Old December 30th, 2009, 02:45 PM   #1
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
Fast blinking turn signal
'01 - The right side blinker flashes really fast, the left side is normal. Both the front and the rear lights are operating (they work/blink), but the right side flashes fast as if a light is out, but it's not.
The mods - smoked rear taillight and signals (bought off ebay) that were a complete component, and just added Asian Cycle flush front signals. The bike also has a blue LED kit (previous owner).
The first flash is at normal speed, but the second one starts flashing quickly.
Any ideas?
austexjg is offline   Reply With Quote
Old December 30th, 2009, 03:11 PM   #2
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Check the wiring and the bulbs. I heard somewhere that the faster flashing happens when it's about to go out as well to give you a sort of a warning. Don't quote me on that because I'm not sure, but I heard it somewhere. Also, if it's not very well connected, it might be fooling it into thinking it's not connected because there's so little connection. I'm no expert though, and those are the only possibilities I could think of. Good luck figuring it out.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old December 30th, 2009, 04:16 PM   #3
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
i've heard a number of problems that could cause this.
it may be an indication that the flasher may be going out.
(don't know where this is on our bikes, or if something similar)
i'd recheck that the bulbs are not loose, sockets for corrosion and wiring connections.
also heard different rated bulbs can do this but dunno bout that.
if it worked fine till yer last mod...start hunting there.
good luck
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old December 30th, 2009, 04:32 PM   #4
austexjg
austexjg's Avatar
Well the bike came with no front blinkers - it may have started when the rear was replaced, but unsure because the fronts were out and I don't remember the flasher going fast on the console when I used the blinkers before adding the new front flush mount signals.
Guess I have some wire hunting to do for loose connections, but I don't think there are any? What a weird problem - to bad I can't leave well enough alone...
Old December 30th, 2009, 05:33 PM   #5
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
a lower wattage bulb will flash faster with the stock turn signal relay
you may need an electronic turn sig relay with your choice of lights
Old December 30th, 2009, 05:48 PM   #6
Grn99Kawi
Grn99Kawi's Avatar
Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold)
a fast blink does mean that a bulb is out.. pull out the front bulb.. see if the speed drops to normal.. then do the same for the rear at least to isolate where the problem is.. hopefully..
2000 Honda CBR600F4 Silver and Red
1999 Kawi Racing Green Ninja 250 sold
Grn99Kawi is offline   Reply With Quote
Old December 30th, 2009, 05:48 PM   #7
austexjg
austexjg's Avatar
That's weird because the light bulbs are the same on the left as the right - front ones match and the rear ones match (same package).
Old December 31st, 2009, 09:59 AM   #8
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Swap the bulbs then, left to right. Do one end first (front or rear) and try them, then the other end... see if the quick flash follows a bulb.
Old December 31st, 2009, 10:03 AM   #9
Grn99Kawi
Grn99Kawi's Avatar
My AC flushmounts were great for about a week, and then the fuse started blowing.. for some reason on one side there was a small piece of metal under the bulb that was shorting the contacts together and blowing the fuse. I pulled it out and all was well.
I know that you arent blowing fuses, but take a good look in there.. 'stuff' happens sometimes.
Adam
Old December 31st, 2009, 10:46 AM   #10
austexjg
austexjg's Avatar
Will do on these things. It's my brothers bike - I gave him the flush fronts for Christmas.
The rear was just the replacing of the lens covers, but the wires look like they have been spliced for some odd reason?
When he rewired the blinkers (left side to right side - opposite) and now the left side starts to blink fast - could it be the spliced wires? He is going to try to redo the connection (spliced) and see if it helps.
Turn Signals ? nothing .... no blinking! Klondike1020 2008 - 2012 Ninja 250R Tech Talk 2 July 17th, 2013 08:52 AM
Aftermarket turn signal replacement fast blinking problem rph12 1986 - 2007 Ninja 250R Tech Talk 2 May 16th, 2012 09:17 PM
Turn Signal lights but no blinking Murtasma 2008 - 2012 Ninja 250R Tech Talk 3 August 1st, 2011 06:06 PM
1) Turn signal not blinking, 2) Brake modulator down MysterioX 2008 - 2012 Ninja 250R Tech Talk 3 May 28th, 2011 03:00 PM
Turn signals not blinking singlecoillover 1986 - 2007 Ninja 250R Tech Talk 6 March 4th, 2010 11:00 PM
