Old March 3rd, 2010, 08:19 AM   #1
singlecoillover
singlecoillover's Avatar
Motorcycle(s): 09 Ninja EX250-J Special Edition
Turn signals not blinking
My turn signals turn on but won't blink. The girl I bought the bike from said it was because of a relay and gave me a replacement. I installed the new relay and still the signals won't blink. I googled the problem and some people suggested getting different bulbs as the wrong ones will cause the system to not function properly. What do you all think?
singlecoillover is offline   Reply With Quote
Old March 3rd, 2010, 10:38 AM   #2
altomista
Evil Mad Scientist
altomista's Avatar
Motorcycle(s): 2006 EX250F6FL, 1986 ZX600A2, 1975 Honda CB550
Are the turn signals stock or aftermarket?
Need your Ninja 250R worked on? PM me... | Spartan Riders on Ning
Avatar created by J.J. McCullough and taken from Wikipedia's Mad Scientist entry.
altomista is offline   Reply With Quote
Old March 3rd, 2010, 10:51 AM   #3
singlecoillover
I think they're aftermarket because the previous owner removed the stock fender.
Old March 3rd, 2010, 10:58 AM   #4
altomista
Evil Mad Scientist
altomista's Avatar
Incandescent bulbs or LED's?
I'm guessing LED's because they stay on? If that's the case, you need a mechanical turn signal relay, not a thermal one.
Old March 3rd, 2010, 11:13 AM   #5
singlecoillover
Actually after closer inspection, I'm going to say that they are OEM signals with incandescent bulbs. They are identical in every way to the signals that are on the stock rear fender.
Old March 3rd, 2010, 10:30 PM   #6
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Pics?
And, my first thought would be to make sure the bulbs aren't burned out. Then try the other relay like Al said. If not there, check all the connections between the signals and the rest of the electrical system. See if there's any connection problems there. Good luck!
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old March 4th, 2010, 11:00 PM   #7
singlecoillover
Problem solved thanks to a NAPA 552 Thermal Flasher. Evidently the part that the girl gave me was either wrong or broken.
Thanks for the help!
Turn Signals ? nothing .... no blinking! Klondike1020 2008 - 2012 Ninja 250R Tech Talk 2 July 17th, 2013 08:52 AM
Aftermarket turn signal replacement fast blinking problem rph12 1986 - 2007 Ninja 250R Tech Talk 2 May 16th, 2012 09:17 PM
Turn Signal lights but no blinking Murtasma 2008 - 2012 Ninja 250R Tech Talk 3 August 1st, 2011 06:06 PM
1) Turn signal not blinking, 2) Brake modulator down MysterioX 2008 - 2012 Ninja 250R Tech Talk 3 May 28th, 2011 03:00 PM
Fast blinking turn signal austexjg 1986 - 2007 Ninja 250R Tech Talk 9 December 31st, 2009 10:46 AM
