Old January 21st, 2017, 10:34 PM   #1
Fashionrider712
Motorcycle(s): Ninja 300, zx6r, drz400sm
My custom 4 piston caliper bracket.
I didn't really like the oem calipers and I had a spare set of zx6r calipers and master. so I figured I could just use them on my zx3. I need to get a smaller master as the oem zx6r one is sized for 2 4piston calipers. But she still works decent enough. I did have to get a custom length line since the caliper is sitting lower than Oem.
Fashionrider712 is offline   Reply With Quote
Old January 22nd, 2017, 06:00 AM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Nice, a lot of mill work there. Your mill?
Old January 22nd, 2017, 07:12 AM   #3
How is the feel, compared to stock?
It's interesting that you made a bracket to get rid of the stock caliper, while it's a common mod for an old Kaw H2 or H1 to use an EX caliper with EBC HH pads and its matching master cylinder to give an old triple a modern feeling front brake. I make the adapters by getting 3/16" thick stainless laser cut, and finish the parts in my mill.
You can see a familiar caliper on this custom that has an H2 engine in an H1 frame.
Old January 22nd, 2017, 04:23 PM   #4
Fashionrider712
Yea, I have a cnc mill in my house.
Old January 22nd, 2017, 09:53 PM   #5
mgentz
Board Member
interesting...how does it perform?
@rojoracing53 was able to mount his a little higher. I'm not sure how the leverage or position affects the wheel or braking as I'm too tired and too dumb to think of that math right now....
Originally Posted by rojoracing53 View Post
Forgot to post up the final product. I've been using it for 9 months now with zero problems a d all kinds of compliments. Also worked great for my trackday at Laguna a few months back.
Old January 22nd, 2017, 10:04 PM   #6
The height won't make any difference, as long as the pads are aligned with the disk OK.
Old January 22nd, 2017, 10:14 PM   #7
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
My rotor is also 30mm larger in diameter which changes the tolerances for caliper placement.
Old January 26th, 2017, 12:00 AM   #8
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Nice work
Old February 27th, 2017, 06:44 PM   #9
Fashionrider712
If I had a bigger rotor I could probably mount it higher. But I didn't want to lose to much threads.
4 Piston Brake Caliper Adapter Bracket Upgrade SV Racing Parts Motorcycle-related 30 February 17th, 2022 05:59 PM
Stripped HEX bolt on rear caliper bracket Guilty 2008 - 2012 Ninja 250R Tech Talk 7 February 4th, 2017 05:13 PM
WTB custom caliper bracket UFOmoplata Items Wanted 0 February 12th, 2016 07:28 PM
Pushing the piston in on caliper Hero Danny General Motorcycling Discussion 14 June 1st, 2015 08:35 AM
Brake Caliper Bracket Torque...Bit Of A Weird One GiGs 2008 - 2012 Ninja 250R Tech Talk 2 September 7th, 2013 09:14 PM
