Old November 27th, 2014, 01:01 PM   #81
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
The only plug that is different is the one goo g to the regulator. Or do you have a 300 harness?
Worlds fastest 250 ninja
Old November 27th, 2014, 01:04 PM   #82
Racer x
Racer x's Avatar
I noticed you don't have a blow off valve.
Old November 27th, 2014, 01:28 PM   #83
garth285
KAWASAKI GURU
garth285's Avatar
yes I'm running the 300 Harness but 250 stator
No blow off valve right now, supposed to have one on the way but low boost and kind of single gear runs you can get away with not having one. As soon as it goes on the road race course it will have one but I'll deal with a small amount of com pressure surge to start with lol.
Turbosmart Kompact valves are pretty inexpensive if you are looking for one!
Old November 27th, 2014, 05:38 PM   #84
Racer x
Racer x's Avatar
With LSR you are full throttle full power. Then off throttle and full breaking.
Old November 27th, 2014, 05:51 PM   #85
garth285
KAWASAKI GURU
garth285's Avatar
Yeah I'm not to worried about it, on my drag buss it did not have a blow off valve, you really don't see any need for one until the end of the run, but with how small this turbo is I don't want to put any added stress on the turbo.
I won a turbosmart Kompact BOV on ebay but the freaking guy won't let me pay for it... go figure?
As soon as i get one I'll have it on the bike,
I should be taking it for its maiden test ride tomorrow!!!!
Old November 27th, 2014, 06:07 PM   #86
Racer x
Racer x's Avatar
Good luck be careful
Old November 28th, 2014, 10:29 AM   #87
garth285
KAWASAKI GURU
garth285's Avatar
WEEEEEEEEEEEEEE Shes boosted :-)
Started tuning just going up and down my block.
@Racer x I have a question for you if you bought your turbo from ecotrons, does the inlet for the oil line have a restriction in it?
Old November 28th, 2014, 11:01 AM   #88
Racer x
Racer x's Avatar
I don't think so. That was the balance. Restrict the inlet and measure the oil flow out. I was going to sorta use jets or a hose clamp on the outside of a hose.
Old November 28th, 2014, 03:12 PM   #89
garth285
KAWASAKI GURU
garth285's Avatar
Well the tuning is coming along nicly, I wish there was an easier way to flash tune the ECU but I have to make a run, log it, and then make my map adjustments and then pull the ECU again to reflash it lol....
@Racer x I just saw thing I must have missed and this might be a issue... On the Ecotrons website at the bottom of the turbo specs theres a note:
Note: the Oil pressure need be about 20-30kPa
or 2.9psi - 4.4psi
So my problem is I am noticing some oil coming OUT of the compressor side not the turbine side. Doing some research I have only found people complaining mostly about oil coming out of the turbine side and causing smoke, which mine is not smoking....
EDIT - So after going out and looking at the turbo I notice there is some oil coming from the oil feed line fitting which is a M10 to 4an fitting..... I am going to see if that needs to be sealed up a little more but it still looked like oil was coming out of the compressor side.
Thoughts?
Old November 28th, 2014, 04:36 PM   #90
Racer x
Racer x's Avatar
The oil pressure going out of the engine is say 70 psi. If you restrict this to a very small orifice then a small volume of oil will come out of the orifice at 70 psi. The turbo is a restriction. If the turbo did not allow any oil flow the pressure would eventually reach 70 psi. So you allow enough oil to flow out of the turbo so the pressure between the orifice and the turbo is 30-40 Kpa.
That is what I am trying to figure out now.
40kpa =6 psi
Old November 28th, 2014, 04:58 PM   #91
garth285
KAWASAKI GURU
garth285's Avatar
10-4
I did quite a bit of research about the oil feed tonight, I found out that quite a few turbos need a restrictor jet to lower the pressure feeding the turbo.
Here is what I did for tonight (going to try it tomorrow)
I found I had just enough fittings and some nitrous pressure gauge adapter to run a 4an line to that and it has a 0-100 gauge on it, and then a outlet that I am able to install a nitrous jet into to test the restriction of the flow. I have it setup so the gauge is after the jet I will install and that will measure how much oil pressure goes to the turbo. I am going to first start the bike up and see what pressure it is at at idle and possibly chance it and rev it up a little to see what psi I'm getting.
I spoke to a turbo busa guy I know and he said it might have been pushing some oil past the seals and they might not be blown but I'll have to watch it.
I'll run it straight with no restrictor in it and then I'll run a nitrous jet in it to see what I get. I have a handful of jets on hand but I think my largest is a .053
I have seen many of the restrictors they are using .030-.055 So I should be able to find a jet that will be the right size for us.
I am just unsure of that psi number that ecotrons has in their instructions. It looks like its sorta translated so not 100% if its accurate. Most places online say 10psi min and 30psi max
Old November 28th, 2014, 05:40 PM   #92
Racer x
Racer x's Avatar
Just make sure the volume is good coming out. Someone must know a ruff estimate of the volume. We are heading into an untested area.
Old November 28th, 2014, 05:52 PM   #93
garth285
KAWASAKI GURU
garth285's Avatar
That is for sure!!!
Its so hard to find solid info online about these turbos but thats what happens when you are on a budget and have to give things a go lol.
On a good note, my setup spools at around 7000 rpm. I dont have my boost gauge in yet so when I get that I can confirm stock wastegate settings. I picked up a AEM Tru Boost gauge/controller pretty cheap. I can turn off the controller and run off wastegate but it will record max boost. I'll have a 100% for sure wastegate spring # for us when its setup.
I am going to work on the oil feed tomorrow sometime and do some more runs. I think my WOT area is almost dialed in as far as air fuel so thats a start. On my base mapping it was rich as can be up until 7k rpm so it was stumbling until it hit boost and then took off like a banshee.... Its going to be HELLA fun with the boosted 250. Even with 15/40 gearing it feels amazing in boost. The last run I did it started to lean out up top so I had to add some fuel but it is ripping so far!
MORE TO COME :-)
Old November 28th, 2014, 07:15 PM   #94
Racer x
Racer x's Avatar
This engine has an unbelievable ability to drink fuel. It is like lean lean lean and then by the time you get it right you can't believe it even ran before. I can burn half a gallon of race gas in a one run with warm up and two mile return ride. That is less than ten MPG!
Old November 29th, 2014, 06:01 AM   #95
garth285
KAWASAKI GURU
garth285's Avatar
Damn yeah thats crazy, I am running E85 to which consumes around 30-40% more fuel to!
I just switched to E85 on a built busa with spray and just a N/A motor needed 26% more fuel but the benefits are amazing. The bikie made 209hp on pump gas I'll have it on the dyno soon to see what it makes on E85
Old November 29th, 2014, 08:28 AM   #96
garth285
KAWASAKI GURU
garth285's Avatar
@Racer x - This morning I hooked up my gauge setup to the oil feed line. With no jetting I was getting about 25-30psi at idle and well over 50psi with a simple rev of the engine it look like it would only go to about 50psi though.
Looking at what almost all other turbos run for pressure which should be about 10psi at idle and 30psi max I installed a nitrous jet. The largest I had was a .053 installed I saw my idle pressure drop down to a little under 20 and revving it up I was still about 45psi.
I had a .034 jet I think it was and a .024 I decided to try out the .024 and I think thats going to be as close as well need it. I got 10-12psi at idle and revving it up it was only getting about 30psi! I took it for a ride and I saw no oil coming out of the compressor inlet so this is good news. Hopefully I did not cause any damage to the seals and just had some oil push threw.
So I will eventually run just a nitrous jet holder in between the oil feed lines and that should settle that hopefully!
Old November 29th, 2014, 08:40 AM   #97
Racer x
Racer x's Avatar
That is awsome. The final piece of the puzzle.
I have a friend with a 750 turbo on E85. I think it went 209 mph. The supercharged 350 Honda that just went 145 used methanol. With no intercooler I guess it's a must. I already have a five gloom tin of Race E85. Don't use pump E85 it is no consistent enough
Old November 29th, 2014, 11:51 AM   #98
garth285
KAWASAKI GURU
garth285's Avatar
Yeah I am running it on pump for right now until I get the tune close and then will switch over to E85R.
I am going to double check my oil pressures when I can have it on the dyno and see what at max RPM's the oil pressure is going to, I can always just keep decreasing the oil jets.
I think the problem with this VZ21 turbo is its size and how small it is, the oil flow is probably alot less than normal turbo's. I think I hit the neail on the head with the .024 jet though it looks right between that 10-30psi.
The only other thing I could think of is what oil you are using.
I am running Shell Rotella T full synthetic 5W-40 (dont judge me) lol
Back to the tuning!
Old November 29th, 2014, 01:54 PM   #99
garth285
KAWASAKI GURU
garth285's Avatar
@Racer x - I believe the wastegate is set to .5 Bar or 7.25psi
I hooked up the 1:1 on my FPR and it was going right about 51psi from what I can see.
Motor has held quite a few WOT runs so far. I am going to call it quits for the weekend though I am waiting for some more parts to come in
Old November 29th, 2014, 02:23 PM   #100
Racer x
Racer x's Avatar
That is what was expected. This is awsome, congratulations
Old November 29th, 2014, 02:27 PM   #101
garth285
KAWASAKI GURU
garth285's Avatar
My turbo oil pressure is spot on at 10-12psi at idle and 30-32psi at max. I let the bike sit and I just saw some oil seepage. I checked my oil return line and I am starting to think it might be low. I have a scavenge pump but its so bulky. I was looking at the one ECOTRONS has but its pricey for being most likely a chinese product.
I found a similar pump thats supposed to be very similar and flow slightly more. Its called a HEP-02A pump. I may attempt to run one of those and see how it acts. I think the oil is flowing threw the return line but I think it needs to be scavenged.
Old November 29th, 2014, 02:46 PM   #102
Racer x
Racer x's Avatar
I am going to run my return to the top of the clutch cover.
Old November 29th, 2014, 02:54 PM   #103
garth285
KAWASAKI GURU
garth285's Avatar
With a pump?
Old November 29th, 2014, 04:05 PM   #104
Racer x
Racer x's Avatar
No just let it gravity flow. I have a pump if I need it.
Old November 29th, 2014, 06:37 PM   #105
garth285
KAWASAKI GURU
garth285's Avatar
10-4 I think the turbo would have to be as high as the exhaust ports to gravity feed that high, would be nice though!
I picked up some fittings for a scavenger pump I have had which is a larger gear driven one, I'm going to run it on the dyno with this pump and monitor the turbo for any oil being pushed out.
I'd like to pick up a small inline pump for it though but most have small 5/16 ports in them so I'd have to reduce my 6an fittings down even more, but if its sucking the oil out of the turbo it will be a win.
Old December 1st, 2014, 03:25 PM   #106
garth285
KAWASAKI GURU
garth285's Avatar
@Racer x I'd start planning on having a scavenger pump. Just did a little experiment on mine and I think we may need them. I can mount my oil pump under my plenum and I think I'll have enough room for all fittings and lines. I just have to decide if I want to run braided lines or just clamp style. I like the braided lines now that I have them but they are a pain in the ass to assemble.
Anyways I ran the bike on the stand and with the pump not running it was starting to smoke a little, fire the pump up and smoke went away and oil was gone. The dyno will tell the take if this cures all the problems, I may even be able to pull the oil jet out if oil does not go past the intake seals. I am going to hard mount the oil pump and take it for a ride when its dry out within the next day or two and go from there!
I will keep you posted!
Old December 1st, 2014, 03:47 PM   #107
This bike gets my nomination for the bike with the most equipment packed into it. Competition is RacerX so far.
Looks great. Keep at it! I will admit that I completely doubted you at the beginning.
Old December 1st, 2014, 03:54 PM   #108
garth285
KAWASAKI GURU
garth285's Avatar
LOL Thanks! Yeah it kinda sucks theres so much stuff packed into it. It would have been much easier to start off with a ninja 300. Could have just upgraded the intake pump and injectors and gone from there. Fuel injection is key though. Oil for the turbo is vital for turbo life as well.
Wait til I have a boost gauge, oil pressure gauge and fuel pressure gauge hooked up lol.
Old December 1st, 2014, 04:04 PM   #109
Bigballsofpaint
Make a kit, i want it! Awesome job
Old December 1st, 2014, 04:09 PM   #110
garth285
KAWASAKI GURU
garth285's Avatar
I'll wind up selling the bike or parting it out eventually. Start saving that !
Old December 1st, 2014, 04:55 PM   #111
Racer x
Racer x's Avatar
If I run the pump to feed the turbo it will have seven PSI all the time. What do you think of that?
As far as complications go this turbo is very straight forward and simple. My nitrous bike is beyond complex. It is like a moon launch every time I run it. Part of the reason I wont take it to the salt. Complexity is not a virtue. It is just things that can go wrong or be out of adjustment.
Old December 1st, 2014, 05:42 PM   #112
garth285
KAWASAKI GURU
garth285's Avatar
That may or may not work. The turbo had journal bearings kind of like our crank bearings. If you loose that oil pressure the turbo shaft will ride the bearings which = bad. If I were you I'd pull the oil from the engine but you may be able to do it that way.
The 2 main things are turbo oil feed pressure and oil drainage.
My turbo is lower than yours so you might not need the scavenger pump and just run a drain line.
Old December 1st, 2014, 06:13 PM   #113
Racer x
Racer x's Avatar
Ya I think that should work. I wounder what happens if the oil pump is running. But the turbo is not spinning, Wont the dynamic seals just leak?
Old December 1st, 2014, 06:21 PM   #114
garth285
KAWASAKI GURU
garth285's Avatar
No they won't. It will not leak unless you over pressure the seals or do not drain it properly.
Old December 2nd, 2014, 12:57 PM   #115
garth285
KAWASAKI GURU
garth285's Avatar
Picked up some good lines for the oil pump system today, if this works well I'll eventually swap it over to steel braided lines but for now I bought 3/8 transmission cooler hose which is good to 400psi and 300* F so it will be safe to run with that hot oil, the clear tubes were meant just to test the system.
I also am getting in my AEM Tru Boost gauge/controller so I'll be able to hook that up to the bike and see what actual PSI I am boosting to.
I also changed something for tuning. I was going to run the bike with no IAP sensor because kawi defaults to the RPM based mapping. Well turns out if that sensor is not it it will throw it into a limp type mode so what I did was run a T on that line and added a one way check valve so the IAP sensor will see vacuum but as soon as the turbo is making positive pressure it bleeds off and just see's 0.0 vacuum. This is what most everyone does I thought I could have gotten away with running it a different way but I'll run it this way and go from there.
Will keep you guys posted on boost numbers and oil system results lol
Old December 2nd, 2014, 04:36 PM   #116
Flying
Motorcycle(s): 2010 Ninja 250
Old December 3rd, 2014, 06:12 AM   #117
garth285
KAWASAKI GURU
garth285's Avatar
A small update... had a callout for work so I couldnt do everything I wanted to last night but I did get my boost gauge hooked up. Pretty neat little unit, I can run the turbo just off the wastegate or I can set two different boost levels and on top of that there is a scramble button that will give you a burst of higher boost with the touch of a button. I wont be able to use that but its a neat feature.
Have to pick up some fittings today for the boost controller solenoid and that will be done.
I'm having a problem with the tuning side, I'm working with some ECU tuners to sort the problem out but its just being unresponsive to my adjustments just at idle.
I should be on the dyno Saturday though to finally make some pulls!
Old December 3rd, 2014, 06:15 AM   #118
Racer x
Racer x's Avatar
Scramble button. Haha I have one of those.
What rpm are you trying to idle? I am good with anything under 2000
Old December 3rd, 2014, 06:22 AM   #119
garth285
KAWASAKI GURU
garth285's Avatar
1200-1500rpm's
Its very odd, anywhere I try to pull fuel in the entire IAP or RPM map from 0rpm to 2500rpm it does not lean out the idle. I'm getting 10.5-11.0 : 1 at idle lol......
The funky thing is, if I unplug the IAP sensor it goes to about 14.5:1
I am thinking there may be a cold start map that is messing me up.
Old December 3rd, 2014, 07:15 AM   #120
Jason5885
Jason5885's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r FI
Everything you are saying sounds very technical and confusing, im still enjoying this though!
Jason5885 is offline   Reply With Quote
Racer X turbo build Racer x Ninjettes At Speed 313 January 23rd, 2016 11:13 AM
Turbo? Yes, TURBO! Somchai General Motorcycling Discussion 7 December 26th, 2013 12:06 PM
250 turbo on visordown alex.s General Motorcycling Discussion 17 August 29th, 2013 12:39 AM
Turbo 250! dyeforever General Motorcycling Discussion 3 May 1st, 2011 07:07 PM
Turbo Ninja! Neema12 General Motorcycling Discussion 24 July 20th, 2009 07:31 AM
