February 17th, 2013, 10:40 AM | #1 |
Yoshimura Chassis Protector Kit
I just placed an order for a Yoshi Frame Slider Kit for the 300!
Part # is 040BG147000 and the cheapest place to buy them is at BiohazardCycles.com. Came out to $165 shipped!
My Ninja 300 Build Photoblog Greater Toronto Area 250/300 Riding Group |
February 20th, 2013, 01:47 PM | #2 |
Good find.
February 20th, 2013, 02:05 PM | #3 |
how badly does it vibrate since you are eliminating the top rubber mount of the engine and instead making it a hard-mount?
February 22nd, 2013, 10:14 PM | #4 |
Join Date: Nov 2012 Motorcycle(s): 2013 Kawasaki Ninja 300 Posts: 53
What? I've got this. Installed it myself. No rubber mounts lost or removed. You reuse the top bolts/nuts and replace the bottom one with a longer bolt. Otherwise nothing is changed from stock, just added. It looks good, IMO, and it seems like it will work well in protecting the bike.
June 17th, 2013, 08:30 AM | #5 |
Friendly Graffiti Artist
Join Date: Jun 2013 Motorcycle(s): 300 SE w/ ABS Posts: 28
was it freaky cutting the fairing hole?
June 17th, 2013, 09:25 AM | #6 |
Kawasaki has premarked the spot. So I drilled that out with with a decent sized drill bit. Then I used a dremel to enlarge until the spacer fit through the hole. The hole doesn't need to be 1.5" or so. It's only about 1/2"-3/4 so the plastic spacer behind the big slider fits through.
