Old August 1st, 2011, 06:37 AM   #1
Murtasma
2 Wheels 4 Life
Murtasma's Avatar
Turn Signal lights but no blinking
I noticed my tail light was out recently which also lead me to discover my left turn signal will not blink but it does light up when activated. The tail light was out because of a loose connection causing a short. I fixed the short and the replaced the fuse so I'm back in business now.
My right turn signal works with out issue. When I activate the left turn signal it lights up but will not blink.
Any ideas on what to look for?
Murtasma is offline   Reply With Quote
Old August 1st, 2011, 09:24 AM   #2
FBNTH
Motorcycle(s): None yet
it may be the bulb is about to die. swap your right bulb with your left bulb and see if the problem switches sides.
Rick
FBNTH is offline   Reply With Quote
Old August 1st, 2011, 10:21 AM   #3
Murtasma
2 Wheels 4 Life
Murtasma's Avatar
I'll give that a shot when I get home and report back thanks.
Old August 1st, 2011, 06:06 PM   #4
TheJimmyEnglish
TheJimmyEnglish's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250R Red
My thoughts also. the bulb may just be about to die completely
My YouTube Channel
TheJimmyEnglish is offline   Reply With Quote
Turn Signal lights are acting like hazard lights Greyfox 2008 - 2012 Ninja 250R Tech Talk 13 October 15th, 2014 09:51 AM
Peg turn signal lights. agentbad 1986 - 2007 Ninja 250R Farkles 1 February 14th, 2014 10:34 AM
Aftermarket turn signal replacement fast blinking problem rph12 1986 - 2007 Ninja 250R Tech Talk 2 May 16th, 2012 09:17 PM
1) Turn signal not blinking, 2) Brake modulator down MysterioX 2008 - 2012 Ninja 250R Tech Talk 3 May 28th, 2011 03:00 PM
Fast blinking turn signal austexjg 1986 - 2007 Ninja 250R Tech Talk 9 December 31st, 2009 10:46 AM
