Old September 19th, 2012, 02:50 PM   #1
MustangDroid
Motorcycle(s): Ninja 250r
Tire question
I have a 2003 Kawasaki Ninja 250r. Not too long ago I bought a brand new tire from a guy for $30. Its a Shinko 110/80/16. I read online that a 110/90/16 was going to cause clearance problems with the front fender. Will this be ok or will it have the same problems? the guy told me it will fit like the OEM tire.
Last futzed with by MustangDroid; September 19th, 2012 at 02:50 PM. Reason: title
MustangDroid is offline   Reply With Quote
Old September 19th, 2012, 02:57 PM   #2
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
Is the tire an OEM size? If it's larger, then chances are that it could rub. Compare it to the OEM size. If it's larger try putting it on and pray you get lucky. If you don't get lucky then come up with a way to fix it.
dirty nasty is offline   Reply With Quote
Old September 19th, 2012, 03:00 PM   #3
MustangDroid
Well its wider. Its 110/80/16. Right now I have the tire that came from factory.
Old September 20th, 2012, 02:42 PM   #4
MustangDroid
anybody?
Old September 20th, 2012, 03:28 PM   #5
EMSRacer07
EMSRacer07's Avatar
yes 110/90 will have issues.
http://faq.ninja250.org/wiki/Size_110/90-16_tires
stock tires are 100/80/16. I got 100/90/16 on my bike.
Old September 20th, 2012, 04:45 PM   #6
MustangDroid
Yeah I know but mine is 110/80/16.
Old September 20th, 2012, 04:54 PM   #7
EMSRacer07
EMSRacer07's Avatar
110/90 are 99mm height
110/80 are 88mm height
11mm difference or .43inches
so might fit right. its a little shorter of a tire
Old September 20th, 2012, 04:59 PM   #8
MustangDroid
So you think it should be ok?
Old September 20th, 2012, 05:01 PM   #9
EMSRacer07
EMSRacer07's Avatar
you have almost half inch of play compared to the 110/90 so you should be ok.
Old September 20th, 2012, 05:07 PM   #10
MustangDroid
Ok good, it is noticeably wider but it looks about the same height. Maybe just a little taller.
Old September 20th, 2012, 05:11 PM   #11
EMSRacer07
EMSRacer07's Avatar
from a stock 100/80 tire its only .314inches taller so yea your fine.
Old September 20th, 2012, 05:31 PM   #12
MustangDroid
Ok thanks. I need a front tire already and I bought that from the guy, he told me it was going to fit good. I have a new rear tire so I should be ok.
Old September 20th, 2012, 05:35 PM   #13
EMSRacer07
EMSRacer07's Avatar
Let us know how it goes.
Old October 22nd, 2012, 04:03 PM   #14
MustangDroid
**UPDATE**
So I been too lazy and I finally decided to take the wheel out. They look about the same height but there is a width difference. There is four nuts inside the fender that rubbed in the tire when I try to test fit it. Tomorrow I'm going to take it to a shop and put in the rim. Pics
Old October 22nd, 2012, 04:13 PM   #15
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
What's wrong with the old tire?
Put that fatty on the rear.
Old October 22nd, 2012, 04:18 PM   #16
MustangDroid
Both are front tires. The old one is worn.
Old October 24th, 2012, 08:28 AM   #17
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
110 is the maximum sidewall width in mm when mounted on the design spec rim width. 80 is the percentage the height from the bead to tread is compared to the width. For instance, your tire is 110mm wide, and the height of the tire from the bead to the tread is 110mm x 80% = 88mm. A 110 mm tire is 10mm wider than the stock 100mm, and 10mm is a hair over 3/8", so I'm not surprised it rubs the fender mounting bolts.
Old October 24th, 2012, 06:47 PM   #18
MustangDroid
I finally put it on the bike. There is almost 1/2 inch of clearance from the top of the tire to the fender. There is about 3/4 to 7/8 clearance from the tire to the fender mounting bolts. I also removed the steel bracket from the fender.
Old October 25th, 2012, 11:47 AM   #19
FrugalNinja250
That steel bracket also functions as a fork brace.
Tire Question Malicious Logic 2008 - 2012 Ninja 250R Tech Talk 6 September 21st, 2012 04:05 AM
tire question xMoises831 General Motorcycling Discussion 2 April 24th, 2012 10:26 PM
Another tire question... DRivero 1986 - 2007 Ninja 250R Tech Talk 6 October 18th, 2010 08:20 AM
My tire question.... (Yes, again) Soujyu 2008 - 2012 Ninja 250R Tech Talk 14 June 27th, 2010 07:54 PM
tire upgrade question: front tire? stryder 2008 - 2012 Ninja 250R Tech Talk 1 April 5th, 2010 07:40 AM
