Old February 17th, 2012, 08:53 PM   #1
DSpinler
Your Lord Funny Bits
DSpinler's Avatar
Motorcycle(s): 2011 Kawasaki Ninja 250
DSpinler's DIY - eBay LED strip install
I started to ask these questions in my original thread here ( http://www.ninjette.org/forums/showthread.php?t=95746 ) but moved to a new thread since this is more than just testing, and so I have a spot to show the results and install steps I take this weekend (Fingers crossed)
So I'm planning on doing the install this weekend... and now my lack of comprehensive electrical knowledge is dawning on me. I've installed lights on truck and hard wired radar detectors to the 12V... but nothing this complicated.
Here's my plan, tell me what I'm gonna screw up:
Positive power is going to be received by splicing into the running lights (still need to figure out which wire it is.) and then to a fuse. From there it will run to two (four?) quick disconnects for the wiring going to the fairings where I will run them in parallel, with the negative wire on the lights going to a wire that will be grounded on the frame....
Am I making any sense? I used some paint skillz to help, but may have made it worse....
--- Your Lord Funny Bits ---
DSpinler is offline   Reply With Quote
Old February 17th, 2012, 09:25 PM   #2
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
switch?
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old February 17th, 2012, 09:31 PM   #3
DSpinler
DSpinler's Avatar
Um....yeah.... lol. Silly me.
I imagine the switch would be wired between the fuse and the disconnects, yes?
Old February 17th, 2012, 09:36 PM   #4
massacremasses
Avid Kitteh Poster
Yeah that would work. Fuse should be first I think...
Power
Fuse
Switch
relay
then what you are powering
I dont think you need a relay though
Old February 17th, 2012, 09:37 PM   #5
DSpinler
DSpinler's Avatar
Never used one before, but from what I hear you would use it for a direct battery powered setup, but still keeping them from being turned on when the bike is off, right?
Old February 17th, 2012, 09:54 PM   #6
massacremasses
Avid Kitteh Poster
yeah because the relay would constantly have power on the one side
Old February 18th, 2012, 12:36 AM   #7
DSpinler
DSpinler's Avatar
But other than that, do I have the wiring right?
Old February 18th, 2012, 10:25 AM   #8
massacremasses
Avid Kitteh Poster
yeah as long as that wire constantly has power when the ignition is on.
Old February 18th, 2012, 03:42 PM   #9
leed
leed's Avatar
Motorcycle(s): Time will tell
If you tie into the brake light running light, no need for a switch!
Old February 18th, 2012, 05:03 PM   #10
massacremasses
Avid Kitteh Poster
just because it has power all of the time I dont think he wants them to be illuminated all the time. Hence the need for a switch...
Old February 18th, 2012, 10:43 PM   #11
leed
leed's Avatar
Ohh I see. I read too fast and I assumed that these were going to be extra running lights. >< Missed that part, hahaha.
You can use the relay from your brake running light and just put a secondary switch really anywhere in the circuit between power and ground. Generally, though, it's easiest and best to put the switch right after the fuse as noted by massacremasses. But even then, you probably don't even need a fuse unless you plan to pull a lot more power. If you tie into the Brake light running light, you'll already have a fuse.
Old February 18th, 2012, 11:50 PM   #12
DSpinler
DSpinler's Avatar
So, attempted install tonight... ran led strips in series, not parallel. As soon as four get hooked up, they no longer light....
The only other difference is that I am drawing power from the licence plate lamp, which is on the same circuit as the running lights, yes?
*le sigh*
Old February 19th, 2012, 04:16 PM   #13
massacremasses
Avid Kitteh Poster
maybe thats not enough power? not sure why they wouldnt work in series unless one was not working and couldnt pass power...
DIY - eBay Steering damper install. psych0hans 2008 - 2012 Ninja 250R Tech Talk 27 May 22nd, 2017 07:21 PM
DIY Install of the Bikemonkey Integrated LED tail light bae13 2008 - 2012 Ninja 250R Farkles 165 March 5th, 2013 03:26 PM
eBay DIY Fender Eliminator with LED jonthechron 2008 - 2012 Ninja 250R Farkles 30 April 10th, 2010 11:47 AM
