Old July 14th, 2009, 11:40 AM   #1
Hokie11
Motorcycle(s): Black 2009 Kawasaki Ninja 250R
bleeding brake fluid... still usable?
Im putting on my woodcraft rearsets + woodcraft brake line, which requires me to bleed brake fluid and replace the bolt... bike only has 300 miles on it, could i reuse the brake fluid or should i just go to the store and get some more? if so, any specific type of brake fluid i should get that would work best?
Black 09 Ninja 250R|Shogun Crash Kit|Woodcraft Full Rearsets|Proton Flush LEDs|De-Snorkeled|Shimmed|K&N|Red Rim Tape|ProGrips|Puig|10K HIDs|15T Front
Hokie11 is offline   Reply With Quote
Old July 14th, 2009, 11:47 AM   #2
yes, you should replace whatever leaks out with fresh fluid. your owner's manual lists the proper fluid to use.
Old July 14th, 2009, 01:20 PM   #3
Snake
Snake's Avatar
Never reuse brake fluid as it gets contaminated when flushed.
Old July 14th, 2009, 01:35 PM   #4
Hokie11
ah ok
Old July 14th, 2009, 07:27 PM   #5
Hokie11
okay, i couldnt get my brake line to bleed according to the method in the manual... i hooked a hose up to the bleed valve on the caliper and took off the reservoir cap... it says diaphragm also, where is that? nothing was coming out of the hose, so i am obviously missing something and the only part i couldnt clearly i.d. is the diaphragm
yes im a noob, just trying to learn to be more hands on, be nice
Old July 14th, 2009, 08:02 PM   #6
Wes
Wes's Avatar
Motorcycle(s): EX250-F14
The diaphragm is a rubber bit on top of the fluid in the master reservoir. If the cap is like the -F bikes, it might be stuck in the lid or something separate. If the cap is a round one like a modern sportbike, it's probably built into the lid.
When you say "the fluid isn't coming out", have you opened the bleeder and squeezed the brake lever?
Tip: stick the end of your hose into a glass jar filled with an inch or two of fresh brake fluid. This way, if you screw up the bleed, you limit the amount of air you can accidentally suck back in the system.
Wes
Wes is offline   Reply With Quote
Old July 14th, 2009, 08:44 PM   #7
Hokie11
ah, do u mean by unscrewing the bleed valve itself? i figure just by having a cap on there wasnt that secure... ill have to try that in the morning
Old July 14th, 2009, 09:02 PM   #8
Hokie11
ok so i got it to bleed.... but VERY little... then it sucked back some air because the whole hose never got filled to push out all the air
how do i keep it flowing out? i held down the brake, but it bled a little then just stopped... normal? should i just start filling the reservoir with fluid now and itll bleed more?
Old July 14th, 2009, 09:07 PM   #9
http://www.spokes-women.org/Technica...e_bleeding.htm
Old July 14th, 2009, 09:49 PM   #10
Hokie11
that worked great! thanks kelly!!
Old July 14th, 2009, 09:54 PM   #11
the magic of Google!!
glad it work out for ya.
Brake bleeding bliss Gurk General Motorcycling Discussion 6 July 2nd, 2014 08:35 PM
Rear Brake Bleeding Trouble dwright0723 2008 - 2012 Ninja 250R Tech Talk 14 May 7th, 2014 07:26 PM
Brake Bleeding Question kennetht 2008 - 2012 Ninja 250R Tech Talk 16 March 4th, 2014 10:55 AM
Bleeding brake ? caineroad 2008 - 2012 Ninja 250R Tech Talk 3 September 24th, 2013 02:53 PM
Rear Brake Bleeding Problem (2011 Ninja 250) - Caliper Valve Sucks Back Fluid/Air MovingUp7 2008 - 2012 Ninja 250R Tech Talk 3 January 28th, 2013 08:46 AM
