Old November 8th, 2010, 01:41 PM   #1
Sailariel
Sailariel's Avatar
Suspension Question
I looked in the Suspension WIKI and ascertained that my rear shock should be set at pos #3 because I weigh 190 to 195. It has been at that position since June 08. Problem is that I saw the MD for some lower back pain and he ascertained that I have a bulging disk at L-3. Quite honestly, riding hurts, esp. on our frost heaved bad Maine roads. Setting the suspension on #1 would probably make things better. My question is--would handling be impaired a great deal by dialing in "Wimp Mode"?
Ninjette, Sold. New Bike: 2010 Honda NT-700V/VA, 73 Honda 550, 74 Honda 550
Old November 8th, 2010, 02:06 PM   #2
only if the lowest setting cause the suspension to bottom. does it? if not, lower the setting to what is comfortable and enjoy.
steering may seem a bit slower/sluggish in turns, but if you don't notice anything, ferget about it. even if it does, I'm sure you'll get used to it... just be aware of a possible change.
Old November 8th, 2010, 02:12 PM   #3
Boom King
So, where's the reverse?
Boom King's Avatar
Sorry to hear about your bad back. I used to have a lot of lower back pain too as my lumbar doesn't curve correctly. Started going to the gym and doing a lot of lower back/upper back muscle exercises and abdominal strengthening. It made a huge difference and I no longer experience the same type and frequency of pain in my lower back. It's probably different in your case as you have a bulging disc and it might limit the range of activity you can do. Have you thought about wearing back brace supports while riding? http://www.comfortchannel.com/prod.itml/icOid/1693. Might be worth a try at least. I've seen a couple of guys at the gym wear it when they work out or play basketball.
As for the suspension, I'm not really sure on that. My guess is that at low speeds, you probably won't notice much difference but perhaps at higher speed turns you would. Maybe you can dial it down to the #2 position first and try it out before going all the way down to #1.
Old November 8th, 2010, 05:04 PM   #4
randomwalk101
self wrencher
randomwalk101's Avatar
How can one tells if the suspension bottoms out?
Old November 8th, 2010, 06:20 PM   #5
Sailariel
Sailariel's Avatar
Hey Guys, Thank you for your responses. I'll take Kelly's advice and drop her down to #1--possibly will experiment with tyre pressure as well. The suggestion of excercise is great--but there is one problem. I have NO abs. Between two AK-47 exit wounds in the midsection and four surgeries where they opened me up from the bottom of my chest to practically my crotch and then held the whole thing together with Gore-Tex--there are no abs--unless we can figure out how to tone up Gore-Tex. I do work out--being about 300meters from the Y. Got great upper body strength and good legs for bicycle racing. I do have a gut when I don't wear the very wide elastic belt. Really, things could be a lot worse. Now we all need to figure out a way I can keep riding the Ninja (I take Doctor's advice with a grain of salt--they are great professionals but they don't have all the answers)
Old November 8th, 2010, 06:28 PM   #6
Sailariel
Sailariel's Avatar
It makes an incredible Clunk! and you definitely feel it in your butt.
Old November 8th, 2010, 07:16 PM   #7
yup... when the suspension bottoms, you have metal to metal contact of parts and whatever forces the shock did not dampen will be sent straight through the frame and on to the seat and handlebars. you'll feel and hear it.
Old November 10th, 2010, 02:13 PM   #8
demp
just wait for that KABLAMMO noise... and the feeling like you've hit a curb
Old November 10th, 2010, 06:17 PM   #9
Sailariel
Sailariel's Avatar
That too.
Old November 10th, 2010, 07:28 PM   #10
So, Alex... have you readjusted the rear shock and if so, has it helped your back?
Old November 10th, 2010, 09:01 PM   #11
DaBlue1
DaBlue1's Avatar
Softening up the suspension for normal commuting will not only help your back but also help in controlling the bike on potholed riddled and ice heaved roads. I have back problems as well. i found out real quick that a stiff suspension was not going to work for me. so I've done a couple of things.
1.The happy medium for me was the #3 position. #1 was way too soft. I'm about 215 lbs (225 fully loaded).
2. I bought a gel seat cushion. The one I got fits the bike perfectly. It was only $20.00 at Walmart. (its actually a car seat cushion)
3.Added some more foam to my stock seat and had it re-covered.
4.Got rid of the bricks posing as stock tires. (see the pics)
All of this has made my riding so much better and comfortable.
Question on race suspension krolinked Ninjettes At Speed 15 September 4th, 2014 01:19 PM
Front suspension question gasguzziler 1986 - 2007 Ninja 250R Tech Talk 18 May 7th, 2014 12:05 PM
suspension question tac12345 2008 - 2012 Ninja 250R Tech Talk 5 September 13th, 2012 09:27 AM
Suspension Question...Intiminator? esi7esi7 Ninjettes At Speed 17 March 10th, 2010 08:25 PM
Suspension Question Rawr 2008 - 2012 Ninja 250R Tech Talk 2 April 30th, 2009 09:51 PM
