Old October 1st, 2011, 10:05 PM   #1
venmichaels
Motorcycle(s): 08 ninja 250r
Throttle wont return anymore..
Today I was replacing my right handlebar..
I removed the throttle housing? Idk what its called...
But when I put it back together.. the throttle will no longer return to the close position..
It just revs and never comes back down... =( Did I screw something up?? Its not even rideable anymore.. does anyone have a pic of how the throttle cable is supposed to look inside the housing?? Im lost..
venmichaels is offline   Reply With Quote
Old October 1st, 2011, 10:06 PM   #2
venmichaels
2009 ninja 250r.
Old October 1st, 2011, 10:07 PM   #3
kingkang204
Motorcycle(s): Bike-less, Can I ride yours?
There are push and pull cables, is it possible that you poped one of them out.
Try this: Turn the bike on, Rev it, and try and turn the throttle back to closed position. If the revs go back down then the push cable is fine.
RR stands for Responsible Riding... Right?
kingkang204 is offline   Reply With Quote
Old October 1st, 2011, 11:53 PM   #4
setasai
setasai's Avatar
Sounds like you have some binding. Take it apart and look carefully at where everything is supposed to go and then try putting it together again. While you're at it, lube the cables.
Old October 2nd, 2011, 06:20 AM   #5
venmichaels
Ive done just that.. everything looks good.. i dont understand..
Old October 2nd, 2011, 06:31 AM   #6
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Look to see if your grip is getting hung up on something.
That's usually what causes it if it's not something assembled wrong..
Maybe there is a Ninjette member close by who can diagnose your issue, or maybe you can take a picture for us to see if we can spot it. Some of us know every part on the bike inside and out.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old October 2nd, 2011, 09:17 AM   #7
pop0tart
Motorcycle(s): stolen :(
There is a spring down at the throttle butterflies that pulls on a cable to cause the twist grip to snap back to idle. You can locate it by removing the right side cover of the bike (black, held in place with one phillips screw). To see where the problem is, I would undo the assembly on the handle bar and work the cables by pushing/pulling with your hands. Any binding? then the problem is further down. If not, the binding was on the bar end of everything. Carefully re-assemble the assembly on the handle bar and before tightening everything down, make sure the grip will twist freely. If that didn't do the trick, lubing the cables may be in order, or the cables need to be re/routed, or both cables may need to be adjusted on the butterflies end of things. Let me know, and I can fill ya in on how to do all that...lots of typing though, so try all that first.
pop0tart is offline   Reply With Quote
Old October 2nd, 2011, 09:32 AM   #8
LazinCajun
LazinCajun's Avatar
Motorcycle(s): 2008 Ninja 250 (Blue!)
Is the grip snapping back closed immediately when you let go of it? If not, the easiest thing to check is that the grip isn't binding against the bar end or the switch/control housing.
LazinCajun is offline   Reply With Quote
Old October 2nd, 2011, 02:32 PM   #9
Monkey Wrench Cycles
Motorcycle repair
Motorcycle(s): '05 Ninja ZX6-RR, '08 GY6 scooter for wife, '02 Shadow ACE, '05 Buell Blast
Surprised no one has mentioned improperly adjusted throttle cables. If they are adjusted to tight the throttle won't return properly.
"You can't know where you're going until you know where you've been"
www.monkeywrenchmotorcycles.com
Monkey Wrench Cycles is offline   Reply With Quote
Old October 2nd, 2011, 03:03 PM   #10
haze5736
Motorcycle(s): 98 Ninja 250
I recently fixed my slow throttle close problem by adjusting the cable. Mine would hang for a bit then would come down slowly.
haze5736 is offline   Reply With Quote
Old October 2nd, 2011, 08:09 PM   #11
pop0tart
Totally mentioned that, sonn
Old October 3rd, 2011, 04:52 AM   #12
Motorcycle repair
In that case +1 I agree
Throttle stays open and won't return to closed position. Insane Pie 2008 - 2012 Ninja 250R Tech Talk 12 May 21st, 2014 11:16 AM
Rear seat lock not working anymore tfkrocks 2008 - 2012 Ninja 250R Tech Talk 13 October 20th, 2013 12:08 PM
[hell for leather] - Not just for squids anymore Ninjette Newsbot Motorcycling News 0 August 24th, 2012 01:40 PM
FI model problem - wont idle well and throttle surges Christofeser 2008 - 2012 Ninja 250R Tech Talk 4 January 16th, 2012 05:07 AM
[topix.net] - Harleys hardly just for male riders anymore Ninjette Newsbot Motorcycling News 0 August 4th, 2008 08:44 PM
