Old May 10th, 2015, 03:22 PM   #281
garth285
KAWASAKI GURU
garth285's Avatar
Originally Posted by xenogears View Post
Updatessssss?!!
Well I have not had the time yet to get things all set but I had another thread about valve springs for the 250/300. I believe the stock valve spring may be a little weak for the 12psi of pressure I am putting on the back side of that intake valve.
Long story short I tested a good handful of valve springs and found the exhaust valve spring for the 2013-2015 ZX6r fit and I can shim them up to about 46-48psi. Stock is 22-24psi so this should be a good upgrade for valve springs.
I just got the new set of zx6r springs in on Friday but was on vacation for the weekend. I'll be getting my springs tomorrow or tuesday but I'll be getting the head ready to be swapped over. I am hoping by the end of this week or into next week I can have the bike up and running with the spare motor with stiff springs and see if this will help.
Will keep all posted when I get some results in.
If the springs don't work I'm most likely going to quit this project, just out of time and money with it
Old May 10th, 2015, 07:05 PM   #282
mgentz
Board Member
Wait...what?
Old May 14th, 2015, 12:13 PM   #283
garth285
KAWASAKI GURU
garth285's Avatar
Progress:
Cylinder head off the spare engine all set up with the 13-15 ZX6r exhaust springs on intake and exhaust. 2 shims on the intake for 46psi of seat pressure and 1 shim on the exhaust side for 38psi of seat pressure.
Just have to find the time to swap the heads over and try it out, I think I might be able to get the head off in the frame so I don't have to pull the motor, or well at least thats the plan!
Will keep all updated as usual
The wife let me clean the parts in the kitchen sink:
Parts laid out ready to be installed:
Valve/Springs installed:
Adjusted the valve clearance:
Old May 14th, 2015, 01:08 PM   #284
mgentz
Board Member
The head can come off in the frame. I've done it many times.
Old May 14th, 2015, 04:34 PM   #285
^^yepp yepp. Done it on a pregen too.
Old May 14th, 2015, 04:53 PM   #286
garth285
KAWASAKI GURU
garth285's Avatar
Thanks guys, I figured I could do so, was not sure if any of the cam chain guides would be a pain or not.
Hopefully I can get this head swapped out and give it a go again soon!
Old May 15th, 2015, 04:09 AM   #287
swarfman64
Master modder
swarfman64's Avatar
Motorcycle(s): TURBO gpx250 99 CB250/500rs Sherco290 Trials Indian 1911big base (replica)
Ahhh progress, looks really good. You realise if this fixes your issues I'll be working day and night to get mine tuned and post some figures.
[B]Come and see my turbo ninja build, dyno build and other stuff at http://swarfman64.blogspot.com.au/20...rtia-dyno.html
swarfman64 is offline   Reply With Quote
Old May 15th, 2015, 06:33 AM   #288
garth285
KAWASAKI GURU
garth285's Avatar
Lol get on it! Your turbo setup looks way cleaner than mine! I'm still worried maybe it's the headers I have made up but we'll see shortly!
Old May 15th, 2015, 07:06 AM   #289
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Hi Shawn,
good to hear your still on your way, I'm confident you'll do it.
Good luck
Old May 15th, 2015, 11:10 AM   #290
garth285
KAWASAKI GURU
garth285's Avatar
Well heres some icing for the cake, pulled the head off the motor and found what appears to be a pushed head gasket, soooooo I may have gone threw the valve spring trouble for nothing possibly. I am going to yank the rest of the motor out of the frame and swap in the spare engine since I know the gasket wasn't pushed on that bike. Wish I had the time and money to put in some 10mm studs but thats not happening.
Old May 15th, 2015, 11:48 AM   #291
bruce71198
bruce71198's Avatar
I think boosted your going to need a solution for the head gasket failure.
Old May 15th, 2015, 01:55 PM   #292
garth285
KAWASAKI GURU
garth285's Avatar
I agree. I found stud info a while back, I think the best thing would be to drill the cases to accept 10mm studs, you can get a good amount more of torque on those stud nuts vs 8mm studs. Not only that ARP makes a set of 10mm studs that will work perfect for the 250.
The spare motor with the fresh head and gasket is on the bench ready to go into the frame. Stock tq is 23lbs on the 8mm head bolts. I went in increments of 5lbs up to 30lbs total. maybe a little extra pressure will keep the head gasket in place.
Old motor is two bolts being pulled away from being out and then I'll have to throw the spare in there.
Now if this goes well and the bike is running good but I have head gasket problems down the road I'm going to probably do the 10mm studs but for now I'll see how this goes!
Old May 24th, 2015, 09:52 AM   #293
garth285
KAWASAKI GURU
garth285's Avatar
Engine is in, just finding the time here and there to work on it.
Don't judge for the mess lol...
Old May 24th, 2015, 10:30 AM   #294
Flying
Motorcycle(s): 2010 Ninja 250
Don't judge for the mess?
Here I am wanting to make messes like yours! Hoping your last tweak will keep things in place.
Old June 5th, 2015, 11:23 AM   #295
garth285
KAWASAKI GURU
garth285's Avatar
She alive....
Old June 5th, 2015, 12:11 PM   #296
garth285
KAWASAKI GURU
garth285's Avatar
Well the bike rode somewhat good, until I revved it once a little and now I have a sweet top end noise.
Going to part this bitch out, done and over it. I need to buy a house soon and need to free up money.
sigh.....
Old June 5th, 2015, 12:46 PM   #297
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
sigh.....
For real!!???
dANG.. I still not done with my project either...
but I agree.. got to try but can't be too hard headed either..
A house... yeah.. great idea.. need one too.. or my apartment needs a garage add on lol
Qomomoko is offline   Reply With Quote
Old June 5th, 2015, 03:50 PM   #298
cuong-nutz
cuong-nutz's Avatar
Originally Posted by Qomomoko View Post
For real!!???
Lol. I think most of us are in the same boat!
I would love to take on your build Shawn if only I had the moolas and time
HalfFast Racing Team
Old June 5th, 2015, 04:07 PM   #299
swarfman64
Master modder
swarfman64's Avatar
Hate it when life gets on tha way of a fun project!
I love the concept of turbo 250 but it's not that
Cost effective per HP when your doing all the development.
I've spent way more than a used 600, possibly two and
still may fail at the dyno. If you really do part it out I hope you
get good money for your bits.
Old June 5th, 2015, 05:27 PM   #300
Somchai
Freedom for Germany
Uhhhh - I'm speechless...
Old June 5th, 2015, 06:42 PM   #301
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Nooooo!!!!!!
Riding it like I financed it.
Old June 5th, 2015, 07:19 PM   #302
cuong-nutz
cuong-nutz's Avatar
Are you using a manual cam chain tensioner?
Old June 6th, 2015, 10:32 AM   #303
garth285
KAWASAKI GURU
garth285's Avatar
No, am running a stock one. I don't think it jumped a tooth as it still ran right, it may have spin a shim or could be worse.
The motor thats in the bike I'm going to pull and inspect the top end, I'll put the stock springs in the head and make sure the motor is sound and will be selling it, same with the other motor.
So if anyone needs a 250 motor let me know as I'll have 2 for sale.
Old June 6th, 2015, 10:33 AM   #304
garth285
KAWASAKI GURU
garth285's Avatar
Yeah sorry guys, I just can't keep working on this project, its been going on to long and fighting me to much, now with a 2nd baby on the way I'm going to be out of time even more.
Old June 6th, 2015, 11:50 AM   #305
cuong-nutz
cuong-nutz's Avatar
Would the setup fit behind the stock fairings?
Old June 6th, 2015, 01:05 PM   #306
garth285
KAWASAKI GURU
garth285's Avatar
The charge pipe will probably hit the right fairing but you could probably get away with a spacer. I have yet to have all the bodywork fabbed up.
Speaking of which if anyone needs race fairing let me know!
Old June 6th, 2015, 01:05 PM   #307
garth285
KAWASAKI GURU
garth285's Avatar
Old June 6th, 2015, 03:45 PM   #308
micoulisninja
modaholic junkie
how 'bout selling me your valve springs ?
check your inbox please Shawn...
ps. I am really sorry you have to give up on your project... I was looking forward to enjoy it completed... please consider just letting it rest in the garage for a while, until you get a chance to pick it up again... it's such a pity, you are so close and so much money, time and effort invested...
Old June 13th, 2015, 08:31 PM   #309
Somchai
Freedom for Germany
@garth285 may I ask you which ignition coils you use?
Old June 15th, 2015, 05:44 AM   #310
garth285
KAWASAKI GURU
garth285's Avatar
Stock Ninja 300 coils.
Old June 15th, 2015, 01:48 PM   #311
micoulisninja
modaholic junkie
which are identical to FI 250's and demand the FI (250 or 300) magnet (rotor) to work properly...
@Somchai... Roland may I ask why you ask ? I mean, if sth was wrong with Shawn's setup it wouldn't even rev up to 9 or 10k... right ?
Old June 15th, 2015, 06:05 PM   #312
cuong-nutz
cuong-nutz's Avatar
Spark weak at that RPM? Typical torque peak is around 10k on a regular motor?
Old June 15th, 2015, 06:55 PM   #313
Somchai
Freedom for Germany
Maybe this is the reason
-----------------------------------------------------------------250R-------------- 250R-FI--------------- 300
Crankshaft Sensor Resistance (Ohms) -----100 - 150-------- 100 - 150------------ 180 - 280
Crankshaft Sensor Peak Voltage --------------3.2 V or more---4.5 V or more----- 4.5 V or more
Primary Windings Resistance (Ohms) -------2.1 - 3.2--------- 1.0 - 1.6-------------- 1.1 - 1.5
Secondary Windings Resistance (kOhms) -10 - 16 k --------10.8 - 16.2 k --------6.4 - 9.6 k
Primary Peak Voltage ------------------------------223 V or more -90 V or more -------90 V or more
The FI-Models only have the ECU for controlling everything, but the 250 carbed has a separat IC Igniter for the Ignition.
Also take a look to the attached picture how the Stick coil cables are connected at the 250-FI (backwards) and 300 (left side and front).
So better don't mix electronics between the different bikes!
Old June 18th, 2015, 06:34 AM   #314
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
RIP Turbo 250: 18 Jul 14 - 5 Jun 15 *tear*
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old June 18th, 2015, 06:35 AM   #315
garth285
KAWASAKI GURU
garth285's Avatar
Who wants to take over this project any buy the turbo kit from me :-p
Old June 18th, 2015, 10:49 PM   #316
Hasersys
Hasersys's Avatar
Motorcycle(s): Have owned Ninja250,EX500,Xj650,RD250,XV750
What are you doing with the rest of the bike just curious?
Hasersys is offline   Reply With Quote
Old June 19th, 2015, 03:41 AM   #317
garth285
KAWASAKI GURU
garth285's Avatar
Selling everything
Old June 19th, 2015, 07:58 AM   #318
Hasersys
Hasersys's Avatar
Dang, well I am right down the road and I am in need of rear and front wheels. preferably with rotors on them, how much? Not sure what I can affored at the moment just got back from Key West, but very interested.
Old June 19th, 2015, 08:02 AM   #319
garth285
KAWASAKI GURU
garth285's Avatar
I'm selling the set complete with rotors, spacers, metal valve stems and BT-003 tires 110/70 up front and 140/70 in the rear. Tires have about 50 miles on them at the MOST.
Asking $450 for the set but if your local I can make you a better deal on them.
https://www.ninjette.org/forums/showthread.php?t=233439
Old June 19th, 2015, 08:04 AM   #320
Hasersys
Hasersys's Avatar
Ok I will pm you
Racer X turbo build Racer x Ninjettes At Speed 313 January 23rd, 2016 11:13 AM
Turbo? Yes, TURBO! Somchai General Motorcycling Discussion 7 December 26th, 2013 12:06 PM
250 turbo on visordown alex.s General Motorcycling Discussion 17 August 29th, 2013 12:39 AM
Turbo 250! dyeforever General Motorcycling Discussion 3 May 1st, 2011 07:07 PM
Turbo Ninja! Neema12 General Motorcycling Discussion 24 July 20th, 2009 07:31 AM
