July 17th, 2009, 05:29 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): Black 2009 Kawasaki Ninja 250R Posts: 153
Air filter now or later?
Ok, so I was just ordering some items online, oil filter, oil, maxima chain wax, and thought I would throw in a K&N air filter...
Is it worth installing now? Do I need to get anything else first? I do plan on getting the AreaP exhaust and jet kit, but that is way way later... last on my list really because of the price... Do I need to shim the needles, remove snorkel or any of that to make the most of the air filter? I kinda want to do all the little things first, and get the exhaust last If it really doesn't do any good, I'll just wait.
Black 09 Ninja 250R|Shogun Crash Kit|Woodcraft Full Rearsets|Proton Flush LEDs|De-Snorkeled|Shimmed|K&N|Red Rim Tape|ProGrips|Puig|10K HIDs|15T Front |
July 17th, 2009, 05:39 PM | #2 |
how long before you get the exhaust?
July 17th, 2009, 05:55 PM | #3 |
no idea really... could be this fall, could be next spring.. not within next 3 months
July 17th, 2009, 05:59 PM | #4 |
the K&N will most likely make your lean running bike run just a bit more lean. I'd suggest doing your bike in stages.
filter, desnorkel and shim now. exhaust and jet kit (or add 1 or 2 more shims) when you get it at that later date. |
July 17th, 2009, 06:02 PM | #5 |
kelly, perfect answer! ordering now
you rock! thanks!
July 17th, 2009, 06:03 PM | #6 |
the K&N R-0990 in your sig... is that different from a factory replacement filter since you removed the airbox? i planned on ordering from motorcycle-superstore.com
http://www.motorcycle-superstore.com...ir-Filter.aspx is this the same? $55 seems a bit high
July 17th, 2009, 06:11 PM | #7 |
the R0990 filter is a direct bolt onto the back of the carbs after you remove the airbox. If you still have your airbox, you want the factory replacement filter so you can install it into your stock airbox.
pic of 0990 filter... |
July 17th, 2009, 06:15 PM | #8 |
looks very nice... but that DIY to remove the airbox did not look fun.. i think ill skip that
thanks a lot!
July 17th, 2009, 06:17 PM | #9 |
This is an air filter??? | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 15 | July 15th, 2013 11:27 AM |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
Anyone know an air filter I can replace the OEM filter with? | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 5 | July 22nd, 2012 09:34 AM |
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su | Ninjette Newsbot | Motorcycling News | 0 | June 11th, 2012 06:00 PM |
What air filter are you using? | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 14 | April 14th, 2012 12:40 AM |
