Old May 24th, 2009, 10:56 PM   #1
headshrink
headshrink's Avatar
What do you think of my tire wear?
This picture is of my front tire (the better OEM one). I returned today from a 134 mi. ride (mostly twisty), and noticed the wear at the edge was noticeably rougher than the rest, which is generally always smooth. Any ideas what this could mean?
Also, I am wondering why the "chicken strip" is significantly larger on this tire than on the rear (rear is ~ 1/2"). Is this normal?
Old May 24th, 2009, 11:01 PM   #2
that's the reason.
my front chicken strip has always been wider than the rear, so from my experience, I'd say it's normal.
Old May 24th, 2009, 11:06 PM   #3
Snake
Snake's Avatar
Is your front tire properly inflated? It could use more air if the chicken stripe is that wide? Justa guess on my part.
Old May 24th, 2009, 11:19 PM   #4
define properly. my tire pressures are set to what I want and checked regularly, if that's what you're asking.
Old May 24th, 2009, 11:25 PM   #5
headshrink
headshrink's Avatar
Yes, the tire pressure is correct. The tire is somewhat cupped from being under-inflated, but I have since taken corrective action.
Kelly, are you saying it is the twisty, or the long ride (or both)? Also, why would it be rougher than the rest? I don't recall ever seeing marks on the tire this rough. I usually look after every ride, at least casually. It isn't the first twisty ride I've done, but it was the longest twisty. I was also working on hanging off my bike, so figure it was actually leaning a little less than it has when I was primarily counter-steering and giving it weak leans. I don't know if that is important to mention, but thought I would just in case.
Old May 24th, 2009, 11:32 PM   #6
...the twisty part.
The more you work the sides of the tire in turns, the more it will have that type of rough texture. If the speed was higher than normal through the turns, that would account for it. Look at some pictures of racing bike tires after a track day... they are much worse than that. Think of it as making use of the bike as it was meant to be used. No worries, just ride!
Old May 24th, 2009, 11:39 PM   #7
headshrink
headshrink's Avatar
I rolled-up on a Ducati 998, a couple of CBRs, and something else, as they where preparing to launch through the twisties. Let me tell you, I showed these boys how to ride, and how to ride for significantly less $$$ and still look gooood (I went right and they went left). ;D
Old May 25th, 2009, 12:23 AM   #8
Snake
Snake's Avatar
Way to go!
Old May 25th, 2009, 03:00 AM   #9
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
That is how my Dunlop GT501 looked before it was replaced at about 12500kms (wear pattern), the tread was rough like that after a hard ride over the twisties.
In fact I believe that is also a Dunlop GT501?
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old May 25th, 2009, 09:54 AM   #10
gizmogamez
gizmogamez's Avatar
Motorcycle(s): 2009 Ninja 250R SE Green
my friends tires always look like that after a track day
gizmogamez is offline   Reply With Quote
Old May 25th, 2009, 03:00 PM   #11
HKr1
IC2(SW)
HKr1's Avatar
Tire looks normal to me. The rear tire gives a bit more(contact patch wise) than the front. < You know for chicken strips, front just shows you have some lean in reserve
Really? Heres my tires after one track day last weekend on my bike
Old May 25th, 2009, 06:02 PM   #12
headshrink
headshrink's Avatar
My 12mi. (one way) commute seems to have tamed the rougher spot.... it looks a little bit smoother now.
Old May 27th, 2009, 04:03 PM   #13
stroked59
Motorcycle(s): 08 Ninja 2505
hkr1... what did you pay for the rear sprocket and where?....
stroked59 is offline   Reply With Quote
Old May 27th, 2009, 04:51 PM   #14
M-Oorb
M-Oorb's Avatar
Motorcycle(s): 2008 250r (Fastest Color)
If your asking because you want to put them on a 250...well those just won't fit as I believe that bike is an r1
Posted via Mobile Device
M-Oorb is offline   Reply With Quote
Tire wear article subxero General Motorcycling Discussion 7 February 26th, 2014 07:57 AM
tire wear life for fat people pb3 2008 - 2012 Ninja 250R Tech Talk 22 October 28th, 2012 04:11 PM
BT-16 tire wear cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 2 April 17th, 2012 09:04 PM
Possible Tire Wear Issue? Zyconic17 Ninjettes At Speed 6 March 23rd, 2012 09:07 PM
Chicken strips and uneven tire wear? Raybot 1986 - 2007 Ninja 250R Tech Talk 6 October 13th, 2010 11:41 AM
