September 4th, 2016, 03:31 PM | #1 |
Newgen tank on a pregen?
Picked up a pregen ex250 for dirt cheap... The plastics were trashed, and the tank is junk. So i'm gonna do a streetfighter look for it. I have been having difficulty finding a replacement fuel tank. So, my question is, will a newgen tank bolt up to a pregen frame? Don't care if it looks the best... Just will it fit?
September 4th, 2016, 09:22 PM | #2 |
Join Date: Apr 2016 Motorcycle(s): Ninja250-3x; CBR600 & R6 (track bikes); lots of dirt stuff Posts: 25
NO, won't fit
The tanks are about 2 inches different in length, with the newgen being longer.
They have to fit above the top tube, which is very different on each model both in angle and length. If you have metal working tools and are a decent tin-man, you could make it work. Probably about 10 hours of work through primer. Hope this helps, Cheers, |
September 4th, 2016, 10:59 PM | #3 |
Thanks, no, that probably won't work at all then... I am a diesel tech, not a metal fab guy. Thanks though!
September 5th, 2016, 07:28 AM | #4 |
A little more info please
I'm a little confused. You have a pregen bike that needs a new tank, and found a newgen tank. Right?
If so, are you looking for a pregen tank? I have one, but the inside is rusty. It might work for you if that's a help. |
September 5th, 2016, 09:43 AM | #5 |
was wondering if they would fit because there are a loy more newgen tanks available then there ate pregens... There is one up on ebay right now the guy wasts $150 for it, and it's rusted and damaged!
September 5th, 2016, 02:53 PM | #6 |
Send me a PM
Jeff,
PM me. Jim L |
September 9th, 2016, 07:11 AM | #7 |
Join Date: Jan 2015 Motorcycle(s): 2000 EX-250; several other years of the same Posts: 460
Did you see this listing? $75 with free shipping....
http://www.ebay.com/itm/252462669787...%3AMEBIDX%3AIT
... can't stop updating the bike! |
September 9th, 2016, 09:55 AM | #8 |
maybe a better buy
Jeff,
The above post may be a better buy for you than my tank. Cheers, Jim |
Newgen vs pregen handlebar | peperino | 2008 - 2012 Ninja 250R Farkles | 7 | February 9th, 2016 02:55 PM |
NEWGEN Gas Tank on PREGEN | vman1313 | 1986 - 2007 Ninja 250R Tech Talk | 11 | May 10th, 2014 04:09 PM |
Newgen exhaust on pregen? | !!(0_o)!! | 1986 - 2007 Ninja 250R Tech Talk | 26 | April 16th, 2013 08:26 PM |
pregen engine in newgen? | alex.s | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 19th, 2012 11:09 PM |
Pregen vs. Newgen | ambudriver | General Motorcycling Discussion | 7 | May 7th, 2011 07:36 PM |
