Old June 9th, 2019, 08:27 PM   #1
NaturalFlavored
Motorcycle(s): 250r
Electrical help
Ok this isn't a ninja but you guys helped me with my old ninja in the past. This is a cn250 motor when I start it, it acts like there is a drain or short somewhere. I started this bike a week or so ago no problems didn't drive it just started it to make sure it was fine.
I replaced the starter solenoid because it was clicking.
Quick video of the symptoms
https://photos.app.goo.gl/HqaimFFngL1VSgGx7
NaturalFlavored is offline   Reply With Quote
Old June 9th, 2019, 11:10 PM   #2
Is new starter solenoid also clicking?
Measure voltage at battery before hitting START. What is voltage?
Measure voltage at battery while hitting START. What is voltage?
Try this test. Jump-start bike from car with known-good battery (battery can start car). Leave car off and connect jumper cables. Wiggle jumper cables on both ends to get good bite. Try starting bike now.
Old June 10th, 2019, 06:17 PM   #3
NaturalFlavored
Motorcycle(s): 250r
I guess it's a bad battery I jumped it and it started the first time. So I checked the voltage when starting and the battery dropped to 2 volts.
It's only a 3 month battery, so I emailed the company upset.
Old June 11th, 2019, 11:36 AM   #4
What brand battery is this? Need to make note to avoid.
Also don't rule out charging system. After bike is jump-started and jumper-cables removed, measure voltage at battery again. What does it measure?
Old June 11th, 2019, 04:05 PM   #5
NaturalFlavored
Motorcycle(s): 250r
Getting a replacement battery. When the knew one gets here I'll test the voltage under load and see if it goes up at all. But thanks for the response, I never thought of checking under load. Never had problems with batteries in the past that had this outcome threw me off. Haha
Old June 11th, 2019, 07:25 PM   #6
NaturalFlavored
Motorcycle(s): 250r
Found an extra battery, threw it on the charger for an hour put it on the bike reading at 13.6volts. started right up kept the meter on and it was going up by .01 watched it for a few numbers then turned it off. Then back on. Don't know how the battery went bad.
Old June 11th, 2019, 08:09 PM   #7
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
A standard flooded lead acid battery loses about 1% of its charge per day when not in use.
90 days? Well...
Old June 11th, 2019, 08:12 PM   #8
NaturalFlavored
Motorcycle(s): 250r
Ok but I used it about a week and half before this issue. Battery was 4 months old. Stator still works as the new battery showed it did, so if a battery can go bad in 2 weeks of not using well that's pretty crappy.
need some electrical help bhalv 1986 - 2007 Ninja 250R Tech Talk 6 November 26th, 2017 03:31 AM
Electrical.. something? Cfc4life 1986 - 2007 Ninja 250R Tech Talk 7 August 8th, 2016 05:46 PM
Electrical problems? ozmani 2008 - 2012 Ninja 250R Tech Talk 16 March 6th, 2013 06:26 PM
Electrical jarred6644 1986 - 2007 Ninja 250R Tech Talk 10 February 2nd, 2012 03:46 AM
[motorcyclistonline] - New Permatex® Liquid Electrical Tape Keeps Electrical Connect Ninjette Newsbot Motorcycling News 0 February 26th, 2011 01:20 AM
