Old February 19th, 2013, 11:17 AM   #1
vman1313
vman1313's Avatar
Motorcycle(s): '14 Honda NC700X; '14 Honda CRF250L; '07 Lifan 200
My baby is sick! =(
I have a stock 2007 with 16k miles on it. I bought her with 9.5k so I have put 7k on the bike myself. I did an oil change, oil filter, and spark plugs when I first bought her. I then changed the oil again at 13k and she is now due her oil change since I do my oil changes at 3.5k. I moved homes and trailer-ed the bike to my new home. I went out on a ride and about a few miles out she just died. She had half a tank of gas so she was not on empty and she had already used up half a tank of gas so I assume the gas was fine. I waited a few minutes playing with the reserve and just messing with the choke and everything else I knew but she still wouldn't crank. Before I started to take off my gear to call someone for help I tried to crank her one more time for "$h!ts and giggles" and she turned right on so I shot out like a "bat-outa-hell" and made it home. I have not been able to keep her running since. At first she would crank with full choke on but would turn off when I gave her gas. Now she barely cranks up with full choke. She cranks then after a few minutes she just shuts off. She will not turn back on but if I let her sit for a few hours I can go back out there, crank her up but again after a few minutes she turns off again. I really haven't had time to play too much with her and am planning to do an oil and oil filter change this week plus maybe the plugs too just to see if it helps out.
She was being ridden about once or twice a week before the problem began due to cold temps and she has always been inside a garage.
Any hints / suggestions??
www.northgariders.com
NuBe4Life!!!
vman1313 is offline   Reply With Quote
Old February 19th, 2013, 11:52 AM   #2
StephenA
Riding Ruby..
StephenA's Avatar
Motorcycle(s): 2014 Yamaha Bolt R-Spec, 2007 Ninja 250R
battery is low?
Unregistered
StephenA is offline   Reply With Quote
Old February 19th, 2013, 12:07 PM   #3
It seems that you engine is starving for gas.
Check the plumbing from the gas tank to the float valves,...........don't forget any in-line fuel filter.
Your carbs need to be fed with around 2 c.c. per second.
Old February 19th, 2013, 12:19 PM   #4
Make sure the petcock is flowing properly.
Other than that, sounds like what mine did when it needed a carb cleaning.
If nothing has changed except it sitting inside and not getting ridden often, it points to dirty carbs to me. Gas can go bad quicker than you think, and the ninjette has tiny carbs that get gummed up easily.
Old February 19th, 2013, 12:20 PM   #5
GlassAnkles
GlassAnkles's Avatar
Motorcycle(s): 02 zx-12r, 13 zx-10r abs
there is a super tiny filter sitting inside the fuel inlet tube coming out of the carb. check that for blockage first because its easy to get to.
GlassAnkles is offline   Reply With Quote
Old February 19th, 2013, 03:54 PM   #6
vman1313
vman1313's Avatar
You guys are amazing...it WAS starving for GAS!! GlassAnkles wins the price but only cause he knew I was a dummy and needed pics
The filters in his pics were caked/blocked up just like in his pic. I cleaned carefully and checked the inside of the tank as best as possible to remove any other debris. (found a little, my fault...I know exactly where it came from) I put her back together and after a few laps up and down the road and then to the gas station...ALL IS WELL!! Thanks all who chimed in and for the thoughts, yall were right on!
Thanks for the knowledge and confidence I could do it myself...sho nuff...I fixed her with out the need to spend a million bucks at a shop.
THANKS AGAIN!!
NuBe4Life!!!
Old February 19th, 2013, 05:02 PM   #7
You are welcome, Tony.
There are many simple service and maintenance works that you can do to save money; just follow the DIY's in the NinjetteWiki or post your questions here.
Old February 19th, 2013, 05:18 PM   #8
vman1313
vman1313's Avatar
I promise I searched this forum for the answer but I just could not find anything definitive. I truly had a hunch that i was just not getting gas (which makes me proud and feel like I am learning) but just needed a place to start.
Again...I say THANKS! I truly appreciate you guys and this site for the knowledge.
NuBe4Life!!!
Old February 19th, 2013, 06:47 PM   #9
Nice work!! It was even easier than I was thinking! Nice.
Old February 19th, 2013, 06:54 PM   #10
Originally Posted by vman1313 View Post
I promise I searched this forum for the answer but I just could not find anything definitive........
Just a reference for your future challenges and endeavors:
http://www.ninjette.org/forums/showthread.php?t=5586
Old February 19th, 2013, 07:05 PM   #11
vman1313
vman1313's Avatar
Dude...thats awesome...thanks for the link! My next endeavor is the clutch cable. It has too much play in it and sometimes I actually have to push it back so that the gear will engage (if that makes sense). I just read the "Replacing the Clucth Cable" section and will first see if I see anything outa' place. If not I figured I would just replace it to see if it fixes the problem. Thanks again!
( Oh and if you have any tips concerning the clutch lever...Im all ears! )
NuBe4Life!!!
Old February 19th, 2013, 07:24 PM   #12
.......Oh and if you have any tips concerning the clutch lever...Im all ears!
http://faq.ninja250.org/wiki/Main_Page
http://faq.ninja250.org/wiki/Adjusting_the_clutch_cable
http://faq.ninja250.org/wiki/Lubing_the_cables
Old February 20th, 2013, 08:30 AM   #13
GlassAnkles
with only 5,500 miles on my 2005 i had to replace it with a motion pro cable as soon as i brought it home. its seems that metal bend it has to take near the handle eats them up sooner that normal. now it smooth as new
http://www.motionpro.com/motorcycle/partno/03-0191/
Old February 21st, 2013, 03:38 PM   #14
n4mwd
n4mwd's Avatar
Tony, glad you solved the fuel flow problem, but to prevent it from happening again, you should add a regular filter in between the petcock and the carb. Also, when putting it up for any length of time, shut the petcock off and ride it around the house until it stalls out. This drains the bowls and helps keep stuff from plugging up from lacquer and other deposits.
My Ninja Blog
Old February 21st, 2013, 05:39 PM   #15
...but that leaves a little bit of gas in the bottom of the bowls.
Just use the drains on the bottom of the bowls. They're there for a reason.
Old February 21st, 2013, 05:59 PM   #16
n4mwd
n4mwd's Avatar
Its more fun to ride it.
My Ninja Blog
Old June 28th, 2015, 04:38 PM   #17
DamonDanner
Motorcycle(s): 2010 Ninja 250
petcock / bogging in mid range / dies after a minute
issues like this with new gas, mid range bogging, but idled fine... checked small inlet filter to carb and was clean, but no gas was coming out the hose when I removed it...put petcock in normal (6 o'clock) position and gas game gushing like it should have... tried blowing in line for "reserve" position and it's got a clog or something in it...runs just fine again.
DamonDanner is offline   Reply With Quote
sick again alex.s Off-Topic 14 May 2nd, 2014 12:34 PM
my baby is sick Blackwidow 2008 - 2012 Ninja 250R Tech Talk 63 July 6th, 2011 05:17 PM
Sick Apex Off-Topic 6 February 22nd, 2011 12:12 PM
[topix.net] - Harley Baby Clothing: Buying Harley Davidson Baby Clothes Ninjette Newsbot Motorcycling News 0 August 6th, 2009 10:50 PM
