Old June 15th, 2009, 06:29 PM   #1
headshrink
headshrink's Avatar
Oil & Temp light staying on longer at start-up
As the title states, over the last week or two it has taken longer and longer for the Oil & Temp lights to turn off at start-up (cold). For the past 9K miles it would always go off by 2 sec. max (estimate). But today it was more like 5 long sec. Thinking it might help, when it wasn't turning off, I tilted the bike more upright, and it instantly turned off.... I don't know if this was a coincidence or not. I am waiting for the oil to settle to double-check my oil level, but I suspect it is fine.
Anyone have a problem like this?
Old June 15th, 2009, 06:38 PM   #2
c_anglada
c_anglada's Avatar
i have the same prob.... to fix all i do is tilt the bike so its level as if going to check the oil level then start it up. the light shuts off after 2 seconds or so.. i think the cause is all the oil is going to the one side and its not enough for the oil pump to push through the system???
c_anglada is offline   Reply With Quote
Old June 15th, 2009, 06:45 PM   #3
headshrink
headshrink's Avatar
I don't understand why it changed all of a sudden. I sure hope nothing is about to break.
I have always used the Motul 3000 until this current oil, which is Valvoline 4-stroke (it was cheap). I just picked up the Shell Rot. and will likely stick with it now that I found it locally.
Old June 17th, 2009, 02:09 PM   #4
headshrink
headshrink's Avatar
It seems an oil change solved this problem.
It looked like I may have had more oil than I usually put in.... close to max line, but I don't think over it. I was fearful at first that something big may have broke and the coolant many have mixed in, but luckily I was just being paranoid.
Old June 18th, 2009, 10:45 PM   #5
i916it
Motorcycle(s): 250R 08
Cool thanks, I was having this problem too where it would stay on a bit longer than usual.
i916it is offline   Reply With Quote
Old June 19th, 2009, 01:24 AM   #6
headshrink
headshrink's Avatar
I wish I knew why.... the old oil was actually pretty new. Let us know if a change helps you too.
Oil Pressure Light Staying on at Start Up spacemonkey 2008 - 2012 Ninja 250R Tech Talk 50 October 26th, 2016 10:05 AM
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
oil temp vs coolant temp cuong-nutz General Motorcycling Discussion 11 January 23rd, 2013 05:44 PM
My temp and oil light came on?? Kevin2109 2008 - 2012 Ninja 250R Tech Talk 11 July 17th, 2011 01:07 AM
Oil and Temp light on after low side dznuts 2008 - 2012 Ninja 250R Tech Talk 2 May 2nd, 2011 05:57 AM
