try that.
I think this would make a nice little street fighter with no uppers to! lol I guess I could run in the naked class :-p
Photos:
Old November 25th, 2014, 07:33 PM   #79
Racer x
Racer x's Avatar
Old November 27th, 2014, 10:18 AM   #80
garth285
KAWASAKI GURU
garth285's Avatar
HAPPY THANKSGIVING!
Had some time while the turkey was in the oven to build my 6AN lines, turbo return line, Fuel Pressure Regulator return line, and the fuel feed line.
Have to secure the fuel pump still but I should be able to pop the tank on and get the bike running with everything onto it.
I do still have to splice in the older stator plug onto the newer harness since the plugs are different.
After that I just have to put fresh oil in it and I should be able to take it down the road!
P.S. some things in the pics are a little temporary like the fuel pressure gauge and some other things lol
Racer X turbo build Racer x Ninjettes At Speed 313 January 23rd, 2016 11:13 AM
Turbo? Yes, TURBO! Somchai General Motorcycling Discussion 7 December 26th, 2013 12:06 PM
250 turbo on visordown alex.s General Motorcycling Discussion 17 August 29th, 2013 12:39 AM
Turbo 250! dyeforever General Motorcycling Discussion 3 May 1st, 2011 07:07 PM
Turbo Ninja! Neema12 General Motorcycling Discussion 24 July 20th, 2009 07:31 AM
