Old March 24th, 2015, 04:33 AM   #1
Jason5885
Jason5885's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r FI
What's your chain/sprocker setup?
I'm buying new chains/sprockets. I've read the ''What replacement chain/sprockets should I consider?'' article on the wiki.
I'm so torn because on the one hand i love the look of the Gold 'alloy' aluminium adonized sprockets. But I've been warned against them for street use.
I've found an AFAM Steel chain and sprocket kit in stock size.
http://www.demon-tweeks.co.uk/motorc...vy-duty-x-ring
This is what i've decided on at the moment.
Does anyone use the aluminium sprockets for street use? if so how do they hold up? do they last as badly as i'm told?
Thanks in advance guys. (posted this on reddit too incase anyone see's it and wonders)
Jason5885 is offline   Reply With Quote
Old March 24th, 2015, 05:05 AM   #2
FBR_BDavis
I can't quote yet on the durability of aluminum sprockets vs. steel as I've only just installed a Vortex CAT5 43T aluminum rear sprocket.. What I will tell you is that the 43T rear sprocket feels so much better and seems to smooth the ride out a bit over the stock 45T rear..
Just like any part on any vehicle, the durability is based on how you use and abuse the part.. If you're really that in love with the gold look, I say go for it.. It is a relatively inexpensive part and also easy to swap out when the time comes.. Good luck in whatever you choose!!
FBR_BDavis is offline   Reply With Quote
Old March 24th, 2015, 05:29 AM   #3
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
I got the D.I.D. chain kit off amazon.
http://www.amazon.com/dp/B00G9TJX6I/..._M3T1_ST1_dp_1
Old March 24th, 2015, 05:44 AM   #4
verboten1
verboten1's Avatar
MOTM - June '15
Primary drive x-ring chain, JT steel sprockets
aluminum has never been robust enough for me
Ride more, worry less.
Last futzed with by verboten1; March 24th, 2015 at 07:16 AM.
Old March 24th, 2015, 05:54 AM   #5
Ghostt
Ghostt's Avatar
Steel for the street, DID chain JT sprockets +1/-2
violente et ignorantia
ZX-2R BLOG
Old March 24th, 2015, 06:25 AM   #6
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
You definitely want a steel tooth sprocket for the street. If you want to add some bling though check out supersprox, that's what I run on my supermoto. http://www.supersproxusa.com
Old March 24th, 2015, 07:01 AM   #7
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
With all your comments please keep in mind that Jason's Ninja is FI, so the sprockets are:
14T front and 43T rear.
Jason maybe get a 15T for the front and then from 42T to 47T what ever you like as rear but from your selection check for the length of the chain (there are calculators for this in the web).
Old March 24th, 2015, 07:38 AM   #8
Jason5885
Jason5885's Avatar
Was just about to post this, 43 in the rear stock over here.
Thanks for the advice guys, looks like the general concensus is to go with steel, and X ring, difference in price between O ring and X ring is pretty negligable over here.
Old March 24th, 2015, 01:11 PM   #9
Ghostt
Ghostt's Avatar
Whichever chain you pick, remember that proper maintenance of the chain is the key. Regardless of X, O, or no ring chains
ZX-2R BLOG
Is 415 Chain Setup Better? krolinked 2008 - 2012 Ninja 250R Tech Talk 1 July 19th, 2012 05:40 PM
Group buy on proven 415 chain/sprocket setup!!! Order Ninjettes At Speed 103 September 27th, 2011 06:33 PM
[webbikeworld.com] - Chain Pickle Motorcycle Chain Cleaner and Degreaser Review Ninjette Newsbot Motorcycling News 0 April 1st, 2011 04:22 AM
Racing: Tires & Chain/Sprocket setup... Order Ninjettes At Speed 30 March 4th, 2011 11:26 AM
Race sprocket + chain setup? Order Ninjettes At Speed 1 September 21st, 2010 11:23 PM
