Old May 28th, 2018, 03:14 PM   #1
kvgeorge1
Motorcycle(s): EX250J
Frozen rotor bolts
I am having to replace my rotors on my 250R. I am the 3rd owner, so I don't know what was done before. However, the rotor bolts are frozen (or stuck) and I am not able to break them loose. Also, I am using a manual impact driver (the one's you hit with a hammer) set to loosen and still cannot get the bolts to budge.
Am I just SOL?
kvgeorge1 is offline   Reply With Quote
Old May 28th, 2018, 04:16 PM   #2
MLR
MLR's Avatar
Have you soaked them with penetrant?
If not, take the front wheel off and lay it flat, soak with penetrant and leave for a day, then hit them with your impact driver.
Have you tried heating them?
I've struggled with bolts when someone has used red lock tight before.
Penetrant, heat and your impact driver should sort it out.
MLR is offline   Reply With Quote
Old May 28th, 2018, 04:38 PM   #3
kvgeorge1
So, by "heating" them, do you mean with a blow-torch (propane)?
Old May 28th, 2018, 06:11 PM   #4
Yes, heat them with torch. A lot of them come from factory with red Loctite. Be sure to re-install to correct torque. It's gonna feel like you're gonna snap them, but that's correct amount. Don't want those suckers loosening!
Old May 28th, 2018, 06:37 PM   #5
kvgeorge1
I've never done anything like that before. So, when I heat them, do I keep the torch on them until they turn red, or just heat them up a little bit?
Old May 28th, 2018, 07:26 PM   #6
kvgeorge1
Got 'em off! Letting the penetrating oil sit for longer and quite a bit of rapping with the impact driver did the trick. Oh, and yes - RED THREAD LOCKER! So, now that it is off, how do I clean the inside of the threaded holes of all the old red locktite?
Old May 28th, 2018, 08:16 PM   #7
Leave it on and use a drop of blue Loctite when re-installing. Won't be as difficult next time, but still secure as Loctite fills void in threads and prevents rattling loose.
Old May 28th, 2018, 08:28 PM   #8
kvgeorge1
Awesome! Thanks everyone for your suggestions.
Old May 29th, 2018, 06:01 AM   #9
One suggestion when heating to remove a bolt that is seized or has red loctite on it - apply heat around the threaded area and not directly on the bolt itself.
You do want to loosen the loctite, but you are also heating to expand the area around the bolt to help release it. Even a seized bolt that doesn't have loctite will be easily removed if you expand the threads around it.
A temperature differential between the bolt (colder) and mount area (hotter) is what you are looking for - not just getting everything hot.
Hello from the frozen tundra Mike V New Members 29 June 23rd, 2016 03:20 PM
[motorcycle.com] - The Frozen Few Ninjette Newsbot Motorcycling News 0 February 25th, 2016 05:10 PM
Front Brake, Rotor bolts rubbing, '07 250 gonzo 1986 - 2007 Ninja 250R Tech Talk 7 July 6th, 2014 01:57 PM
Removing stripped rotor bolts FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 33 April 17th, 2013 07:41 PM
WTB : 08+ Ninja 250 Rear Rotor + Bolts abhijitz Items Wanted 0 August 23rd, 2012 07:07 PM
