Old January 13th, 2015, 07:21 PM   #161
garth285
KAWASAKI GURU
garth285's Avatar
All ready for the dyno tomorrow!!!
(Yes I have more straps for it)
Old January 13th, 2015, 07:26 PM   #162
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
I'm looking forward to your dynorun with big interest and wish you best success
Old January 13th, 2015, 07:27 PM   #163
garth285
KAWASAKI GURU
garth285's Avatar
Thanks for the support! What a pain in the butt it has been just to try to get to the dyno!
Results tomorrow!
Old January 14th, 2015, 07:36 PM   #164
garth285
KAWASAKI GURU
garth285's Avatar
Well some progress has been made but I am running into a early rev limiter, hoping its the speed sensor causing the rev limiter.
Progress not perfection!
Old January 14th, 2015, 07:41 PM   #165
garth285
KAWASAKI GURU
garth285's Avatar
Hey @Racer x wanna guess how much boost these motors can hold lol....
While on the dyno I blocked the wastegate line and went from 12psi to....... get a load of this.... I'm seriously surprised the head did not lift.
26PSI of boost!!!!!!!!!!
Old January 14th, 2015, 07:51 PM   #166
Nice!!
That's a wonky set of curves. Also, it aggravates me that the X-axis is in mph rather than rpm.
Old January 14th, 2015, 07:54 PM   #167
garth285
KAWASAKI GURU
garth285's Avatar
I really did not do to much tuning to the bike tonight so its no where near final tune.
Trying to get past this early rev limiter.
Old January 14th, 2015, 08:22 PM   #168
swarfman64
Master modder
swarfman64's Avatar
Motorcycle(s): TURBO gpx250 99 CB250/500rs Sherco290 Trials Indian 1911big base (replica)
Wow, that's fantastic! I'm watching all this closely.
You've done a great job getting this all set up, I think these little engine are going to respond very well to boost. Initially I was going to settle for a nice reliable turbo bike but now I think the competitive spirit has kicked in and I want more!
[B]Come and see my turbo ninja build, dyno build and other stuff at http://swarfman64.blogspot.com.au/20...rtia-dyno.html
swarfman64 is offline   Reply With Quote
Old January 15th, 2015, 05:08 AM   #169
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Nice job! 50 hp is a real deal.
Worlds fastest 250 ninja
Old January 16th, 2015, 11:21 AM   #170
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
So... when are you building mine? Seriously.
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old January 16th, 2015, 12:41 PM   #171
garth285
KAWASAKI GURU
garth285's Avatar
I'll probably wind up selling this kit when I'm done with it!
Old January 16th, 2015, 01:00 PM   #172
Racer x
Racer x's Avatar
Bring what ever you have to Ohio. The 250/350 class is HOT we got turbos nitrous all motor guys. Vintage stuff all little bike busting serious speed. My bike is over 120 the 350 supercharged guys just went 145 and this year the turbos will add more to the ranks.
Old January 16th, 2015, 01:01 PM   #173
garth285
KAWASAKI GURU
garth285's Avatar
@Racer x - Swarfman is in Australia!
Old January 16th, 2015, 01:25 PM   #174
Racer x
Racer x's Avatar
My bad I should have checked that. Well there is Lake Garner
Old January 16th, 2015, 02:47 PM   #175
swarfman64
Master modder
swarfman64's Avatar
Thanks for the invite but your just a little too far away.
Old January 16th, 2015, 07:49 PM   #176
garth285
KAWASAKI GURU
garth285's Avatar
Well I may have an idea of whats wrong, the ninja 250 crank sensor specs in the manual say 100-150ohm and a peak of 3.2V The ninja 300 crank sensor says 180-280ohm and 4.5V ...... that may be holding me back! Hopefully I can try out a buddys setup and see what happens
Old January 18th, 2015, 10:00 AM   #177
garth285
KAWASAKI GURU
garth285's Avatar
Hey @Racer x just figured I'd share this info with ya, the wastegate on these VZ21's are boosting to 12psi and the oil jet that I have installed I think it was a .023 well when the bike was fully warmed up the bike at idle has oil pressure of 5-6psi and it picks up to about 15psi but under load and up to 10k rpm the oil pressure went down to 8psi going to the turbo so I may be going to a larger oil jet and run the test again.
I made some tuning adjustment's to the bike since I got plenty of runs in on the dyno but it was lean here and there and rich here and there. but I am running 25* of timing from 7k rpm and up and I'll see how the bike reacts to that, wondering if the bike was breaking up due to timing. I know stock they run about 34* I think it was so I have 9* of timing pulled for 12psi so we'll see how this acts with a bit more of timing pulled.
One more thing... when I disconnected the wastegate the turbo was putting out 5psi more at 7,000 rpm from 9.5psi to 15.5psi
Also with the wastegate disconnected it made that same 9.5psi 1,000rpms earlier.....
I atleast know the wastegate is doing its job but it would have been nice if it spooled the same connected as it did disconnected.
The bike held 26psi at 10k rpm.... I wonder if it can handle 26psi at 13k lol
Old January 18th, 2015, 10:46 AM   #178
Racer x
Racer x's Avatar
I would not be surprised if the pressure in the cylinder gets so high spark and air flow gets disrupted. Then it just flattens out on power.
Timing the spark event closer to TDC is good. It's what everyone does with turbos. But you need to play with boost and timing together.
Step one is to settle on a fuel and tune around that. As long as you can keep burning everything below 1400 degrees add more till coolant comes out the side. Then add studs.
Old January 18th, 2015, 01:44 PM   #179
swarfman64
Master modder
swarfman64's Avatar
Question. Are you removing timing in relation to manifold pressure or just off the rpm/timing graph. I'm pretty happy these vz turbos seem sized well for tho 250.
Are you watching your get befor the turbo? A standard bike in good tune will run 1200 deg 8 inches down the exhaust at an 8000rpm cruise! Anyway, it's great to see the time and effort your putting in, it's already looking very promising.
Old January 18th, 2015, 01:54 PM   #180
garth285
KAWASAKI GURU
garth285's Avatar
Right now I have only been tuning WOT so from about 70% throttle and up and rpm based as well but I am also looking at my bosot pressures and what RPM's I'm seeing certain boost levels.
I think the VZ turbos are almost spot on for the ninja 250, at decently low rpm's it starts building boost.
Heres what boost pressures I'm seeing on the stock wastegate.
4,600 - 2.5psi
5,000 - 3.5psi
5,500 - 7.2psi
6,000 - 9.5psi
7,000 - 9.9psi
8,000 - 10.5psi
9,000 - 11.9psi
10,000 - 11.9psi
I am waiting for my EGT probe to come in and I'lkl start running that as soon as its in. For now I have no idea what EGT's I'm seeing
I may take the bike for a spin around the block and see if it wants to rev out with the decreased timing and see what it does.
Old January 18th, 2015, 02:02 PM   #181
garth285
KAWASAKI GURU
garth285's Avatar
Without wastegate connected lol
4615 - 2.59
5128 - 4.83
5641 - 9.48
6154 - 12.54
6667 - 14.83
7179 - 17.29
7692 - 20.52
8205 - 23.36
8718 - 25.22
9231 - 25.69
9744 - 25.95
10256 - 24.70
Old January 19th, 2015, 08:32 AM   #182
garth285
KAWASAKI GURU
garth285's Avatar
@Racer x - I have been doing some research about the coils, I think the 300's will be fine, they are used in the 1000's but the looking at the peak voltage on the primary side of the stick coil its 90 Volts. The Kawasaki H2 which can make up to 300hp uses a coil that produces 100 Volts.
Hayabusa's which when turbocharged or using a lot of nitrous only have 80V of peak voltage so I think the coils will do!
Did not have time to ride the bike yesterday but hopefully can hop on it tonight and give it a spin.
Old January 19th, 2015, 10:38 AM   #183
Racer x
Racer x's Avatar
Any idea what the stock 250 peak at?
Old January 19th, 2015, 11:17 AM   #184
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I want turbos
Old January 19th, 2015, 12:11 PM   #185
garth285
KAWASAKI GURU
garth285's Avatar
Service manual states peak voltage on the 08-12 250 is 223 Volts.... hmm maybe because its not a stick coil it doesnt need as much.
Old January 19th, 2015, 01:18 PM   #186
Racer x
Racer x's Avatar
When I was developing my nitrous system I hit a wall powerwise. Like just over 40 hp rich or lean it was just not making more power. After changing to stick could it went ti 50 like nothing.
Old January 19th, 2015, 01:29 PM   #187
garth285
KAWASAKI GURU
garth285's Avatar
yeah I know the older coils can hold you back. I found the ZX-10r's also run 100V coils as well so I may try that, actually I may hook up the meter to the coils tonight just to make sure I'm getting good voltage and ohms.
Old January 19th, 2015, 01:41 PM   #188
Racer x
Racer x's Avatar
I use Takai coils. Getting 12000 plus RPM requires lots of coil strength
Old January 19th, 2015, 06:23 PM   #189
garth285
KAWASAKI GURU
garth285's Avatar
Tested the coils tonight, primary and secondary resistance is spot on.....
Peak voltage on both coils and both cylinders are right at 95V so that is good.
I changed out the Iridium plugs and put in CR9E's I was doing some research and some people had issues with them on some other things but I figured I'd try out some regular NGK's Gaped down to .022. No chance to ride the bike tonight, hopefully tomorrow...
Oh also checked out the crank position sensor peak voltage, was right at 4.5 Volts which is good since that's what the 300's call for, the 250 was a little less but yeah that looks good.
I feel like I'm getting closer!
Old January 19th, 2015, 07:04 PM   #190
Racer x
Racer x's Avatar
Closing up the gap is a good idea. I run 18-22 gap with CR10E. I don't like fancy plugs.
Old January 19th, 2015, 07:11 PM   #191
garth285
KAWASAKI GURU
garth285's Avatar
I was running almost a .040" gap to start with but then closed it down to .026 but didnt have any change, now set at .022" I'll see what it does.
Turbo busa guys run Iridium's all day long but different strokes for different folks lol....
Old January 19th, 2015, 08:38 PM   #192
Racer x
Racer x's Avatar
I like regular plugs because they are easy to read. Most turbo Busa guys are only pushing the engine eight or Ning seconds. Even land speed racers are going full power ten or fifteen seconds. With fifty HP about 120 mph the little ninja will be at 12000 rpm thirty seconds or more. Until things are sorted out I don't use the tiny electrode plugs.
Old January 20th, 2015, 06:02 AM   #193
swarfman64
Master modder
swarfman64's Avatar
RacerX did you use stick coils with Ecotrons ECU? I'm just looking into doing it myself.
Old January 20th, 2015, 06:58 AM   #194
Racer x
Racer x's Avatar
Yes but I never got a chance to really run the FI.
Old January 20th, 2015, 04:19 PM   #195
garth285
KAWASAKI GURU
garth285's Avatar
Well I ran the bike tonight. The problem is still there... Ran it with the cr9e plugs gaped to .022" and timing from 7k to 15k turned down to 25*.
Next test I'm going to try out is I am wondering if my fuel system is holding me back. The fuel pump and the ecu both get power from the same wire. I know if the pump is pulling to much power it could pop a fuse but I wonder if it's pulling just enough to make the ecu tweek out.
Sigh.....
Old January 25th, 2015, 08:20 PM   #196
garth285
KAWASAKI GURU
garth285's Avatar
Well I am at a wall right now with the tuning, hopefully will have someone test my ecu on a stock bike to make sure the tuning software is good.
Anyways I played around with the oil jet for the turbo. I installed the .034 jet and I am getting about 13psi at idle and 23psi at WOT up to 10,000rpm. The turbo was smoking a little on startup so with the cold oil it must be a little to high. With the .024 jet i was seeing about 10psi at idle but at WOT the oil pressure would drop up top to about 8psi. I dont want to run the oil pressure that low on those small turbo bearings so I think I will stay with the .034 jet. I think a .030 jet would probably be optimal.
Just waiting to see if its my ECU holding me back or not... will keep you guys posted :-/
Old January 25th, 2015, 10:01 PM   #197
swarfman64
Master modder
swarfman64's Avatar
If it's any help I've got a 0.060(1.5mm) jet. I'm going to increase it too. Usually only ball bearing turbos use restrictors and I restricted it initaly because of the information out there. I've never restricted a journal bearing befor now. I think it's important to drain above the oil level because these turbos only have piston ring style seals each end and not carbon face seals. Just my thoughts from past experience. Keep pushing, I luv this stuff!
What hp do yo get at about 9 psi?
Last futzed with by swarfman64; January 26th, 2015 at 02:38 AM. Reason: Again, I'm a tool
Old January 26th, 2015, 04:40 AM   #198
garth285
KAWASAKI GURU
garth285's Avatar
Well I'm not able to rev the bike out to redline so I dont know. Running on the stock wastegate I am making 9.5psi at 6,000rpm though if that helps?
Old January 26th, 2015, 05:45 AM   #199
swarfman64
Master modder
swarfman64's Avatar
I wish I could help with your rpm problem. While I'm a long way off tuned at 9psi, a standard ignition system with cr9e plugs at 0.027", 25l/r pump and a 0.5:1 rising rate reg seem to be keeping up easily. I've got a new ignition map that seems to work with EGT 1150 and AFR 12.5:1 full load. I've got an old noisy motor so in stopping at 12000rpm. It looks like your pump/reg etc setup is better than mine so its gotta be something simple.IMG_4149.jpg. I'm not saying that this map is great because its street tuned but gut feeling, but it is letting me go full noise to 12000rpm low egt and no knocking.
Old January 26th, 2015, 05:53 AM   #200
Racer x
Racer x's Avatar
Stop at 12000. The valve train start to stress after that. Yes you can rev higher. But making power after that is for later. Most of my power seems to be around there. Sort it out below that and then push for full load and full rpm power
Racer X turbo build Racer x Ninjettes At Speed 313 January 23rd, 2016 11:13 AM
Turbo? Yes, TURBO! Somchai General Motorcycling Discussion 7 December 26th, 2013 12:06 PM
250 turbo on visordown alex.s General Motorcycling Discussion 17 August 29th, 2013 12:39 AM
Turbo 250! dyeforever General Motorcycling Discussion 3 May 1st, 2011 07:07 PM
Turbo Ninja! Neema12 General Motorcycling Discussion 24 July 20th, 2009 07:31 AM
