Old April 1st, 2015, 03:06 AM   #1
Jason5885
Jason5885's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r FI
Question Strange Idle Issue
Something I've been meaning to ask you guys for a while now. Firstly, my bike is Fuel injection before anybody goes on about carbs.
Ever since I got my Bike Dyno'd, Whenever I start up the bike idles as should at ~2k Revs...
Then when i begin to drive and turn the throttle the bike revs climb and go up to say 5/6k (only if i turn the throttle) and stay there even when i let go of the throttle, and if i let go of the clutch i would be propelled forward. I have to control it by going hard on the brakes or by just pulling the clutch in and letting it rev high.
Once it warms up after around 5 mins however, this doesn't happen.
So basically, my bike becomes very dangerous at start up if i just get on and ride. It's 100% temperature related, but i've no idea how to fix it, this never happened before when it was stock.
Any Ideas?
Jason5885 is offline   Reply With Quote
Old April 1st, 2015, 04:02 AM   #2
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Hi Jason, many guys in Germany had the same symptom and this is no problem.
When I remember it correct then in the manual it's written to get the Ninja warm-up at least for one minute before you start to ride and all the guys in Germany didn't have this no more after they did just this - warm her up.
Some also had to correct the idle-rpm to 1250 +/- 50 rpm.
By the way I never had that symptom, because I start her then take my helmet, put the gloves on and then I start riding - always fine.
Old April 1st, 2015, 08:31 AM   #3
Ghostt
Ghostt's Avatar
Throttle position sensor maybe?, or another sensor? Sorry not up on my FI motos.
If it was car that's what I'd be looking at, air temperature sensor? Along with what I've already stated above, and plug up to the ECM and see if there's any error codes.
Good luck mate.
violente et ignorantia
ZX-2R BLOG
Strange high idle issue. Terraninja 1986 - 2007 Ninja 250R Tech Talk 40 April 8th, 2015 06:30 PM
Strange choke issue? archaeofreak 1986 - 2007 Ninja 250R Tech Talk 4 February 25th, 2015 03:54 PM
Strange Carb issue n4mwd 1986 - 2007 Ninja 250R Tech Talk 42 August 26th, 2013 06:05 AM
Idle issue djjontran 1986 - 2007 Ninja 250R Tech Talk 27 August 18th, 2013 09:00 AM
idle issue PEN25 1986 - 2007 Ninja 250R Tech Talk 10 June 30th, 2013 02:14 PM
