Old August 16th, 2015, 05:27 PM   #1
Timpo
Motorcycle(s): 2013 Ninja 300
Arrow JE High Compression Piston Kit (13.5:1 compression, 356cc displacement)
Hi everyone,
I was wondering if it's possible to install Ninja 250R piston on our Ninja 300 but I could not get a definite answer from Ninja 300 Forum.
http://www.kawasa***************/for...placement.html
Anyways I decided to come here and see if anyone knows anything.
Looks like piston ring is the problem?
**EDIT**
I just tried to link the thread that I was referring to, but this forum won't let me.
Timpo is offline   Reply With Quote
Old August 17th, 2015, 05:37 AM   #2
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I am not 100% certain but I think that the 250 and the 300 pistons have a different wrist pin to top of piston measurement. So no they will not work.
Old August 17th, 2015, 04:54 PM   #3
micoulisninja
modaholic junkie
Originally Posted by Timpo View Post
Hi everyone,
I was wondering if it's possible to install Ninja 250R piston on our Ninja 300 but I could not get a definite answer.
since I have been working a lot on both of these engines, there are a few things you are probably overlooking...
first of all the 250 has an aluminum block with iron sleeves while the 300 has an all-aluminum block with nikasil coating, which is expensive to replate if overbored and very few companies are able to do it reliably. The kind of work you are looking for would be custom-only, so even more costly...
you would also have to fit rings made for nikasil-plated aluminum, the ones made for iron sleeves would scratch the block to destruction...
second is the fact that con rods are same thickness but not the same length, the 300's being quite shorter... piston pin is same OD but quite narrower...
like subxero said, pin to piston deck is different, head gasket on 300 is a triple "sandwich type", almost 5 times the thickness of the 250's single metal leaf...
apart from those major differences and difficulties to overcome, there other details that also need special modding...
I am not saying it is impossible, I am saying it would cost you more than a new 300 for a result that would still be much less than... half a ZX-6...
I was about about to go for that kind of build but soon realised that it was a mistake all along, mostly because the 250's casing cannot take larger, stronger studs, the oil cooling is inadequate and there was the head with its tiny valves and soft springs and the TBs and so on...
So, since I am a modaholic, I got a 300's engine, the 32mm TBs, and ordered an overbored all-aluminum 67mm aluminum block (by the way JE or wiseco make up to 66mm, that is +4mm on either 250 or 300, the +6mm is simply a mistake at their site, so if put on a 300 crank it would be about 335cc...)
The financial crisis thing going on over here has put me to a stop at the moment but I am about to catch up by early September...
needless to say that this is not cheap, it could be used to buy me a 300 with several extras, since there is much head work, springs, modded rods, pins and pistons off a '09 ZX-6R...
garth285 who was really close to building a turboed 250 helped me choose the springs and gave me ideas...
https://www.ninjette.org/forums/showthread.php?t=223351
cuong-nutz is the master of information... you will verify most of my writing there and get very useful data...
https://www.ninjette.org/forums/showthread.php?t=180069
Somchai is always inspiring and his huge experience is precious, contact him or check out his posts...
Bruce71198 has built a super 335cc engine based on a 250, check out his build...
https://www.ninjette.org/forums/show...&highlight=335
you can get ideas by checking out what I have done so far, maybe the difficulties I have encountered might give an idea how hard that kind of project really is... will update soon with progress...
https://www.ninjette.org/forums/show...=198145&page=3
Old August 18th, 2015, 11:48 AM   #4
APEmike
Motorcycle(s): 2014 Ninja 300
I know how to make it happen.
Its a matter of finding the difference in wrist pin height and making up for it with a spacer plate between the block and upper case. Spacer plates are custom, but not expensive. As for boring and replating Nikasil bores goes, I deal with it daily. Its a long-ish process though where I work but its not hard, nor OVERLY expensive.
The other think you need to worry about is engine balance. New pistons dont weigh the same as stock pistons so you will have to get the rotating assembly re-balanced. A gram or two can make a pretty big difference in balance at 13,000 rpm.
Gaskets and a spacer plate are really no trouble at all to have made.
The trick to more power however is all in the head, and our problem is that the valvetrain materials are junk. They werent made for performance, they are cheap, lawnmower grade, welded valve head-to-stem low quality steel junk. I am currently working on trying to find a way to make some real race quality stainless valves, but it is slow going.
The way to go would be to find a real good spring (i know a couple different ones that work), titanium retainers (that nobody makes, yet) stainless valves(working on them), in standard or oversize depending on application, porting from someone who knows what they are doing(my friend/co-worker), some more compression as it is way too low for a modern street motorcycle(JE or Wiseco, pick one for the sticker you like more), and a cam to match the work and what the bike is being used for. Web Cam will be happy to make you a custom grind.
Old August 18th, 2015, 05:14 PM   #5
micoulisninja
modaholic junkie
Mike pin to piston deck (on squish band) is 3.5mm shorter compared to 250's. Comparing stock parts. I measured 250's high comp pistons to have up to 1mm more material on squish depending on their base compression ratio values, could be up to 4.5mm for a 13,5:1 piston
So that can be easily overcome by a base spacer...
Nice idea, I thought so myself, but when I checked thoroughly piston travel, I noticed that a spacer larger than 1-2mm would leave the bottom of the piston skirt go under the block (and I am talking about the 250's short skirted high compression pistons, the 300's stockers are on the limit as they are).
The cylinder block (and most importantly its walls) is of the exact same height while now the piston has a longer travelling distance up and down and I bet that is one of the main reasons their 300 piston design has shorter skirts and still reach the bottom edge of the walls...
Anyway,measuring the 300's open-decked cylinder block wall, I found it to be about 4.5mm thick...
So these observations make me wonder about a couple of things, I hope you can help me understand better...
1. How much overbore do you believe would be reliable for that kind of cylinder wall thickness ? +2mm ? And if only that much, do you believe it is really worth the process ? I mean for the 250's iron sleeves it is probably good value for money (and extra power), but for aluminum nikasil replating on a 300 ?
2. What could be done if the available high-comp, short-skirted 250 short-stroke oriented pistons almost have their bottom tips coming out and under the block walls inside the 300's longer piston travel even without using any base spacer ?
Maybe your answers will help me make a breakthrough with my project, so I am really looking forward to your post, thank you in advance !
Old August 18th, 2015, 06:43 PM   #6
Timpo
Thanks guys for all the detailed response!
Sounds like there's gonna be a lot of work.. and I'm not exactly a gearhead so I don't think I could do all the modifications to make it happen.
If I were to look for more power, it would just make more sense for me to get a ZX-6R I guess.
Old August 20th, 2015, 03:13 PM   #7
APEmike
You would be surprised at how much skirt can come down before there is an issue. Some of the blocks we have done get the pistons going WAY down in the bore. +11mm stroke Hayabusas come to mind. 9mm of their 27.5mm skirts will be below the bore. Not a small amount, and yet they live and make SERIOUS power. Its all about getting the clearances right.
2.5mm leaves it awfully thin in my opinion for something that is expected to live a good life. A 'hours' engine, sure, go for it. Not a good option for the street. Stock or 1mm over should work well.
The 250 block is the way to go for BIG pistons. Just remove the stock sleeves, bore out the block, put larger sleeves in, bore the upper case to match the new sleeves, and bore the sleeves for the new pistons. Thats 45 year old tech. Simple and cheap. Downsides are it will cast just as much to do it for the first time as just having a Nikasil bore done, after that its stupid cheap. It wont last as long between having to re-ring and de-glaze. Heat transfer sucks with iron sleeves compared to aluminum. Nikasil wont be as cheap but the material is MUCH more durable, and heat transfer is substantially better. Not to mention its a lighter block...
I really wouldnt bother with extra CCs, as there isint a LOT of power to be found there. Its all about the head and cams, and getting the lower end to last.
-Mike
Old August 20th, 2015, 06:54 PM   #8
micoulisninja
modaholic junkie
-Mike
To be honest I didn't know that having the pistons' bottom part of the skirt is not a major issue and am I glad to hear that !!
As for the rest, I just couldn't agree more !!
Hope you find some good valve for replacing stock, they are indeed of low quality...
Old October 12th, 2015, 07:21 PM   #9
mgentz
Board Member
true dat....I know all too well
Spare engine--high compression build? kxpower? 1986 - 2007 Ninja 250R Tech Talk 20 March 31st, 2014 10:00 AM
What is compression Racer x 2008 - 2012 Ninja 250R Tech Talk 22 March 15th, 2013 02:44 AM
277 Kit/high Compression piston jasle 2008 - 2012 Ninja 250R Tech Talk 6 November 30th, 2012 08:20 PM
Compression gauge kevlar250 1986 - 2007 Ninja 250R Tech Talk 4 November 2nd, 2011 06:15 AM
High or Low Compression Yellow Submarine 2008 - 2012 Ninja 250R Tech Talk 13 March 4th, 2010 08:49 AM
