Old February 1st, 2023, 07:33 AM   #1
[motorcycle.com] - It’s Official: Kawasaki Announces The 2023 Ninja ZX-4RR KRT
One of the worst-kept secrets in motorcycling is now a secret no more: Kawasaki has announced the Ninja ZX-4RR KRT will be coming to the US in 2023, (hopefully) ushering in a revival of 400cc four-cylinder sportbikes that were all the rage in the 1990s. But unlike the current parallel-twin Ninja 400, which is essentially a budget bike dressed in sportbike clothes,* this newest model is worthy of the ZX prefix, as it boasts proper suspension, twin radial brakes, a full electronics suite, and chassis geometry inspired by its ZX-6R and ZX-10R siblings – oh, and let’s not forget – a compact four-banger that will rev to over 15,000 rpm! But more on all those things in a minute.
First, if you’re a longtime MO follower, this shouldn’t surprise you. Our resident sleuth, Dennis Chung, broke ground on this new bike over a year ago – in May of 2021, to be exact, when Kawasaki applied for a patent for an air duct to drive air around the radiator and header pipes to help cool the engine directly. Dennis followed that up in August of 2022 when Kawasaki filed VIN submissions for an upcoming ZX-4. However, in an effort to bring Dennis’ non-existent ego back to Earth, let’s nitpick one little thing: He got the number of Rs wrong (for the US at least – he still suspects a single R will come to other markets). The suffix should include two Rs, along with three more letters: KRT (Kawasaki Racing Team). This suffix matters because a double-R Kawasaki Ninja is meant to be a thoroughbred track weapon.*
Is it? On paper anyway, it sure seems so. Without further ado, let’s take a closer look at the long-anticipated Ninja ZX-4RR.
Engine
We can’t start anywhere else but the engine. As you know, it’s a 399cc, liquid-cooled inline-four with dual overhead cams. Bore and stroke measure 57.0 x 39.16mm, for an oversquare engine capable of such high rpm. The ECU is similar to the one on the Kawasaki Z H2, which allows for the use of Kawasaki’s latest electronics. Electronic Throttle Valves (ETV) with 34mm throttle bodies feed air and fuel to the engine and also facilitate the use of all the rider aids we’ve come to expect from today’s sportbikes, like traction control, power modes, and even the bi-directional quickshifter.
Looking at the cylinder head, the intake port interiors are sand cast, using fine sand, which results in a smooth finish. Similar to the Ninja ZX-10R, the intake port exits have been machined in two stages, first along with the valve seats and then again at an inclined angle, to create a straighter path for intake air into the combustion chamber. This promotes a smoother flow and a greater volume of fuel-air mixture. Lightweight forged camshafts contribute to the high-rpm performance. Triple-rate valve springs keep the valves in check, even at high rpm.*
The intake valves themselves are large, measuring 22.1mm, and are complemented by 19mm exhaust valves, flowing a great volume of air necessary for high engine speeds. A narrow valve angle of 24.8º not only helps combustion efficiency but also helps in designing a compact cylinder head and overall engine. The combustion chambers are precision machined to high tolerances – a production technique that is limited to Kawasaki’s high-performance premium models.*
The tiny little pistons are cast aluminum for low reciprocating weight and quick-climbing revs. Also, to help achieve that lofty engine speed, the piston skirts are relatively short and have a molybdenum coating for increased durability. Compression ratio is a modest 12.3:1, which Kawasaki says allows the use of “regular gasoline.” We’re not sure if that means using octane as low as 87 (not that we do anyway), but we can already see aftermarket tuners playing with compression ratios and ignition timing to take advantage of race gas. Utilizing an aluminum die-cast cylinder with an open-deck design, excellent heat dissipation and low engine weight is achieved.*
The Kawasaki press release continues:
In order to reduce mechanical loss and vibration, Kawasaki engineers carefully selected the connecting rod ratio, while a special carburizing treatment was used on the connecting rods to improve durability and reduce weight. Thanks to the crankshaft’s light flywheel mass, a low moment of inertia was reached, contributing to a quick-revving engine character and direct throttle response. A deep oil pan ensures that the oil pump inlet is always submerged, blocking air from being ingested, even during hard acceleration and deceleration while sport or track riding.
Radiator shown with optional radiator screen.
Keeping the engine cool is obviously a high priority, and the water jackets were carefully designed for this purpose. Even the long-reach spark plugs offer more contact with the water jacket to help prevent engine knocking. There’s a large, 30-row radiator to keep the coolant temps under control, and the patented air duct mentioned at the top of this story is actually a radiator fan cover that is located behind the radiator to move hot air out to the sides and away from the rider. Ducts built into the fairings funnel air towards the radiator to bring coolant temps down.
A true “mini” superbike, the ZX-4RR has a functional ram air scoop at the front of its nose, just like its ZX-6R and ZX-10R siblings. Using a similar layout to the Ninja H2, the Ram Air duct is routed to the left of the front fork on its way to the airbox. This contributes to a duct with a highly efficient airflow, enabling cool, high-pressure air from the front of the bike to be ingested. Additionally, the design is extremely effective at preventing water from entering the airbox while riding in the rain. And just in case you forget, the large Ram Air duct has “Ram Air” stamped into it. Maybe you can show it off to your friends…?*
The intake funnels are 60mm and 40mm for efficient filling and produce a flat torque curve with smooth power delivery. The downdraft intake creates a shorter, more direct path for intake air to enter the cylinder, improving cylinder-filling efficiency and increasing engine power at high rpm.
After all the spent gasses are done combusting, they exit the bike through an exhaust system modeled after the ZX-6R. Four-into-one header pipes link headers 1-2 and 3-4 to help with low-end torque, the pipes then meet with a collector with three catalyzers before leaving via the long silencer in the back.*
Putting the power to the ground is a six-speed gearbox with Assist & Slipper clutch. The assist function clamps the clutch pack tighter while also providing a light clutch, and the slip function allows the clutch to slip a little to prevent rear-wheel hop in the event of a sloppy downshift. Of course, you won’t make any sloppy downshifts because the ZX-4RR comes with a bi-directional quickshifter.
Ultimately, everyone wants to know what kind of power it’s making. The answer is… we don’t know. Kawasaki has only revealed that it makes a peak of 26.5 lb-ft of torque at 11,000 rpm. Our guess is peak power will be around 40-50 hp. Nonetheless, we’re already excited at the power the aftermarket will be able to pump out of one of these.*
Chassis and Suspension
Unlike its ZX-6R and ZX-10R brothers, the ZX-4RR doesn’t use a perimeter beam frame. Instead, there’s a steel trellis frame of various pipe diameters and thicknesses to achieve specific rigidity and chassis flex, utilizing feedback learned directly from the KRT World Superbike team. What kind of feedback? Things like the center of gravity position, swingarm pivot position, engine axis positions, and caster (aka rake) angle were just some of the dimensions inspired by the ZX-10RR. The long, steel swingarm allows for optimum front/rear weight distribution, while the arch design of the right side not only looks cool and draws a balance between rigidity and flex, but it also gives the space needed to fit the silencer as centrally as possible.
Showa provides suspension for both Kawasaki’s World Superbike team and its production models, and the ZX-4RR is the latest to benefit from this collaboration. In the front is Showa’s 37mm SFF-BP (Separate Function Fork – Big Piston) with spring rates and valving specifically for the mixed-use conditions the ZX-4RR will see on the street and track. As the name suggests, each fork leg separates the suspension functions. The left tube handles preload adjustments, while the right tube handles the damping changes. Unlike a cartridge fork, however, the fork tube itself acts like a cartridge, allowing a bigger piston to be used. Hence the name. Unfortunately, the ZX-4RR falls short in that it only offers preload adjustment up front. If you were hoping to be able to change the compression or rebound settings, sorry. You’re hosed.
However, at the rear is Showa’s BFRC (Balance Free Rear Cushion) shock mounted via linkage above the swingarm, placing the shock further away from the heat generated from the engine and exhaust. The shock is similar to the one on the ZX-10R but obviously tuned differently for the smaller bike. Unlike the front fork, the shock has adjustability for preload, compression, and rebound damping.*
As disappointing as the front suspension may be (at least on paper), the brakes on the ZX-4RR definitely look appropriate for the part. Up front are two 290mm semi-floating discs paired with radial-mount, four-piston monobloc calipers, with the upper pistons measuring 32mm and the lower ones 30mm. Here’s hoping Kawasaki has given it adequate brake pads, but even if not, those are easy enough to change. The rear is a single 220mm disc with a single 38mm piston caliper. Kawasaki’s latest ABS technology comes standard.
Another bit of good news is the ZX-4RR’s star-pattern five-spoke wheels come stock with Dunlop Sportmax GPR-300 tires. The front is a standard 120/70 size, and the rear is a 160/60, meaning there are lots of exceptional tire choices.*
Then there’s the weight. With a curb weight of 414.5 lbs, the ZX-4 is about 50 lbs heavier than the current Ninja 400 (361 – 366 lbs), and less than 20 lbs lighter than the ZX-6R (425 – 430 lbs). A sub-400-lb curb weight would have been nice, but time will tell if it feels lighter than it actually is.
Electronics
On the surface, it seems silly for a 399cc motorcycle to have an electronics suite, but as a bike with two Rs in its name, it does make more sense. Plus, since the bike already has fly-by-wire throttle, the components are already in place to incorporate TC. Hence, the ZX-4RR sees the KTRC system applied here. Adjustable in three different levels (four if you include Off), Kawasaki fails to mention anything regarding an IMU in its press materials, which leads us to believe that it’s a reactive TC system instead of a predictive one – which seems fine for a bike like this.*
In addition to KTRC, the 4RR also gets two-level Power Modes, and integrated Riding Modes (Sport, Road, Rain) with preset power and TC settings. A fourth mode, Rider, is a manual mode that allows you to set the power and TC settings independently.
Information is displayed via a 4.3-inch TFT not too dissimilar from the one on the ZX-10R. Apart from the standard menu that gives you road speed, engine speed, and the like, there’s also a Circuit Mode screen that shows track-related information front and center, including a lap timer. There’s also the ability to connect the ZX-4RR to Kawasaki’s Rideology App to view vehicle info, riding logs, mobile phone notices, and more.
Ergonomics/Styling
In case you haven’t noticed yet, this is a supersport bike, through and through. Clip-ons are mounted below the triple clamp, and the pegs are slightly behind you (though they don’t appear to be too high in the photos). You’re going to be in the racer position with weight over your wrists, which will be especially apparent if you’re coming off, say, the current Ninja 400 and its comparatively upright bars. That said, as we look at these photos, the seat, which is 31.5 inches off the ground (compared to the Ninja 400’s 30.9-inch seat height) looks cramped for average-size adults. The 3.96-gallon tank, too, is narrow, which is great for feeling slim on the bike and for being able to put a foot down but might pose a problem when it comes to finding an anchor point for the outside leg as you’re slicing through a turn.
Being part of the ZX family, the resemblance to its bigger siblings is striking, albeit expected. Classic Ninja styling carries over to the ZX-4, with sharp, angled styling throughout, capped off with the signature aggressive and angled nose section and huge ram air scoop borrowed from the ZX-6R and influenced by the previous-generation ZX-10R.
There’s One Big Catch
So far, the ZX-4RR sounds like a bike any sportbike fan can get behind, right? Well, if you remember, the 400cc four-bangers of 30 years ago all disappeared because they simply became too expensive for their own good. The 2023 Kawasaki Ninja ZX-4RR KRT Edition carries a retail price of $9,699. Might we be on the verge of seeing history repeat itself?
For some perspective, that’s nearly $4000 more than the current Ninja 400 and only $1000 less than the base ZX-6R. Granted, as someone who loves (and owns) small bikes, I’ll be the first to say that the value of the ZX-4RR shouldn’t be measured in horsepower. But with pricing so close to bigger bikes, something tells me the initial hype surrounding the ZX-4 will fade fast before riders lust for horsepower again. If there’s any hope for more small-bore screamers to make their return, then Mr. Chung’s prediction of a Single R version coming here with a lower price tag will have to come true. Time will tell.*
In the meantime, there’s no denying we’re looking forward to throwing a leg over the Ninja ZX-4RR.
2023 Kawasaki Ninja ZX-4RR KRT SpecificationsMSRP$9,699Engine Type4-Stroke, Liquid-Cooled, DOHC, 4 Valves Per Cylinder, Inline 4Displacement399 ccBore and Stroke57.0 x 39.1 mmCompression ratio12.6:1HorsepowerNATorque26.5 lb-ft. at 11,000 rpm (Claimed)Fuel systemDFI w/34mm Throttle Bodies(4)IgnitionTCBI with Digital AdvanceTransmission6-speed KQS with Positive Neutral FinderFinal driveSealed ChainClutchWet multi-disc, Slip/AssistFrameSteel TrellisFront Suspensionø37 mm Inverted SFF-BP Fork with Adjustable Preload and Top-out SpringsRear SuspensionHorizontal Back-link with BFRC lite Shock with Piggyback Reservoir, Adjustable Preload, Compression, and Rebound Damping, Top-out SpringsFront Tire120/70-17Rear Tire160/60-17Front BrakeDual Semi-floating 290 mm Discs with Radial-mount, Monobloc Opposed 4-Piston CalipersRear BrakeSingle 220 mm Disc with Single-Piston CaliperCaster (rake)23.5°Trail3.8 inchesOverall lengthNAOverall widthNAOverall heightNAWheelbase54.3 inchesSeat height31.5 inchesCurb Weight414.5 pounds (Claimed)Fuel capacity3.96 gallonsWarranty12 monthsKawasaki Protection Plus12, 24, 36, or 48 monthsBecome a Motorcycle.com insider. Get the latest motorcycle news first by subscribing to our newsletter here.
The post It’s Official: Kawasaki Announces The 2023 Ninja ZX-4RR KRT appeared first on Motorcycle.com.
Click here for full story...
Old February 1st, 2023, 09:40 AM   #2
Well, it's been officially announced! Kawi released the 4-cylinder 400cc superbike that many folks have been screaming for ever since the tiny 4 bangers went away decades ago. It remains to be seen if it can be sold for ~ $10K US, but it certainly seems to have most of the specs that people had on their wishlist.
Old February 1st, 2023, 08:08 PM   #3
This is the bike I dreamed of when I was 17 and bought my ninjette. It has the right engine, frame, size, power; this, that, and the other thing, etc.
Whoever buys one, please enjoy it.
Old February 1st, 2023, 08:57 PM   #4
Looks like US version has the 16k redline. Canadian versions of the ZX-4R and ZX-4RR are limited to 11500 rpm due to noise regs. Makes me wonder if there will then be a "California" version with comparable limitations.
Old February 3rd, 2023, 10:52 AM   #5
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
This has always been my biggest concern. I would love to have a Ninjette with all the high-end stuff from the bigger bikes (as I bet just about everyone here would). However, it costs $4400 more than the EX400 (which is only $5300). It's $1,000 less than a ZX-6R. I think it's a pretty niche market that is willing to pay $10k for the ZX-4RR and not just spend another $1k to go up to the ZX-6R with about 70% more horsepower.
If it was right in the middle of the two at $8,000 I think it would be easier to justify (one step up from the EX400 into the racebike category, and another step up to the bigger racebike). As is, you're basically buying a ZX-6R, and saving a little cash by getting slightly lower displacement (and possibly some suspension compromises).
Based on https://www.visordown.com/news/new-b...mn-2023-launch, it looks like the 4R SE loses the fancy rear shock, and the base 4R also loses the preload adjustment on the fork. It doesn't seem to me like those changes would drastically reduce the price.
It sounds like the best Ninjette yet. I'm just not sure it's a good enough value for many people to actually buy it.
Old February 3rd, 2023, 06:11 PM   #6
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
I have a bit of concern over the price. It's just about the same price as the Ninja 650 I tested last week, which has the upgraded suspension and brakes I'm looking for, and has more power (not that I really need it).
I'm hoping Kawi does a demo day with the new 400. I'd really like to try it out.
Old February 4th, 2023, 03:05 PM   #7
More ominous news.
https://www.motorcycle.com/new-model...-4rr-make.html
Old February 5th, 2023, 03:25 PM   #8
CaliGrrl
CaliGrrl's Avatar
So if we can push it to 14,000 we can get the full horsepower but we don't know if we will be allowed to or not....
The Kawi rep at a recent demo day said he gets asked about this bike all the time, but at that time he had no information for me. So they make the bike everybody wants but then they nerf it. They can do better.
Old February 6th, 2023, 09:00 AM   #9
InvisiBill
InvisiBill's Avatar
Motorcycle.com has obtained vehicle identification number information submitted by Kawasaki to the National Highway Traffic Safety Administration has the ZX-4RR (listed under its model code of ZX400SP) as producing just 42 kW, or 56.3 hp. Whether that’s with or without ram air matters little, as prospective American customers may be disappointed to know the ZX-4RR is down more than 25% from the European spec.
It seems weird to me that they could sell a 16k-RPM ZX-6R, but have to limit the ZX-4RR's same 16k-RPM by 25% due to noise ordinances. You'd think they'd just slap on a bigger, uglier, more restrictive muffler to cover that.
That same chart shows the EX400 at 36kW (48hp). I know it's not just about pure power numbers, but you're paying 83% more for 17% more horsepower. EX400s with exhaust, airbox mods, and the tune to match (stock engine) are dynoing at 53hp. The ZX-6R for only $1,000 more has 2.2x the power.
If the posted numbers are accurate for the final product, that seems like a huge letdown. Maybe there's a switchable street/track mode, or intermediate license setup, or something...
Old February 6th, 2023, 10:32 AM   #10
It may be a combination of noise ordinances and emissions regs. People have stated for years that the super high revs of the tiny 4's wouldn't meet modern emissions regs for a variety of reasons. This bike is a test case for how true those predictions turned out to be. We will undoubtedly have more information soon.
Old February 7th, 2023, 11:31 AM   #11
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Looks like there’s a lot of good here, if it’s 75hp then it’ll be a riot. Price tag is heavy especially with how close to a zx6r it is. By the time it’s built it’ll be every bit of a 15-20k usd race bike. Local classes currently have it specifically banned from 400 classes (smart move so it doesn’t destroy the classes) so it’ll have to compete with the RS660 and KTM790, a tall order. Still have a lot of interest and like the concept/been wanting the idea for years just hard to justify. We’ll see how it sells and what the consensus is as time goes on. Fully expecting the EX400 to be more popular overall.
Old February 14th, 2023, 09:32 PM   #12
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
Saw it on the Kawi website the other day. It's definitely a true lightweight track terror and a beautiful bike. However, that price tag is a bit steep. It's not far from a zx6r. It would be nice if it had it's own class. I really like the look and specs but for $9700 I don't know that's a tough one. $1k away from the base zx6r. To me this bike is only worth $8k.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old February 17th, 2023, 08:59 AM   #13
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
they will come down in price after they see they will not sell en'mass
of that I am sure, but if that is the case they may well stop manufacturing them all together.... so to me it would be a un wise purchase....
Like all the other bike manufacturing companies out there they are hunting for that perfect seller.... unfortunately they put a way too high price on it
which will kill it from the get-go....
.... History has proven that the initial price has to be lower than the competitors
in order to sell all of your stock.... but when they get greedy and ask more than the competitors the item almost always falls flat on it's face...no matter how good it is. it was a poor move on Kawasaki's part to ask so much for such a small bike....
Bob......
Old February 19th, 2023, 12:59 PM   #14
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I am looking for on locally so I can drool in person
Old March 1st, 2023, 01:38 AM   #15
IndestructibleNinja
IndestructibleNinja's Avatar
Motorcycle(s): 08' ninja 250 and Honda XL600
This is definitely the bike to get if you have the money laying around. I can't wait to buy one of these for a couple grand and fix it up, when the time comes. Screw 10 grand new, I'll polish my turds for a decade.
IndestructibleNinja is offline   Reply With Quote
Old March 5th, 2023, 10:55 PM   #16
xorbe
xorbe's Avatar
We're over at zx4rforum.com, nobody has let it slip what rpms will ship in the USA, but apparently Graves already has 16k ecu flash ready to go.
imho, Kawasaki's Canada "noise regulations" is sly speak for "emissions", we all know what's really going on here.
Okay but the base zx6r lacks auto-blip, ride by wire, tft, abs, and krt livery. The zx6r krt abs is actually $12K so a cool $2300 more than zx4r (and still lacks tft, auto-blip, and ride by wire).
[RideApart] - 2023 Kawasaki Ninja ZX-4RR Is Finally Here To Take The World By Storm Ninjette Newsbot Motorcycling News 0 February 1st, 2023 07:16 AM
[cycleworld.com] - 2023 Kawasaki ZX-4RR KRT Edition Coming to the US Ninjette Newsbot Motorcycling News 0 February 1st, 2023 07:16 AM
[ridermagazine.com] - 2023 Kawasaki Ninja ZX-4RR | First Look Review Ninjette Newsbot Motorcycling News 0 February 1st, 2023 07:16 AM
