Old January 26th, 2010, 11:43 AM   #1
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
15t sprocket '09 250r
3 Local shops don't have them ???
Need a source please
thanks
eddie
Old January 26th, 2010, 11:54 AM   #2
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
Here you go.
k-os is offline   Reply With Quote
Old January 26th, 2010, 12:37 PM   #3
eddiekay
eddiekay's Avatar
Thanks...knew the dennis kirk name so no reservations about ordering...nice people...answered questions.
Old January 27th, 2010, 10:07 AM   #4
blong
Motorcycle(s): 09 ninja250, 03 sv650
sv650 uses the same sprocket, you can try that too
blong is offline   Reply With Quote
Old January 27th, 2010, 10:11 AM   #5
eddiekay
eddiekay's Avatar
thanks for rsvp...ordered it from Denniskirkkk shipped same day, witing now. Hey, not too sound too dumb but it easier to ask here....what's the rear axle nut size...my set of metrics stops at 17
Old January 27th, 2010, 10:32 AM   #6
k-os
I can't remember what the size is for the rear axle, but the size for the nut on the front sprocket is 20mm, so make sure you get one of those.
Old January 27th, 2010, 01:20 PM   #7
Momaru
Momaru's Avatar
Not absolutely certain but I think the axle nut is 24mm, I know the castle nut is 16mm. I say this because the owners tool set has a 24mm box-end wrench in the kit that seems about the right size and I can't recall anything else it'd fit. I'll check it when I get home.
Part number 92110-0045
Proud member of the Blue Army
Old February 21st, 2010, 08:03 AM   #8
blackburn RR
Black Ninjas
blackburn RR's Avatar
Motorcycle(s): Kawasaki Ninja zx150RR, 250R
one question,
if i want keep the rear stock, can i fit 16T infront?
is there any clearance issue?
sorry that's two Q's.
BB
It is much easier to stop smoking than to recover from stroke.
blackburn RR is offline   Reply With Quote
Old February 21st, 2010, 11:22 AM   #9
eddiekay
eddiekay's Avatar
From posts on this baord and others I believe you can keeo the rear sprocket.
Old February 21st, 2010, 12:30 PM   #10
Sailariel
Sailariel's Avatar
Originally Posted by blackburn RR View Post
one question,
BB
A 16T will not fit with the existing guard. You probably will not want to go higher than 15T. The rear axle nut is 24mm. The nut on the sprocket is 27mm. The 27 may be hard to find. I found one at NAPA after searching Auto Zone etc.
Old February 21st, 2010, 01:13 PM   #11
mike_sema
mike_sema's Avatar
Motorcycle(s): ninja 250r
i got mine from Sears
08 250R: sportisi VR full exhaust, Dynojet, custom seat, kleen air rmvd, rim tape, grips, fender chop,zg db windscreen,k&n air filter,15t front sprocket,sportisi-usa clipons,solo seat cowl
mike_sema is offline   Reply With Quote
15t Sprocket Noise ChickenRun 2008 - 2012 Ninja 250R Tech Talk 5 August 18th, 2013 12:58 PM
Installing 15t Vortex front sprocket on 08 250r, require shimming and how? novak2k9 2008 - 2012 Ninja 250R Tech Talk 7 February 4th, 2013 11:47 AM
Quicky about 15t sprocket Graugaard 2008 - 2012 Ninja 250R Tech Talk 7 June 28th, 2012 03:10 AM
First ride-15t sprocket wild-bill 2008 - 2012 Ninja 250R Tech Talk 13 January 24th, 2011 08:28 AM
went from 14t sprocket to 15t speedgsx98 1986 - 2007 Ninja 250R Tech Talk 4 May 11th, 2009 04:18 PM
