March 27th, 2014, 09:45 PM | #41 |
cadd cadd cadd
MOTM - May '15
Can't get the carbs out!!! So close, yet so far
The right side of the airbox doesn't move far back enough!!! ARRRRRGGHHHH! |
March 27th, 2014, 09:53 PM | #42 |
March 27th, 2014, 10:12 PM | #43 |
cadd cadd cadd
MOTM - May '15
You gotta be kidding me! So the rear fairing has to come off as well to get the snorkel off?!
March 27th, 2014, 10:42 PM | #44 |
The Violet Vixen
Join Date: Jun 2012 Motorcycle(s): Perigee (250), Hotaru (250), Saturn (300), Pearl (300), Zero (S1000RR), Chibi (Z125), Xellos ('18 HP4R) Posts: A lot.
MOTM - Jun '16
This is why I put pods on :P
March 27th, 2014, 11:22 PM | #45 |
cadd cadd cadd
MOTM - May '15
Is it possible to take the carbs out without taking the snorkel off?
Has anyone done it? If I take off the left boot that connects the carb to the motor, would I have an easier time taking the carbs out without taking the snorkel off? |
March 28th, 2014, 05:30 AM | #46 |
No, with a little work, you can remove the snorkel right out of the side. It's flexible enough to do it. Once you pry it loose from the airbox, push it back and up slightly, flex it and pull it out from in between the frame. After you tune the carbs, most likely you might not need to put it back anyway.
March 28th, 2014, 05:59 AM | #47 |
Join Date: Mar 2013 Motorcycle(s): 2005 Ninja 250 Posts: 40
March 28th, 2014, 06:32 AM | #48 |
cadd cadd cadd
MOTM - May '15
Assuming I get the carbs out....and clean them.
How would I adjust the fuel air mixture? Don't I have to run the bike? If I do, how on earth am I supposed to get a screwdriver down there and turn the mixture screws?!?! Guess it's time to invest in a tiny tiny tiny stubby screwdriver? |
March 28th, 2014, 06:45 AM | #49 | |
And yes you need a tiny stubby or offset screwdriver Here is some good detailed info. How Constant Velocity Carburetors Work http://www.motorcycleproject.com/mot...bs_work_v3.swf Motorcycle Carburetor Theory 101 http://www.motorcyclecarbs.com/carbs101.pdf |
March 28th, 2014, 06:51 AM | #50 | |
The Violet Vixen
MOTM - Jun '16
March 28th, 2014, 02:01 PM | #51 |
cadd cadd cadd
MOTM - May '15
What a battle!!!
I have no idea if I could get it back in. Such a tight fit. I guess next step is to drain it? Then????? |
March 28th, 2014, 02:09 PM | #52 |
cadd cadd cadd
MOTM - May '15
This is what drained out from the two bowls.
March 28th, 2014, 02:31 PM | #53 |
cadd cadd cadd
MOTM - May '15
Looks clean to me.
March 28th, 2014, 02:36 PM | #54 |
cadd cadd cadd
MOTM - May '15
Floats look good, right?
March 28th, 2014, 02:37 PM | #55 |
March 28th, 2014, 02:52 PM | #56 |
cadd cadd cadd
MOTM - May '15
The main jet says 98.
March 28th, 2014, 03:06 PM | #57 |
March 28th, 2014, 03:27 PM | #58 |
cadd cadd cadd
MOTM - May '15
This is what the needle looks like. Has it been shimmed?
March 28th, 2014, 03:38 PM | #59 |
March 28th, 2014, 04:03 PM | #60 |
cadd cadd cadd
MOTM - May '15
How do I get the needles out?!?! A pair of tweezers would work?
The mixture screws were set as follows: Right side 1.75 turns out Left side 2.5 turns out. I tighten both screws in (needle protrudes). Then I backed each one out 2.5 turns as you recommended. I guess now I have to take the needles out and take a pic for you to look at and see what recommendations you have. I'm assuming with a pair of tweezers, I can just pull them straight out? Or would I have to unscrew them out? |
March 28th, 2014, 04:09 PM | #61 |
March 28th, 2014, 04:12 PM | #62 |
cadd cadd cadd
MOTM - May '15
It looks like a stock needle when I compared it to the pic you posted above. It has a marking "N9VW".
I only took the right needle out. Is it safe to assume the left needle would be the same? |
March 28th, 2014, 04:18 PM | #63 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Yeah should be. You could take a picture of the tank with the gas cap open when you park it then compare when you go to ride again. I know with my bike I just wait until my trip odometer gets close to 200 then I fill up. Is you gearing stock, plugs good, tires right pressure. Maybe try a different gas station or ethanol free. Your carbs look super clean. Make sure you sync them when you put them back on. Hell you could tear out the air box and install pods with a jet kit while your at it.
March 28th, 2014, 04:23 PM | #64 | |
So far everything looks good. If the bike runs fine, you can either shim the needles while you got the carbs out or leave it completely stock. most pople with slip-on exhaust usually shim the needles as well. As the weather gets warmer the performance of the bike will change a little too, but nothing major. It's up to you at this point. BTW, double check your plug gap. I couldn't tell by your pic if it looked good or not. |
March 28th, 2014, 04:32 PM | #65 |
cadd cadd cadd
MOTM - May '15
Does the diaphragm look like it's seated properly to you?
March 28th, 2014, 04:39 PM | #66 |
cadd cadd cadd
MOTM - May '15
Are there any adjustments I need to make to the floats? Or that little Empire state building thing attached to it? If not, I'd like to put those back in and install the bowls back on.
The carbs were extremely clean. I didn't bother cleaning them. I just sprayed some carb cleaner into the four holes (two on each carb). The carb cleaners came out of the main jets and pilot jets. When I put my fingers over the jets while spraying, they came out of those tiny holes. |
March 28th, 2014, 04:41 PM | #67 |
March 28th, 2014, 04:41 PM | #68 | |
March 28th, 2014, 04:47 PM | #69 |
cadd cadd cadd
MOTM - May '15
I did not shim the needles. I don't really want to. I want to keep it as stock as possible. Would this be an issue if I don't shim the needle with a slip on?
Also, how would I measure the float height? Would this be the issue of gasoline flowing through the motor into the crankcase where the motor oil is housed? |
March 28th, 2014, 04:52 PM | #70 | ||
March 28th, 2014, 04:59 PM | #71 |
cadd cadd cadd
MOTM - May '15
About 1.6cm. Is that close enough?
March 28th, 2014, 05:00 PM | #72 |
cadd cadd cadd
MOTM - May '15
DaBlue, after this job gets completed, give me your PayPal addy. I'd like to buy you a drink!
March 28th, 2014, 05:06 PM | #73 |
cadd cadd cadd
MOTM - May '15
Alright, I think I'm going to start putting the carbs back on. Do you guys think adjusting the fuel mixture by turning it out 2.5 turns will solve my issue? Essentially, I didn't do much. I just went
From: Right side 1.75 turns out Left side 2.5 turns out. To: Both sides 2.5 turns out. Another issue I forgot to mention is that it was difficult for me to adjust the idle speed knob. It either jumps up to 1,800 or down to 1,000. I could get it to idle anywhere near 1300rpm. Do you guy recommend that I look at anything else before I attempt to put the carbs back on? |
March 28th, 2014, 05:13 PM | #74 |
That's at 16mm which is fine. 17mm +- 2mm is stock. Adjusting the idle mix screws to 2.5 out should smooth out the idle. Don't forget to sync when your done.
March 28th, 2014, 05:24 PM | #75 | ||
close enough
Check your throttle cables and make sure they have the proper slack (2-3 mm of throttle grip play) then check the throttle linkage lever on the side of the carb and make sure it stops on the idle adjusting screw with the throttle fully closed. |
March 28th, 2014, 05:36 PM | #76 |
cadd cadd cadd
MOTM - May '15
I have Sunday off. I'm going to wait until Sunday before I install the carbs back on. It's going to be another battle I'm not looking towards.
I saw that the throttle cable has a tiny bit of slack when I was pulling the carbs out (when in the fully closed position). I'll make sure when to adjust them accordingly when I reinstall. The idle adjuster has a screw that sits flush with the the throttle assembly in the closed position as well. I'll keep you guys updated once my spark plugs come in and I re-install the carbs back on. I have my fingers crossed!!! If it does not solve the issue, I'm not sure what to do next. I guess I'll take it to a mechanic and tell him what I've done so far and have him/her trouble shoot? |
March 28th, 2014, 05:44 PM | #77 |
cadd cadd cadd
MOTM - May '15
Wait a minute!!!!!
If I went from 1.75 to 2.5 on the fuel mixture screw, wouldn't that make the bike run richer???? |
March 28th, 2014, 06:11 PM | #78 |
It means one side of your bike was running lean and starving for fuel and it runs lean from the factory. The slip on exhaust would've compounded this problem. 2.5 out is good.
Last futzed with by agentbad; March 29th, 2014 at 10:21 AM. |
March 28th, 2014, 07:17 PM | #79 |
cadd cadd cadd
MOTM - May '15
When I took off the carbs, it looks like this.
Right side 1.75 turns out Left side 2.5 turns out. And I find this picture after doing a little more research. This is the default setting from the factory! But why would it be different for each cylinder? Just so confusing! |
March 28th, 2014, 07:27 PM | #80 |
The Violet Vixen
MOTM - Jun '16
If I recall correctly it has to do with the Kleen air system; but I'm super fuzzy on the topic so I could be lying.
ninja 250 won't run video included | possession | 2008 - 2012 Ninja 250R Tech Talk | 17 | April 14th, 2014 06:50 AM |
[roadracingworld.com] - Video: Danny Eslick's Daytona 200 Adventure Included Sliding | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2011 11:20 AM |
Bike filled crankcase with gasoline.... help? | SV_Hadder | 1986 - 2007 Ninja 250R Tech Talk | 23 | January 18th, 2011 09:35 PM |
[visordown.com] - Bike dealer accused of stealing from customers | Ninjette Newsbot | Motorcycling News | 0 | October 24th, 2008 07:13 AM |
[nytimes.com] - Stealing From a Biker Gang | Ninjette Newsbot | Motorcycling News | 0 | June 19th, 2008 07:05 AM |
