Old September 17th, 2009, 12:29 PM   #41
Rayme
Rayme's Avatar
Motorcycle(s): '04 sv650s
Be sure to take the battery inside. It doesn't make much sense letter it freeze. I usually bring it inside the home and put on the charge for a couple hours every weeks or so. Make sure it's in a well ventilated place..not that it's any dangerous than inside a garage/baby barn...Charging a frozen battery sounds counter intuitive.
The reason the gas goes bad is because of evaporation, it's more prone to evaporate in the carbs than the fuel tank, so it's a good thing to drain the carbs so there's no gas to evaporate and leave gunky residues.
As for oil, drain your oil before winter and just put in the cheapest oil you can get at walmart and let it sit in there for winter...Then put your favorite oil before starting it.
I did all that and had zero problem starting the bikes after 5-6 months.
There's 2 types of people in this world, those who complain and those who act.
Rayme is offline   Reply With Quote
Old September 17th, 2009, 12:31 PM   #42
Greg_E
Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R
Remove battery and bring inside where it is warm, install when needed.
Greg_E is offline   Reply With Quote
Old September 17th, 2009, 01:04 PM   #43
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Check your owner's manual for what Kawasaki recommends, though I would never follow some of their suggestions based on what I've read of winter storage.
Yeah, they say to drain the tank.
They also say you should be able to "operate the fuel tap while riding without taking your eyes off the road." The fuel tap is located behind the left side cover and can't be operated with your hands anyway.
Oh, and they say to have it turned ON to drain the tank, when IIRC you drain the tank by turning it to PRI.
Old September 17th, 2009, 01:36 PM   #44
those instructions were most likely copied over from the pregen manual or some strange mixture of both. one must be really careful of things they read in those manuals and use some common sense.
Old September 17th, 2009, 09:47 PM   #45
minuslars
Motorcycle(s): '03 EX250
I just thought I'd mention that premium gas has the MOST ethanol in it. It's the ethanol that acts as the "octane booster."
It seems to me that regular gas with a bit more stabilizer would be the way to go.
That, and perhaps having the bike in a nitrogen bubble to prevent oxidation (i.e. rust) lol
minuslars is offline   Reply With Quote
Old September 17th, 2009, 10:13 PM   #46
That's another first for me. Source?
Old September 18th, 2009, 06:07 AM   #47
adouglas
adouglas's Avatar
Pfeh. Primitive. Stone knives and bearskins.
I'm thinking stasis field.
Old September 18th, 2009, 09:23 AM   #48
empire00
empire00's Avatar
Motorcycle(s): 2009 250r SE, 2015 FJ-09
http://en.wikipedia.org/wiki/Octane_rating
in ethanol fuels the ethanol acts as a octane booster.
ethanol has a RON of 116
the gasoline component is lower with the two averaging out to 91 RON for 87 octane gas.
empire00 is offline   Reply With Quote
Old September 18th, 2009, 09:43 AM   #49
MtnCruiser
MtnCruiser's Avatar
Motorcycle(s): 2 2004 Ninja 250 and 2008 VTX 1300
If you are really worried about using stabil or the effects of ethanol in the gas you can also drain the tank completely and coat the inside with fogging oil and it will be fine. A shot of fogging oil into each cylinder is a good idea also.
MtnCruiser is offline   Reply With Quote
Old September 18th, 2009, 09:49 AM   #50
I'm missing it. Where in there does it say they use ethanol as an octane booster?
Old September 18th, 2009, 10:06 AM   #51
Ethanol does in fact act as an octane booster. Federal regs require the major oil companies to include a certain portion of ethanol across their entire gasoline production. Varies by company, and has been going up each year, but a good guideline is somewhere around 6%. Many states cap ethanol usage at 10%, as many vehicles won't perform well if the percentage was any higher than that.
In areas where the refiners are using a good chunk of ethanol in their gasoline, close to or equal to that 10% rating, they end up having to use less of some of the other octane enhancers that would otherwise be necessary, as the ethanol content itself ups the effective octane rating. In other words, refiners don't go right to the ethanol as the primary octane enhancer, but if they have gone down the ethanol route for regulatory reasons, the ethanol does help the gasoline meet the expected octane ratings at the end product.
Old September 18th, 2009, 10:30 AM   #52
So, is the bolded text true?
my understanding is that ethanol fuel has the same amount of ethanol in all the grades across the board. octane additives are added proportionately to obtain the octane rating desired prior to the ethanol being added... at least that's the way it's done on island.
Old September 18th, 2009, 10:33 AM   #53
The bolded text is not necessarily true. It's not necessarily false either. The unhelpful but unfortunately more correct answer is "it depends".
Old September 18th, 2009, 10:36 AM   #54
Gee, Alex... do you have a part time job in Washington, D.C.?
Old September 18th, 2009, 11:32 AM   #55
Nope. But perhaps it would suit me. Not trying to mislead or misdirect folks, it's just that gasoline production is more complex than can be described easily. The refineries futz with things day in and day out depending on the particular nature of the crude they are running that day, the current load on the different areas of the refinery, the product mix they are trying to end up with that day, and the different pricing available and even contractual requirements they are trying to fill that day. All of that boils down to a whole bunch of different ways they can refine the crude to get it to something at the end of the line that meets whatever applicable specs they need to to call it "gasoline".
Old October 2nd, 2009, 07:27 AM   #56
Talonne
Talonne's Avatar
Motorcycle(s): '09 Metallic Diablo Black
Is Seafoam a good stabilizer for over the winter? Also, is draining the float bowls still necessary if I use Seafoam, since it claims to "clean" the carbs and liquefy gum/varnish deposits?
Talonne is offline   Reply With Quote
Old October 2nd, 2009, 08:50 AM   #57
BlueRaven
BlueRaven's Avatar
Motorcycle(s): '09 Ninja 250 Black
should the petcock be turned to prime before draining the bowls or just leave be?
I'm not small, I'm fun sized
BlueRaven is offline   Reply With Quote
Old October 2nd, 2009, 08:56 AM   #58
adouglas
adouglas's Avatar
No, I think not, but caveat... I don't have first-hand experience.
My understanding of how this works is that PRI lets gas flow out of the tank and into the bowls without the engine running. ON allows no fuel to flow until there's vacuum (caused by the engine turning).
So if you switch to PRI when you drain the bowls, it'll take a very, very, long time before fuel stops flowing, because you'd actually be draining the whole tank through that tiny little hole....
Old October 2nd, 2009, 09:01 AM   #59
BlueRaven
BlueRaven's Avatar
I always thought if i put it in prime it would cut off the flow from the gas tank. Tells you what i know but i guess i'm new at this as well.
Old October 2nd, 2009, 10:18 AM   #60
adouglas
adouglas's Avatar
PRI stands for PRIME, as in priming a pump, as in putting fluid into it.....
Old October 2nd, 2009, 10:40 AM   #61
ARF07
ARF07's Avatar
Motorcycle(s): Yamaha R6
Hey guys, I just read through this thread today, as Tennessee (at college) is going to cool down here pretty soon. There is a gas station here that has ethanol-free gas. It's more expensive, but I usually run in anyways. Does the winterizing process change at all w/ the ethanol free gas as opposed to the regular? I'm just having a tough time understanding what happens because of the components of the gas in the tank, and what happens because of the temp change.
ARF07 is offline   Reply With Quote
Old October 2nd, 2009, 10:53 AM   #62
divingtigger
Pedal Power
divingtigger's Avatar
Motorcycle(s): 2008 Ninja EX250R
Gonna be doing this this weekend. I always used Seafoam in my other toys (boats ect..) with no issue in the carb so maybe, but I'm going to drain the bowls anyways
Using Pedal Power
divingtigger is offline   Reply With Quote
Old October 2nd, 2009, 11:12 AM   #63
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
aloha,
friend of mine rides an 883 and she's deploying to the middle east for a year.
information here helped her with storage issues and she wanted me to pass along her appreciation for the knowledge we shared here.
so...THANX EH!
i love it here! uh-huh!
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old October 2nd, 2009, 01:26 PM   #64
Talonne
Talonne's Avatar
Ok... I guess I should. I am just afraid of messing something up somehow.
I will be doing this soon as well... We're getting our first snow flurries of the season tomorrow.
Old October 6th, 2009, 03:24 AM   #65
headshrink
headshrink's Avatar
The way we winterize here in CA is:
1) Start engine
2) Ride
3) Rinse and Repeat
Old October 7th, 2009, 06:39 PM   #66
Syphen
Some weird Canuck!
Syphen's Avatar
Motorcycle(s): '92 CBR250RR "Babyblade", 2008 Ninja 250R, 2001 CBR600F4i
Jessica, I stored the Ninja 250R last year by changing oil (to a cheap 10w40 oil.. amsoil in the summer only), washing it, pouring half a can of sea-foam in the tank, and filling the tank to the very brim. I run the bike for 10 minutes or so to get the seafoam well mixed and into the carbs. Turn the bike off, put it on stands and once again top the gas tank to the brim. Remove battery, kiss the bike good night and put a cover on it. Keep the battery indoors over winter and charge it periodically OR put it on a battery tender. I also store my F4i in a similar way because with the fuel injection system, there is no petcock. It will be fine.
The bike fired up within seconds when I dug it out after a 5 and a half month sleep and I've been storing bikes like this for 5 years now without issues. If a bike has a fuel petcock (my old CBR600, or my CBR250RR) then I will drain the carbs by running the bike but some people say this allows the seals in the carb to dry out. Just do it like I mention above and you will be perfectly fine.
I still like CBR's more Just kidding.
Syphen is offline   Reply With Quote
Old October 11th, 2009, 12:59 PM   #67
ScorpionNinja
ScorpionNinja's Avatar
1) Start engine
2) Ride
3) Rinse and Repeat
lucky you man!
heh
Old October 16th, 2009, 11:55 AM   #68
anomolli
anomolli's Avatar
Motorcycle(s): 2009 Ninja 250R (red)
I use a Battery Tender Jr. It trickle charges a battery when low and knows when the battery is topped off and will shut itself off to prevent overcharging. It then goes into a "maintain" mode and will charge the battery when the battery charge drops a bit while stored.
You leave it plugged in all winter and your battery stays fully charged. The kit comes with a small connector that you can install on your bike that makes plugging/unplugging the charger a breeze.
@kkim
I'm looking at the battery tender on motorcycle-superstore, but seems like there's two flavors, a 6 or a 12 volt one. Which one should be used? Thanks!
anomolli is offline   Reply With Quote
Old October 16th, 2009, 11:56 AM   #69
Plasmatoast
Plasmatoast's Avatar
Motorcycle(s): 09 250R - 08 250R - 03 250EX - 86 KLR 250
12volt should be used
Plasmatoast is offline   Reply With Quote
Old October 16th, 2009, 11:58 AM   #70
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
I'm not Kelly.... but it's a 12 volt.
Old October 16th, 2009, 12:03 PM   #71
anomolli
anomolli's Avatar
thanks very much. :-)
Old October 16th, 2009, 12:12 PM   #72
I see you got an answer. sorry, for some reason I don't get an auto notification to this thread when there was a reply until now.
good luck with your winter storage.
Old October 17th, 2009, 01:01 PM   #73
Allen
Allen's Avatar
Motorcycle(s): 08 250 Ninja
1) Start engine
2) Ride
3) Rinse and Repeat
That's been what I've been doing for years. It's never failed.
Allen is offline   Reply With Quote
Old October 17th, 2009, 05:47 PM   #74
ScorpionNinja
your lucky as hell!!! hehee
Old October 17th, 2009, 05:54 PM   #75
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Is covering the entire bike with vasoline still used to winterize it?
I've heard that if you keep the bike in the living room it will stay warm but it is hard to start and run the engine once a week to keep the gas, oil, and battery stabile.
If you live in Florida do you still have to winterize, even if you ride all winter?
Old October 17th, 2009, 08:23 PM   #76
Allen
Allen's Avatar
Let me qualify that statement........Today it was 45 deg. and drizzle. Not a great day for riding. Anyway I have the gear for it and pick my days to ride, especially during Dec. and Jan.
About 1/2 the locals winterize the other half rides.
But the idea of rubbing Vaseline all over a baby Ninja is new to me. But I'm open to new ideas..........Maybe I'll try it while the wife is at work.
Old October 18th, 2009, 06:40 AM   #77
gamma500
gamma500's Avatar
Pretty much what I have done for the last 40 years...Stabil instead of Seafoam. My experience with an empty gas tank and dry carbs has been rust and hung up float valves and dry seals even when I fogged the tank. A fully fogged gas tank will wash off some of the interior residue/scum and end up in the petcock/filter area where it evaporates leaving a gummy residue which buggers up this area and will enter the carbs when you regas up and start.
gamma500 is offline   Reply With Quote
Old October 18th, 2009, 07:17 AM   #78
divingtigger
Pedal Power
Keep saying that I'm going to winterize the bike, maybe this weekend, it will be 13 degrees c around 10 for the rest of the week...after that who knows, it has snowed off and on though
Using Pedal Power
Old October 18th, 2009, 10:30 AM   #79
anomolli
anomolli's Avatar
Does everyone here pretty much change their own oil and filter? I've been reading through this forum as well as the service manual and it seems like the initial task takes a bit of investment on my part. Meaning, i have to buy the rear stand, tools, etc. to get the job done. So i'm just wondering if people take it to the mechanic to get the oil changed and then drain the carbs and add stabilizer themselves? Or is it the culture to kind of get your hands dirty yourself?
Old October 18th, 2009, 10:51 AM   #80
gamma500
gamma500's Avatar
You can change the oil on a NewGen just with the side stand down as long as you ziptie the front brake handle down to make sure she doesn't roll when you put a little oomph to the drain plug and filter bolt. Your stock tool kit even has the wrench sizes you'll need. Don't even need to remove the lower fairings if you don't want the extra room.
Anything I can do to keep the Dealer's apprentices away from my bikes is a plus as far as I'm concerned. Check out the plier serrated marks on your fill plastic plug when you get her back cause they didn't feel like putting a piece of protector on it !
Winterizing for one day Ninja Rob General Motorcycling Discussion 50 January 10th, 2015 08:01 AM
Winterizing Question Apex123 2008 - 2012 Ninja 250R Tech Talk 2 November 12th, 2014 09:53 PM
winterizing 250's scorch General Motorcycling Discussion 10 May 13th, 2014 11:34 AM
Winterizing... emilyLOVESlime 1986 - 2007 Ninja 250R Tech Talk 18 November 2nd, 2009 10:57 PM
Winterizing your Ninjette Sailariel 2008 - 2012 Ninja 250R Tech Talk 37 December 20th, 2008 08:05 PM
